发表于 2013-12-25 21:27:23
这是这段相关的代码
#include "IMU.h"
#include "MPU6050.h"
#include "math.h"
#define RtA 57.324841 //弧度到角度
#define AtR 0.0174533 //度到角度
#define Acc_G 0.0011963 //加速度变成G
#define Gyro_G 0.0152672 //角速度变成度
#define Gyro_Gr 0.0002663
#define FILTER_NUM 20
S_INT16_XYZ ACC_AVG; //平均值滤波后的ACC
S_FLOAT_XYZ GYRO_I; //陀螺仪积分
S_FLOAT_XYZ EXP_ANGLE; //期望角度
S_FLOAT_XYZ DIF_ANGLE; //期望角度与实际角度差
S_FLOAT_XYZ Q_ANGLE; //四元数计算出的角度
int16_t ACC_X_BUF[FILTER_NUM],ACC_Y_BUF[FILTER_NUM],ACC_Z_BUF[FILTER_NUM]; //加速度滑动窗口滤波数组
void Prepare_Data(void)
static uint8_t filter_cnt=0;
int32_t temp1=0,temp2=0,temp3=0;
uint8_t i;
MPU6050_Read();
MPU6050_Dataanl();
ACC_X_BUF[filter_cnt] = MPU6050_ACC_LAST.X;//更新滑动窗口数组
ACC_Y_BUF[filter_cnt] = MPU6050_ACC_LAST.Y;
ACC_Z_BUF[filter_cnt] = MPU6050_ACC_LAST.Z;
for(i=0;i<FILTER_NUM;i++)
temp1 += ACC_X_BUF;
temp2 += ACC_Y_BUF;
temp3 += ACC_Z_BUF;
ACC_AVG.X = temp1 / FILTER_NUM;
ACC_AVG.Y = temp2 / FILTER_NUM;
ACC_AVG.Z = temp3 / FILTER_NUM;
filter_cnt++;
if(filter_cnt==FILTER_NUM) filter_cnt=0;
//以下是积分值
GYRO_I.Z+ = MPU6050_GYRO_LAST.Z*Gyro_G*0.001;//0.001是时间间隔,两次prepare的执行周期
void Get_Attitude(void)
IMUupdate(MPU6050_GYRO_LAST.X*Gyro_Gr,
MPU6050_GYRO_LAST.Y*Gyro_Gr,
MPU6050_GYRO_LAST.Z*Gyro_Gr,
ACC_AVG.X,ACC_AVG.Y,ACC_AVG.Z); //*0.0174转成弧度
#define Kp 2.0f // proportional gain governs rate of convergence to accelerometer/magnetometer
#define Ki 0.005f // integral gain governs rate of convergence of gyroscope biases
#define halfT 0.5f // half the sample period
float q0 = 1, q1 = 0, q2 = 0, q3 = 0; // quaternion elements representing the estimated orientation
float exInt = 0, eyInt = 0, ezInt = 0; // scaled integral error
void IMUupdate(float gx, float gy, float gz, float ax, float ay, float az)
float norm;
float vx, vy, vz;
float ex, ey, ez;
if(ax*ay*az==0)
return;
norm = sqrt(ax*ax + ay*ay + az*az); //acc数据归一化
ax = ax /norm;
ay = ay / norm;
az = az / norm;
// estimated direction of gravity and flux (v and w) 估计重力方向和流量/变迁
vx = 2*(q1*q3 - q0*q2); //四元素中xyz的表示
vy = 2*(q0*q1 + q2*q3);
vz = q0*q0 - q1*q1 - q2*q2 + q3*q3 ;
// error is sum of cross product between reference direction of fields and direction measured by sensors
ex = (ay*vz - az*vy) ; //向量外积在相减得到差分就是误差
ey = (az*vx - ax*vz) ;
ez = (ax*vy - ay*vx) ;
exInt = exInt + ex * Ki; //对误差进行积分
eyInt = eyInt + ey * Ki;
ezInt = ezInt + ez * Ki;
// adjusted gyroscope measurements
gx = gx + Kp*ex + exInt; //将误差PI后补偿到陀螺仪,即补偿零点漂移
gy = gy + Kp*ey + eyInt;
gz = gz + Kp*ez + ezInt; //这里的gz由于没有观测者进行矫正会产生漂移,表现出来的就是积分自增或自减
// integrate quaternion rate and normalise //四元素的微分方程
q0 = q0 + (-q1*gx - q2*gy - q3*gz)*halfT;
q1 = q1 + (q0*gx + q2*gz - q3*gy)*halfT;
q2 = q2 + (q0*gy - q1*gz + q3*gx)*halfT;
q3 = q3 + (q0*gz + q1*gy - q2*gx)*halfT;
// normalise quaternion
norm = sqrt(q0*q0 + q1*q1 + q2*q2 + q3*q3);
q0 = q0 / norm;
q1 = q1 / norm;
q2 = q2 / norm;
q3 = q3 / norm;
Q_ANGLE.Z = GYRO_I.Z;
Q_ANGLE.Y = asin(-2 * q1 * q3 + 2 * q0* q2)* 57.3; // pitch
Q_ANGLE.X = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 57.3; // roll
