用的是MC96F6432Q单片机,是51内核的,问了他们的FAE说:”这个问题是很正常的,因为是8位机嘛!所以你要把int数组拆成8位,要是有问题问keil公司!“真炒蛋!
我的数组定义如下:
unsigned int code battery_sheet[100] =
2267, //3.0990V
2299, //3.1436V
2319, //3.1711V
2333, //3.1898V
2344, //3.2051V
2353, //3.2174V
2362, //3.2297V
2371, //3.2410V
2378, //3.2513V
2386, //3.2615V
2393, //3.2710V
2399, //3.2801V
2405, //3.2880V
2411, //3.2957V
2416, //3.3030V
2828, //3.8669V
2837, //3.8783V
2846, //3.8909V
2855, //3.9037V
2865, //3.9170V
2875, //3.9313V
2886, //3.9452V
2896, //3.9599V
2908, //3.9763V
2922, //3.9949V
2938, //4.0164V
2959, //4.0450V
在引用的时候出错了!!!!
PS: 优化等级原先是8,后来改成了0还是不行!
最新发现:在子程序里面调用没有问题!于是定义了一个专门的函数:
unsigned int ReadArray_BAT(unsigned char index)
return battery_sheet[index]; }
