代码自己写的,在Ubuntu下GCC编译通过,经少量AVR的HEX测试无误,如有纰漏错误,请自行判断纠正!!!!!!!!!!!!!!
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- typedef signed char int8_t;
- typedef unsigned char uint8_t;
- typedef signed short int16_t;
- typedef unsigned short uint16_t;
- typedef signed int int32_t;
- typedef unsigned int uint32_t;
- typedef float flt_t;
- typedef double lflt_t;
- #define _not_hex_(src) ((('0' > src) || ('9' < src)) && (('a' > src) || ('f' < src)) && (('A' > src) || ('F' < src)))
- #define _hex_trans_eq_(src,dst) \
- if (_not_hex_(src)) \
- return HEX_ERR; \
- if (('0' <= (src)) && ('9' >= (src))) \
- dst = (src) - '0'; \
- else if (('a' <= (src)) && ('f' >= (src))) \
- dst = (src) - 'a' + 10; \
- else if (('A' <= (src)) && ('F' >= (src))) \
- dst = (src) - 'A' + 10; \
- #define _hex_trans_or_(src,dst) \
- return HEX_ERR; \
- dst |= (src) - '0'; \
- dst |= (src) - 'a' + 10; \
- dst |= (src) - 'A' + 10; \
- #define _hex_trans_or_shift_(src,dst) \
- dst <<= 4; \
- _hex_trans_or_(src,dst); \
- enum RESULT{HEX_ERR = -1, HEX_DATA_OK = 0, HEX_END_OK = 1, HEX_LBA_OK = 2, HEX_SEG_OK = 3};
- int8_t _hex2bin_(const uint8_t* src, uint8_t* dst, uint8_t* data_type, uint8_t* data_len, uint16_t* data_addr)
- uint8_t check_sum, i;
- // 如果源code长度小于11,表明源code有误!
- if (11 > strlen((const char*)src))
- return HEX_ERR;
- // 校验起始字节是否为':',如果不为':',表明源code有误!
- if (':' != *src++)
- return HEX_ERR;
- // 得到数据长度的高4位
- _hex_trans_eq_(*src, *data_len);
- src++;
- // 得到数据长度的低4位
- _hex_trans_or_shift_(*src, *data_len);
- src++;
- // 校验和
- check_sum = *data_len;
- // 得到数据地址
- _hex_trans_eq_(*src, *data_addr);
- src++;
- _hex_trans_or_shift_(*src, *data_addr);
- src++;
- // 校验和
- check_sum += *data_addr;
- src++;
- src++;
- // 校验和
- // 得到数据类型
- _hex_trans_eq_(*src, *data_type);
- src++;
- _hex_trans_or_shift_(*src, *data_type);
- src++;
- // 校验和
- check_sum += *data_type;
- switch (*data_type)
- case 0: // 数据记录
- for (i = *data_len; i; i--, dst++)
- _hex_trans_eq_(*src, *dst);
- src++;
- _hex_trans_or_shift_(*src, *dst);
- src++;
- // 校验和
- check_sum += *dst;
- // 校验
- _hex_trans_eq_(*src, i);
- src++;
- _hex_trans_or_shift_(*src, i);
- check_sum += i;
- return check_sum? HEX_ERR : HEX_DATA_OK;
- case 1: // 文件结束记录
- if (*data_addr)
- return HEX_ERR;
- // 校验
- src++;
- check_sum += i;
- return check_sum? HEX_ERR : HEX_END_OK;
- case 2: // 扩展段地址记录
- if (*data_addr)
- return HEX_ERR;
- // 得到扩展段地址
- src++;
- src++;
- // 校验和
- src++;
- src++;
- // 校验和
- return check_sum? HEX_ERR : HEX_SEG_OK;
- case 4: // 扩展线性地址记录
- if (*data_addr)
- return HEX_ERR;
- // 得到扩展段地址
- // 得到数据地址
- src++;
- src++;
- // 校验和
- src++;
- src++;
- // 校验和
- return check_sum? HEX_ERR : HEX_LBA_OK;
- default:
- return HEX_ERR;
- return HEX_ERR;
- int8_t hex2bin(const int8_t* src_file_path, const int8_t* dst_file_path)
- uint8_t buffer_hex[1024], buffer_bin[256];
- uint8_t data_type, len_bin;
- uint16_t addr_low;
- uint32_t addr_high = 0;
- FILE* src_file;
- FILE* dst_file;
- src_file = fopen((const char*)src_file_path, "r");
- if (!src_file)
- return -1;
- dst_file = fopen((const char*)dst_file_path, "wb");
- if (!dst_file)
- fclose(src_file);
- return -1;
- for ( ; !feof(src_file); )
- if (NULL == fgets((char*)buffer_hex, 1024, src_file))
- break;
- if (HEX_ERR == _hex2bin_((const uint8_t*)buffer_hex, (uint8_t*)buffer_bin, &data_type, &len_bin, &addr_low))
- break;
- switch (data_type)
- case 0: // 数据记录
- if (ftell(dst_file) != addr_low + addr_high)
- fseek(dst_file, addr_low + addr_high, SEEK_SET);
- if (1 != fwrite((const uint8_t*)buffer_bin, len_bin, 1, dst_file))
- fclose(src_file);
- fclose(dst_file);
- return -1;
- break;
- case 1: // 文件结束记录
- fclose(src_file);
- fclose(dst_file);
- return 0;
- addr_high = ((uint32_t)addr_low) << 2;
- break;
- addr_high = ((uint32_t)addr_low) << 16;
- break;
- default:
- fclose(src_file);
- fclose(dst_file);
- return -1;
- fclose(src_file);
- fclose(dst_file);
- return 0;
- int main(void)
- if (!hex2bin((const int8_t*)"avr-test.hex",(const int8_t*)"avr-test.bin"))
- printf("ok!\n");
- return 0;
复制代码 |
