回复: 7
请帮忙看一下这个程序报错的问题,急!
发表于 2013-12-14 18:24:36 | 显示全部楼层 |阅读模式
在arduino 105中提示:
sketch_dec13a:26: error: variable or field 'MoveWheels' declared void
sketch_dec13a:26: error: 'WheelDirection' was not declared in this scope
sketch_dec13a:26: error: expected primary-expression before 'int'
以下是程序
#define __AVR_ATmega328P__
* Self-Balancing Robot
* Kerry D. Wong
* http://www.kerrywong.com
* Built with NetBeans IDE
* The I2C library code is from DSSCircuits
* http://dsscircuits.com/articles/arduino-i2c-master-library.html
#include <Arduino.h>
#include <math.h>
#include <I2C/I2C.h>
//<editor-fold defaultstate="collapsed" desc="PIN Defenitions">
const int PIN_GYRO_X = 0; //analog 0
const int PIN_GYRO_Z = 1; //analog 1
const int PIN_MOTOR_1 = 3;
const int PIN_MOTOR_2 = 5;
const int PIN_MODE_SWITCH = 2;
const int PIN_MODE_LED = 6;
//</editor-fold>
//<editor-fold defaultstate="collapsed" desc="Accelerometer Register Defenitions">
const byte REG_STATUS = 0x00; //(R) Real time status
const byte REG_OUT_X_MSB = 0x01; //(R) [7:0] are 8 MSBs of 10-bit sample
const byte REG_OUT_X_LSB = 0x02; //(R) [7:6] are 2 LSBs of 10-bit sample
const byte REG_OUT_Y_MSB = 0x03; //(R) [7:0] are 8 MSBs of 10-bit sample
const byte REG_OUT_Y_LSB = 0x04; //(R) [7:6] are 2 LSBs of 10-bit sample
const byte REG_OUT_Z_MSB = 0x05; //(R) [7:0] are 8 MSBs of 10-bit sample
const byte REG_OUT_Z_LSB = 0x06; //(R) [7:6] are 2 LSBs of 10-bit sample
const byte REG_SYSMOD = 0x0b; //(R) Current system mode
const byte REG_INT_SOURCE = 0x0c; //(R) Interrupt status
const byte REG_WHO_AM_I = 0x0d; //(R) Device ID (0x3A)
const byte REG_XYZ_DATA_CFG = 0xe; //(R/W) Dynamic range settings
const byte REG_HP_FILTER_CUTOFF = 0x0f; //(R/W) cut-off frequency is set to 16Hz @ 800Hz
const byte REG_PL_STATUS = 0x10; //(R) Landscape/Portrait orientation status
const byte REG_PL_CFG = 0x11; //(R/W) Landscape/Portrait configuration
const byte REG_PL_COUNT = 0x12; //(R) Landscape/Portrait debounce counter
const byte REG_PL_BF_ZCOMP = 0x13; //(R) Back-Front, Z-Lock trip threshold
const byte REG_P_L_THS_REG = 0x14; //(R/W) Portrait to Landscape trip angle is 29 degree
const byte REG_FF_MT_CFG = 0x15; //(R/W) Freefall/motion functional block configuration
const byte REG_FF_MT_SRC = 0x16; //(R) Freefall/motion event source register
const byte REG_FF_MT_THS = 0x17; //(R/W) Freefall/motion threshold register
const byte REG_FF_MT_COUNT = 0x18; //(R/W) Freefall/motion debounce counter
const byte REG_TRANSIENT_CFG = 0x1d; //(R/W) Transient functional block configuration
const byte REG_TRANSIENT_SRC = 0x1e; //(R) Transient event status register
const byte REG_TRANSIENT_THS = 0x1f; //(R/W) Transient event threshold
const byte REG_TRANSIENT_COUNT = 0x20; //(R/W) Transient debounce counter
const byte REG_PULSE_CFG = 0x21; //(R/W) ELE, Double_XYZ or Single_XYZ
const byte REG_PULSE_SRC = 0x22; //(R) EA, Double_XYZ or Single_XYZ
const byte REG_PULSE_THSX = 0x23; //(R/W) X pulse threshold
const byte REG_PULSE_THSY = 0x24; //(R/W) Y pulse threshold
const byte REG_PULSE_THSZ = 0x25; //(R/W) Z pulse threshold
