下面这个程序,也没有看到对时钟的设置,是否能正常工作 ????
程序功能:MCU的片内ADC对P6.0端口的电压进行转换
将模拟电压值显示在1602液晶上。
测试说明:调节电位器W1的旋钮观察液晶显示数字变化。
#include <msp430x14x.h>
#include "cry1602.h"
#include "cry1602.c"
//typedef unsigned char uchar;
//typedef unsigned int uint;
#define Num_of_Results 32
uchar shuzi[] = {"0123456789."};
uchar tishi[] = {"The volt is:"};
static uint results[Num_of_Results]; //保存ADC转换结果的数组 // is not used for anything.
void Trans_val(uint Hex_Val);
/************************主函数****************************/
WDTCTL = WDTPW+WDTHOLD; //关闭看门狗
/*下面六行程序关闭所有的IO口*/
P1DIR = 0XFF;P1OUT = 0XFF;
P2DIR = 0XFF;P2OUT = 0XFF;
P3DIR = 0XFF;P3OUT = 0XFF;
P4DIR = 0XFF;P4OUT = 0XFF;
P5DIR = 0XFF;P5OUT = 0XFF;
P6DIR = 0XFF;P6OUT = 0XFF;
P6DIR |= BIT2;P6OUT |= BIT2; //关闭电平转换
P5DIR|=BIT5;P5OUT&=~BIT5; //关闭数码管显示
P6DIR|=BIT6;P6OUT&=~BIT6; //半闭数码管显示
P6DIR|=BIT5;P6OUT&=~BIT5; //半闭数码管显示
LcdReset(); //复位1602液晶
DispNChar(2,0,12,tishi); //显示提示信息
Disp1Char(11,1,'V'); //显示电压单位
P6SEL |= 0x01; // 使能ADC通道
ADC12CTL0 = ADC12ON+SHT0_8+MSC; // 打开ADC,设置采样时间
ADC12CTL1 = SHP+CONSEQ_2; // 使用采样定时器
ADC12IE = 0x01; // 使能ADC中断
ADC12CTL0 |= ENC; // 使能转换
ADC12CTL0 |= ADC12SC; // 开始转换
_EINT();
LPM0;
函数名称:ADC12ISR
功 能:ADC中断服务函数,在这里用多次平均的
计算P6.0口的模拟电压数值
参 数:无
返回值 :无
#pragma vector=ADC_VECTOR
__interrupt void ADC12ISR (void)
static uint index = 0;
results[index++] = ADC12MEM0; // Move results
if(index == Num_of_Results)
uchar i;
unsigned long sum = 0;
index = 0;
for(i = 0; i < Num_of_Results; i++)
sum += results[i];
sum >>= 5; //除以32
Trans_val(sum);
函数名称:Trans_val
功 能:将16进制ADC转换数据变换成三位10进制
真实的模拟电压数据,并在液晶上显示
参 数:Hex_Val--16进制数据
n--变换时的分母等于2的n次方
返回值 :无
unsigned long caltmp;
uint Curr_Volt;
uchar t1,i;
uchar ptr[4];
caltmp = Hex_Val;
caltmp = (caltmp << 5) + Hex_Val; //caltmp = Hex_Val * 33
caltmp = (caltmp << 3) + (caltmp << 1); //caltmp = caltmp * 10
Curr_Volt = caltmp >> 12; //Curr_Volt = caltmp / 2^n
ptr[0] = Curr_Volt / 100; //Hex->Dec变换
t1 = Curr_Volt - (ptr[0] * 100);
ptr[2] = t1 / 10;
ptr[3] = t1 - (ptr[2] * 10);
ptr[1] = 10; //shuzi表中第10位对应符号"."
//在液晶上显示变换后的结果
for(i = 0;i < 4;i++)
Disp1Char((6 + i),1,shuzi[ptr[i]]);
