使用J-LinkV8
IAR版本6.6
调试串口波特率:115200
基于MDKK70-EK_T43硬件平台
关键词: Freescale 飞思卡尔 Kinetis Cortex-M4 K70 MDKK70 核心板 开发板 例程 demo 低功耗定时器 LPTMR
实验现象:
编译并下载调试程序,根据串口提示信息进行测试。
串口输出:
K70-256pin Silicon rev 1.0
Flash parameter version 0.0.8.0
Flash version ID 1.0.18.0
LPTMR Examples
LPTMR Time Counting Example
LPTMR using LPO clock with no prescale, and compare value=5000 (5 seconds)
Press a key to start counter
Current value of counter register CNR is 5000
Waited for 5000 counts
End of Time Counting Example
Current value of pulse count register CNR is XXX.
Detected 1000 pulses on LPTMR_ALT2
End of Pulse Counting Example
LPTMR Time Counting Example with Prescaler
LPTMR using LPO clock with PRESCALE=4 and compare value=250 (8 seconds)
Current value of counter register CNR is 250
Waited for 250 counts
End of Time Counting Example with Prescale
Internal Reference Clock Example
LPTMR using fast internal ref clock with PRESCALE=0x8, and compare value=15625 (4 seconds)
Counting...
4 seconds should have passed
End of Internal reference Clock Source Example
LPO Clock Source Example
LPTMR using LPO clock with no prescale, and compare value=4000 (4 seconds)
Counting...
End of LPO Clock Source Example
32 Khz Clock Source Example
Test using RTC OSC
LPTMR using 32Khz clock with PRESCALE=0x1, and compare value=32768 (4 seconds)
Counting...
End of 32 Khz Clock Source Example
External Clock Source Example
LPTMR using external clock with PRESCALE=0xF, and compare value=7630 (10 seconds)
Counting...
Timer should have waited for 10 seconds
End of External Clock Example
LPTMR Interrupt Example
Counting...
In LPT ISR!
Timer should have waited for 5 seconds
End of LPTMR Interrupt Example
LPTMR Pulse Counting Example on LPTMR_ALT1
Testing ALT1 pin on PORTA19
PA19位于GPIO引出口,请给PA19脉冲
This test requires a function generator, or another way of producing a pulse signal on the pin specified above. Please connect that device to the specified pin
If you would like to continue with this example, press "y". To skip press any other key
Press any key to start pulse counter
Current value of pulse count register CNR is xxx.
Detected 1000 pulses on LPTMR_ALT1
LPTMR Pulse Counting Example on LPTMR_ALT2
Testing ALT2 pin on PORTC5
PC5位于核心板20*2口第8脚引出口,请给PC5脉冲
End of LPTMR Examples