const byte REG_PULSE_TMLT = 0x26; //(R/W) Time limit for pulse
const byte REG_PULSE_LTCY = 0x27; //(R/W) Latency time for 2nd pulse
const byte REG_PULSE_WIND = 0x28; //(R/W) Window time for 2nd pulse
const byte REG_ASLP_COUNT = 0x29; //(R/W) Counter setting for auto-sleep
const byte REG_CTRL_REG1 = 0x2a; //(R/W) ODR = 800 Hz, STANDBY mode
const byte REG_CTRL_REG2 = 0x2b; //(R/W) Sleep enable, OS Modes, RST, ST
const byte REG_CTRL_REG3 = 0x2c; //(R/W) Wake from sleep, IPOL, PP_OD
const byte REG_CTRL_REG4 = 0x2d; //(R/W) Interrupt enable register
const byte REG_CTRL_REG5 = 0x2e; //(R/W) Interrupt pin (INT1/INT2) map
const byte REG_OFF_X = 0x2f; //(R/W) X-axis offset adjust
const byte REG_OFF_Y = 0x30; //(R/W) Y-axis offset adjust
const byte REG_OFF_Z = 0x31; //(R/W) Z-axis offset adjust
const byte I2C_ADDR = 0x1c;
//</editor-fold>
//<editor-fold defaultstate="collapsed" desc="Accelerometer Scale Defenitions">
const byte FULL_SCALE_RANGE_2g = 0x0;
const byte FULL_SCALE_RANGE_4g = 0x1;
const byte FULL_SCALE_RANGE_8g = 0x2;
//</editor-fold>
//<editor-fold defaultstate="collapsed" desc="Wheel Directions">
enum WheelDirection {
  DIR_FORWARD,
  DIR_BACKWARD,
  DIR_STOP
//</editor-fold>
//<editor-fold defaultstate="collapsed" desc="Gyro initial value">
float GYRO_X_INIT_VAL = 450.0;
//</editor-fold>
//<editor-fold defaultstate="collapsed" desc="Other Constants"> */
//gyro: 500 dps
//acc: 2g -256,256
const float INIT_ANGLE = -0.005;
const int ANGLE_BUFFER_LENGTH = 3;
const float SumErrMax = 3;
const float SumErrMin = -3;
//</editor-fold>
// <editor-fold defaultstate="collapsed" desc="Global Variables">
int VxAcc = 0, VyAcc = 0, VzAcc = 0;
int VxGyro = 0, VzGyro = 0;
float degX = 0.0f, degY = 0.0f, degZ = 0.0f;
float throttle = 0.0;
float accAngle = 0.0, currAngle = 0.0, prevAngle = 0.0, elapsedTimeSec=0.0;
unsigned long prevTimeStamp = 0, currTimeStamp = 0, elapsedTime = 0;
boolean isFirstTime = false;
float angleBuffer[ANGLE_BUFFER_LENGTH];
int angleBufferIndex = 0;
boolean MotorOff = false;
float curErr = 0, prevErr = 0, SumErr = 0;
float integralTerm = 0, derivativeTerm = 0;
float Kp = 30000.0, Ki = 50000,  Kd = 500;
float Cn = 0;
// </editor-fold>
// <editor-fold defaultstate="collapsed" desc="Accelerometer Functions">
  Read register content into buffer.
The default count is 1 byte.
The buffer needs to be pre-allocated
if count > 1
void regRead(byte reg, byte *buf, byte count = 1) {
  I2c.write(I2C_ADDR, reg);
  I2c.read(I2C_ADDR, reg, count);
  for (int i = 0; i < count; i++)
    *(buf + i) = I2c.receive();
  Write a byte value into a register
void regWrite(byte reg, byte val) {
  I2c.write(I2C_ADDR, reg, val);
  Put MMA8453Q into standby mode
void standbyMode() {
  byte reg;
  byte activeMask = 0x01;
  regRead(REG_CTRL_REG1, &reg);
  regWrite(REG_CTRL_REG1, reg & ~activeMask);
Put MMA8453Q into active mode
void activeMode() {
  byte reg;
  regWrite(REG_CTRL_REG1, reg | activeMask);
  Use fast mode (low resolution mode)
The acceleration readings will be
limited to 8 bits in this mode.
