发表于 2013-12-7 15:59:00
换成ise10.1后,可以更新,但是出现错误 ERROR:iMPACT:585 - A problem may exist in the hardware configuration. 还请大侠救一救啊。。。
Welcome to iMPACT
iMPACT Version: 10.1
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Cable connection failed.
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Connecting to cable (Usb Port - USB21).
Driver file xusb_xlp.sys found.
Driver version: src=1029, dest=1029.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
Type = 0x0004.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1029.
File version of D:/Xilinx/10.1/ISE/data/xusb_xlp.hex = 1302.
Firmware hex file version = 1302.
Downloading D:/Xilinx/10.1/ISE/data/xusb_xlp.hex.
Downloaded firmware version = 1302.
Type = 0x0004.
ESN option: 00000000000000.
PLD file version = 0012h.
PLD version = FFFFh.
WARNING:iMPACT - Platform Cable USB firmware must be updated. This operation may take up to 10 seconds. Please
do not stop the process or disconnect the cable prior to completion. The cable STATUS LED will be RED for the duration
of the update process.
Updating the cable firmware...
Firmware update completed successfully.
PROGRESS_END - End Operation.
Elapsed time = 4 sec.
Attempting to identify devices in the boundary-scan chain configuration...// *** BATCH CMD : Identify
Identifying chain contents ....done.
Check that the cable, scan chain, and power connections are intact,
that the specified scan chain configuration matches the actual hardware, and
that the power supply is adequate and delivering the correct voltage.
Elapsed time = 0 sec.
// *** BATCH CMD : identifyMPM |
