问题已解决
注意:proteus 中但1602有ASCII字库,12864不带字库
0~9纵向取模得到
- unsigned char code n0[]={/*-- 文字: 0 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00};
- unsigned char code n1[]={/*-- 文字: 1 --*/
- 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00};
- unsigned char code n2[]={/*-- 文字: 2 --*/
- 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00};
- unsigned char code n3[]={/*-- 文字: 3 --*/
- 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00};
- unsigned char code n4[]={/*-- 文字: 4 --*/
- 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00};
- unsigned char code n5[]={/*-- 文字: 5 --*/
- 0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00};
- unsigned char code n6[]={/*-- 文字: 6 --*/
- 0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00};
- unsigned char code n7[]={/*-- 文字: 7 --*/
- 0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00};
- unsigned char code n8[]={/*-- 文字: 8 --*/
- 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00};
- unsigned char code n9[]={/*-- 文字: 9 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00};
取模软件: |