void lowResMode() {
  byte reg;
  byte fastModeMask = 0x02;
  regWrite(REG_CTRL_REG1, reg | fastModeMask);
  Use default mode (high resolution mode)
10 bits in this mode.
void hiResMode() {
  byte reg;
  regWrite(REG_CTRL_REG1, reg & ~fastModeMask);
  get accelerometer readings (x, y, z)
by default, standard 10 bits mode is used.
if accelerometer is initialized to use low res mode,
isHighRes must be passed in as false.
void getAccXYZ(int *x, int *y, int *z, bool isHighRes = true) {
  byte buf[6];
  if (isHighRes) {
    regRead(REG_OUT_X_MSB, buf, 6);
    *x = buf[0] << 2 | buf[1] >> 6 & 0x3;
    *y = buf[2] << 2 | buf[3] >> 6 & 0x3;
    *z = buf[4] << 2 | buf[5] >> 6 & 0x3;
  else {
    regRead(REG_OUT_X_MSB, buf, 3);
    *x = buf[0] << 2;
    *y = buf[1] << 2;
    *z = buf[2] << 2;
  if (*x > 511) *x = *x - 1024;
  if (*y > 511) *y = *y - 1024;
  if (*z > 511) *z = *z - 1024;
//</editor-fold>
// <editor-fold defaultstate="collapsed" desc="Calibrate Gyro">
float CalGyro() {
  float val = 0.0;
  digitalWrite(PIN_MODE_LED, HIGH);
  delay(500);
  for (int i = 0; i < 25; i++) {
    val += analogRead(PIN_GYRO_X);
    delay(10);
  val /= 25.0;
  Serial.print("GyroX Stationary=");
  Serial.println(val);
  digitalWrite(PIN_MODE_LED, LOW);
  return val;
}// </editor-fold>
// <editor-fold defaultstate="collapsed" desc="Angle estimation">
float GetAvgAngle() {
  int count = 0;
  float a = 0;
  for (int i = 0; i < ANGLE_BUFFER_LENGTH; i++) {
    if (angleBuffer != 0) {
      count++;
      a += angleBuffer;
  if (count > 0)
    return a / float(count);
    return 0.0;
float GetAccAngle() {
  getAccXYZ(&VxAcc, &VzAcc, &VyAcc);
  float r = sqrt((float) VzAcc * (float) VzAcc + (float) VyAcc * (float) VyAcc);
  accAngle = (float) VzAcc / r; //approximates sine
  return accAngle;
float EstimateAngle() {
  currTimeStamp = micros();
  elapsedTime = currTimeStamp - prevTimeStamp;
  prevTimeStamp = currTimeStamp;
  elapsedTimeSec = (float) elapsedTime / 1e6f;
  float angle = GetAccAngle();
  if (isFirstTime) {
    currAngle = angle;
  else {
    VxGyro = analogRead(PIN_GYRO_X);
    degX = (float) (VxGyro - GYRO_X_INIT_VAL) * 3300.0f / 512.0f / 180.0f * (float) elapsedTimeSec;
    currAngle = 0.95 * (prevAngle + degX) + 0.05 * angle;
  prevAngle = currAngle;
  if (MotorOff) { //for debugging purposes
    Serial.print("\tcurrAngleAvg=");
    Serial.print(GetAvgAngle(), 4);
    Serial.print("\tcurrAngle=");
    Serial.print(currAngle, 4);
    Serial.print("\taccAngle=");
    Serial.print(accAngle);
    Serial.print("\tgyroAngle=");
    Serial.print(degX);
    Serial.print("\tVxGyro=");
    Serial.print(VxGyro);
    Serial.print("\telapsedTime=");
    Serial.print(elapsedTime);
    Serial.print("\tthrottle=");
    Serial.println(throttle);
  return currAngle;
// </editor-fold>
