- int8_t GPRS_BearerProfile(uint8_t *buf,uint8_t *apn)
- uint8_t ret,ch,i;
- delay_ms(100);
- UART3_BufferClear();
- USART3_PutString("AT+SAPBR=3,1,"Contype","GPRS"\r\n");
- GPRS_WaitFor("OK\r\n",1000);
- delay_ms(500);
- USART3_PutString("AT+SAPBR=3,1,"APN","");
- USART3_PutString((char*)apn);
- USART3_PutString(""\r\n");
- GPRS_WaitFor("OK\r\n",2000);
- delay_ms(500);
- USART3_PutString("AT+SAPBR=1,1\r\n");
- GPRS_WaitFor("OK\r\n",10000);
- delay_ms(500);
- USART3_PutString("AT+SAPBR=2,1\r\n");
- delay_ms(500);
- ret = GPRS_WaitFor("+SAPBR:",3000);
- if(ret)
- GPRS_Response(24);
- if(res_string_index < 8)
- return 0;
- if(res_string_index >22)
- res_string_index = 22;
- for(ch=0;ch<res_string_index;ch++)
- if(res_string[ch]=='"')
- break;
- ch++;
- i=0;
- for(;ch<res_string_index;ch++)
- if(res_string[ch]!='"')
- buf[i] = res_string[ch];
- else
- buf[i]='\0';
- res_string_index=i;
- break;
- i++;
- return res_string_index;
- int8_t GPRS_ContextClose(void)
- delay_ms(100);
- USART3_PutString("AT+SAPBR=0,1\r\n");
- return GPRS_WaitFor("OK\r\n",1000);
- uint16_t GPRS_HTTP_GET(uint8_t *dns, uint8_t *buf)
- uint8_t ret,ch,ResultCode;
- uint16_t length,index;
- uint8_t timeout = 50;
- uint8_t tmp_buf[4];
- delay_ms(100);
- USART3_PutString("AT+HTTPINIT\r\n");
- delay_ms(100);
- USART3_PutString("AT+HTTPPARA="CID",1\r\n");
- delay_ms(100);
- USART3_PutString("AT+HTTPPARA="URL","");
- USART3_PutString((char *)dns);
- delay_ms(100);
- USART3_PutString("AT+HTTPACTION=0\r\n");
- while(timeout--)
- delay_ms(100);
- ret = GPRS_WaitFor("+HTTPACTION:0,",1000);
- if(ret)
- break;
- delay_ms(10);
- tmp_buf[0] = USART3_GetChar();
- tmp_buf[1] = USART3_GetChar();
- tmp_buf[2] = USART3_GetChar();
- tmp_buf[3] = '\0';
- ResultCode = memcmp(tmp_buf,"200",3);
- printf("ResultCode=%d,%s\r\n",ResultCode,tmp_buf);
- if(ret && (ResultCode == 0))
- delay_ms(100);
- memset((char*)tmp_buf,'\0',4);
- USART3_PutString("AT+HTTPREAD\r\n");
- ret = GPRS_WaitFor("+HTTPREAD:",8000);
- //printf("ret = %d\r\n",ret);
- if(ret)
- //delay_ms(10);
- GPRS_WaitForNotRoll("\r\n",500);
- GPRS_ResponseNotLength();
- memcpy(tmp_buf,res_string,res_string_index);
- length = atoi((char*)tmp_buf);
- //printf("buf = %s ,length = %d\r\n",tmp_buf,length);
- if(GPRS_WaitForNotRoll("OK\r\n",10000))
- index = 0;
- do
- ch = USART3_GetChar();
- if(ch != '\r' && ch != '\n')buf[index++] = ch;
- }while(ch);
- delay_ms(100);
- USART3_PutString("AT+HTTPTERM\r\n");
- delay_ms(100);
- return length;
串口通讯记录:
OK
AT+SAPBR=3,1,"APN","CMNET"
OK
AT+SAPBR=1,1
OK
AT+SAPBR=2,1
+SAPBR: 1,1,"10.149.77.103"
OK
AT+HTTPINIT
OK
AT+HTTPPARA="CID",1
OK
AT+HTTPPARA="URL","http://m.weather.com.cn/data/101280601.html"
OK
AT+HTTPACTION=0
OK
+HTTPACTION:0,601,0 // 这里返回601 ,正常为200,以及收到的json格式数据
AT+HTTPTERM
OK
AT+SAPBR=0,1
