fpga4fun 是一个很不错的关于FPGA 的外国网站 里面提供了很多实例,不过最近好像登录不上了!
其中有一个关于 uart 的实例很经典,当中关于波特率的一段尤其经典,可以不是很懂。
所以今天想仿真一下 ,看看这段经典代码的是如何实现的.....可惜捣鼓了很久都没仿出波形来,求各为大牛帮帮忙看看什么原因~~~~
这是fpga4fun uart 接收 的代码
- // RS-232 RX module
- // (c) fpga4fun.com KNJN LLC - 2003, 2004, 2005, 2006
- module async_receiver(clk, RxD, RxD_data_ready, RxD_data, RxD_endofpacket, RxD_idle);
- input clk, RxD;
- output RxD_data_ready; // onc clock pulse when RxD_data is valid
- output [7:0] RxD_data;
- parameter ClkFrequency = 50000000; // 25MHz
- parameter Baud = 9600;
- // We also detect if a gap occurs in the received stream of characters
- // That can be useful if multiple characters are sent in burst
- // so that multiple characters can be treated as a "packet"
- output RxD_endofpacket; // one clock pulse, when no more data is received (RxD_idle is going high)
- output RxD_idle; // no data is being received
- // Baud generator (we use 8 times oversampling)
- parameter Baud8 = Baud*8;
- parameter Baud8GeneratorAccWidth = 16;
- wire [Baud8GeneratorAccWidth:0] Baud8GeneratorInc = ((Baud8<<(Baud8GeneratorAccWidth-7))+(ClkFrequency>>8))/(ClkFrequency>>7);
- reg [Baud8GeneratorAccWidth:0] Baud8GeneratorAcc;
- always @(posedge clk) Baud8GeneratorAcc <= Baud8GeneratorAcc[Baud8GeneratorAccWidth-1:0] + Baud8GeneratorInc;
- wire Baud8Tick = Baud8GeneratorAcc[Baud8GeneratorAccWidth];
- reg [1:0] RxD_sync_inv;
- always @(posedge clk) if(Baud8Tick) RxD_sync_inv <= {RxD_sync_inv[0], ~RxD};
- // we invert RxD, so that the idle becomes "0", to prevent a phantom character to be received at startup
- reg [1:0] RxD_cnt_inv;
- reg RxD_bit_inv;
- if(Baud8Tick)
- begin
- if( RxD_sync_inv[1] && RxD_cnt_inv!=2'b11) RxD_cnt_inv <= RxD_cnt_inv + 2'h1;
- else
- if(~RxD_sync_inv[1] && RxD_cnt_inv!=2'b00) RxD_cnt_inv <= RxD_cnt_inv - 2'h1;
- if(RxD_cnt_inv==2'b00) RxD_bit_inv <= 1'b0;
- else
- if(RxD_cnt_inv==2'b11) RxD_bit_inv <= 1'b1;
- end
- reg [3:0] state;
- reg [3:0] bit_spacing;
- // "next_bit" controls when the data sampling occurs
- // depending on how noisy the RxD is, different values might work better
- // with a clean connection, values from 8 to 11 work
- wire next_bit = (bit_spacing==4'd10);
- if(state==0)
- bit_spacing <= 4'b0000;
- else
- if(Baud8Tick)
- bit_spacing <= {bit_spacing[2:0] + 4'b0001} | {bit_spacing[3], 3'b000};
- if(Baud8Tick)
- case(state)
- 4'b0000: if(RxD_bit_inv) state <= 4'b1000; // start bit found?
- 4'b1000: if(next_bit) state <= 4'b1001; // bit 0
- 4'b1001: if(next_bit) state <= 4'b1010; // bit 1
- 4'b1010: if(next_bit) state <= 4'b1011; // bit 2
- 4'b1011: if(next_bit) state <= 4'b1100; // bit 3
- 4'b1100: if(next_bit) state <= 4'b1101; // bit 4
- 4'b1101: if(next_bit) state <= 4'b1110; // bit 5
- 4'b1110: if(next_bit) state <= 4'b1111; // bit 6
- 4'b1111: if(next_bit) state <= 4'b0001; // bit 7
- 4'b0001: if(next_bit) state <= 4'b0000; // stop bit
- default: state <= 4'b0000;
- endcase
- reg [7:0] RxD_data;
- if(Baud8Tick && next_bit && state[3]) RxD_data <= {~RxD_bit_inv, RxD_data[7:1]};
- reg RxD_data_ready, RxD_data_error;
- begin
- RxD_data_ready <= (Baud8Tick && next_bit && state==4'b0001 && ~RxD_bit_inv); // ready only if the stop bit is received
- RxD_data_error <= (Baud8Tick && next_bit && state==4'b0001 && RxD_bit_inv); // error if the stop bit is not received
- end
- reg [4:0] gap_count;
- always @(posedge clk) if (state!=0) gap_count<=5'h00; else if(Baud8Tick & ~gap_count[4]) gap_count <= gap_count + 5'h01;
- assign RxD_idle = gap_count[4];
- reg RxD_endofpacket; always @(posedge clk) RxD_endofpacket <= Baud8Tick & (gap_count==5'h0F);
- endmodule
这是我写的仿真代码
- `timescale 1ns / 1ps
- module async_receiver_tb ;
- wire RxD_endofpacket ;
- reg RxD ;
- reg clk ;
- wire RxD_idle ;
- wire [7:0] RxD_data ;
- wire RxD_data_ready;
- async_receiver
- DUT (
- .RxD_endofpacket (RxD_endofpacket ) ,
- .RxD (RxD ) ,
- .clk (clk ) ,
- .RxD_idle (RxD_idle ) ,
- .RxD_data (RxD_data ) ,
- .RxD_data_ready (RxD_data_ready ) );
- parameter CLOCK_20NS = 20;
- initial begin
- clk = 1'b0;
- forever
- # (CLOCK_20NS/2) clk = ~clk; // 20ns CLOCK
- end
- parameter BPS_9600 = 104140,
- SEND_DATA = 8'b1000_0011;
- integer i;
- initial begin
- RxD = 1'b1; //RESET rs232_rx
- # BPS_9600 RxD = 1'b0; // transmit START bit
- for (i=0;i<8;i=i+1) //transmit DATA byte
- # BPS_9600 RxD = SEND_DATA[i];
- # BPS_9600 RxD = 1'b0; // transmit STOP bit
- # BPS_9600 RxD = 1'b1; // bus IDLE
- end
- endmodule