// <editor-fold defaultstate="collapsed" desc="Drive">
void MoveWheels(WheelDirection dir, int speed) {
  if (MotorOff) return;
  if (speed > 255) speed = 255;
  else if (speed < 0) speed = 0;
  if (dir == DIR_STOP) {
    digitalWrite(PIN_MOTOR_1, LOW);
    digitalWrite(PIN_MOTOR_2, LOW);
  else if (dir == DIR_FORWARD) {
    analogWrite(PIN_MOTOR_1, speed);
  else if (dir == DIR_BACKWARD) {
    analogWrite(PIN_MOTOR_2, speed);
// </editor-fold>
void setup() {
  I2c.begin();
  Serial.begin(9600);
  standbyMode(); //register settings must be made in standby mode
  regWrite(REG_XYZ_DATA_CFG, FULL_SCALE_RANGE_2g);
  hiResMode();
  activeMode();
  pinMode(PIN_MOTOR_1, OUTPUT);
  pinMode(PIN_MOTOR_2, OUTPUT);
  pinMode(PIN_MODE_LED, OUTPUT);
  pinMode(PIN_MODE_SWITCH, INPUT);
  digitalWrite(PIN_MODE_SWITCH, HIGH);
  Serial.print("Motor is ");
  if (digitalRead(PIN_MODE_SWITCH) == HIGH) {
    MotorOff = true;
    Serial.println("OFF");
  else {
    MotorOff = false;
    Serial.println("ON");
  byte b;
  regRead(REG_WHO_AM_I, &b);
  Serial.println(b, HEX);
  for (int i = 0; i < ANGLE_BUFFER_LENGTH; i++) angleBuffer = 0;
  GYRO_X_INIT_VAL = CalGyro();
void loop() {
  float a = EstimateAngle() - INIT_ANGLE;
  angleBuffer[angleBufferIndex] = a;
  angleBufferIndex = (angleBufferIndex + 1) % ANGLE_BUFFER_LENGTH;
  float ang = GetAvgAngle();
  curErr = ang - INIT_ANGLE; //error
  SumErr += curErr;
  if (SumErr > SumErrMax) SumErr = SumErrMax;
  else if (SumErr < SumErrMin) SumErr = SumErrMin;
  //Ki*SumE/(Kp*Fs*X)
  integralTerm = SumErr * elapsedTimeSec * Ki / Kp * 10.0;
  derivativeTerm = curErr - prevErr;
  if(derivativeTerm > 0.1) derivativeTerm = 0.1;
  else if (derivativeTerm < -0.1) derivativeTerm = -0.1;
  // Kd(curErr-prevErr)*Ts/(Kp*X)
  derivativeTerm = derivativeTerm * Kd * elapsedTimeSec / Kp;
  if(derivativeTerm > 120) derivativeTerm = 120;
  else if (derivativeTerm < -120) derivativeTerm = -120;
  Cn = (curErr + integralTerm + derivativeTerm) * Kp / 10.0;
  Serial.println(Cn);
  WheelDirection dir;
  if (Cn > 0) dir = DIR_FORWARD;
  else if (Cn < -0) dir = DIR_BACKWARD;
  else dir = DIR_STOP;
  throttle = abs(Cn);
  if (abs(ang) > 0.7)  MoveWheels(DIR_STOP, 0); //if angle too large to correct, stop motor
  else MoveWheels(dir, throttle);
  prevErr = curErr;
 楼主| 发表于 2013-12-14 19:22:17 | 显示全部楼层
没人能回答一下吗
出0入25汤圆
发表于 2013-12-14 20:14:34 | 显示全部楼层
enum 变量定义不对!
 楼主| 发表于 2013-12-14 20:33:37 | 显示全部楼层
为何不对
 楼主| 发表于 2013-12-14 20:37:29 | 显示全部楼层
墨非 发表于 2013-12-14 20:14
enum 变量定义不对!
哪里不对?这个程序在他人的机子上编译通过的。
出0入25汤圆
发表于 2013-12-14 20:42:25 | 显示全部楼层
typedef  enum  VALUE
one,
two,
three,
}value_t;
enum VALUE num;
value_t num;
 楼主| 发表于 2013-12-14 22:59:00 | 显示全部楼层
墨非 发表于 2013-12-14 20:42
typedef  enum  VALUE
one,
谢谢回复,我再试试看
发表于 2013-12-20 23:13:04 | 显示全部楼层
你好,你的328P熔丝位设置的是多少呢
GMT+8, 2024-7-23 23:28
