9.9新,友晶fpga开发板de2i-150可以安装linux,windows7,开发板中有intel atom cpu,fp
ga芯片,64g ssd,2g内存,无线wifi模块,可以用于pci-e的开发。
价格 3000
电话15807183820
QQ 811741874
Microprocessor
CPU : Intel® Atom™ Dual Core Processor N2600( 1M Cache, 1.6GHz )
Intel® Hyper-Threading Technology( 4 exection threads )
Intel SpeedStep® Technology
Instruction Set : 64-bit
Instruction Set Extensions : SSE2, SSE3, SSSE3
Integrated Graphics
Graphics Base Frequency : 400MHz
Chipset : Intel® NM10 Express Chipset
DMI x2 to CPU
Intel® High Definition Audio
Serial ATA (SATA) 3 Gb/s
Universal Serial Bus(USB) Hi-Speed USB 2.0
PCI Express Gen 1
Memory
DDR3 SO-DIMM SDRAM
Ethernet
Intel® 82583V GbE Controller
10/100/1000 Mb/s RJ45
3 status indicting LEDs
Display
VGA
HDMI 1.3a
Audio Codec
Realtek ALC272VA3-GR
BIOS
DIP package Bios Flash : GD25Q16
Programming Interface for Bios : Dedi-Prog Interface
Debug Interface
XDP header
Clock System
CK505 : 9VRS4339B
32768 Hz RTC crystal
27MHz VGA clock source
Others
Power header for hard-disk
Current limit for USB
Buzzer
Mini PCIE header (Default for Intel® Centrino® Advance-N 6205 WiFi modu
le)
mSATA header
RTC battery : CR2032
FPGA
Featured Devices
Cyclone IV GXP4CGX150F31 device
149,760 LEs
720 M9K memory blocks
6,480 Kbits embedded memory
8 PLLs
FPGA configuration
JTAG and AS mode configuration
EPCS64 serial configuration device
On-board USB Blaster circuitry
Memory devices
128MB (32Mx32bit) SDRAM
4MB (1Mx32) SSRAM
64MB (4Mx16) Flash with 16-bit mode
SD Card socket
Provides SPI and 4-bit SD mode for SD Card access
Connectors
Ethernet 10/100/1000 Mbps ports
High Speed Mezzanine Card (HSMC)
40-pin expansion port
VGA-out connector
VGA DAC (high speed triple DACs)
DB9 serial connector for RS-232 port with flow control
Clock
Three 50MHz oscillator clock inputs
SMA connectors (external clock input/output)
Display
16x2 LCD module
Switches and indicators
18 slide switches and 4 push-buttons switches
18 red and 9 green LEDs
Eight 7-segment displays
Other features
Infrared remote-control receiver module
TV decoder (NTSC/PAL/SECAM) and TV-in connector
