Altium Designer 14.0.9.30380 在 win8 中文家庭版上安装注册成功,有图有真相!
【下载文件共 1.68G,安装后约占硬盘 6.5G。绿色版、免安装,文件日期是 2013.10.25,版本与官网同步】
另有各个版本的 Altium Designer (均已和谐)的下载地址
【请顺便 回复/顶 一下,怎么样?】
安装说明:
【其实也可不必按以下要求拷贝或移动源文件。以管理员权限执行7z自解压时,把目标路径指向相关的文件夹即可,解压后会在相关的文件夹内出现Altium的新文件夹。如果在解压时出现“无法读取xxx文件”等错误信息,应停止解压(需等待片刻),并重新以管理员权限执行之】
Altium Designer 14.0.9.30380 Full installation version of ru-board October 26, 2013 Description, system requirements, see the Hamster: http://techdocs.altium.com/
Not yet available offline Installer, use this set of Handmade Everything is designed for Windows 7/8, checked on: Windows 7-x 32, Windows 7 x 64-Windows x 64-Windows 8 8.1 to x 64.
Installation procedure:
1. If .NET Framework is 4 (or 5), install it: run dotNetFx40_Full_x86_x64.exe
2. Install TeighaX: run TeighaX_Setup_3.9.0.msi
3. copy the file _Program Files.exe in the folder
C:\Program Files 32-bit OS
C:\Program Files (x 86) 64-bit OS
and run it with administrator privileges (Run As Administrator)
4. copy the file _ProgramData.exe in the folder
%ProgramData% Windows 7/8
C:\Documents and Settings\All Users\Application Data\ Windows XP
and run it as an administrator.
Attention! After unpacking, check/change the permissions on the folders Altium, Altium 2004 Modify flag to Users group
5. copy the file _Users_Public_Documents.exe in the folder
C:\Users\Public\Documents Windows 7/8
C:\Documents and Settings\All Users\Documents\ Windows XP
and run it.
6. Implement the registry data file (DSH LMB file)
Altium_x32.reg 32-bit Windows 7/8
Altium_x64.reg 64-bit Windows 7/8
Altium_x32XP.reg 32-bit Windows XP
Altium_x64XP.reg 64-bit Windows XP
7. create a shortcut to run: Enter the folder with the program. By default, the
C:\Program Files\Altium\AD14\ 32-bit OS
C:\Program Files (x 86) \Altium\AD14\ 64-bit OS
Click LMB on the file DXP.exe Create a shortcut and place it where you like or Send to-> Desktop (create shotcut). A shortcut on the desktop.
Start the Altium Designer and shove any of 10-license
Altium 2013 ... Standalone.alf
from a folder
\Licenses
In the same folder are two licenses (each at 100 users) for both the primary and backup license servers.
File association data from Altium produce:
DXP-> > Preferences-File Types
Notes:
1. the procedure for installing the OS by default.
Program files (_Program Files.exe) and data (_Users_Public_Documents.exe) You can run anywhere.
You must correct two parameters see the appropriate registry data.
2. should work on HRûne, but I have not tested it and I am not going to.
3. before installation, make sure that you have installed Al′tiâ with
ID {2FA77EF5-441E-4960-B91C-BB9761F806FC}.
This of course is close to 0.
4. test run on Windows XP fails-Al′tij blunt does not run without issuing kakah.
The hamster was livere, that the same situation occurred and when running the installer.
So, HRûnovody, draw your own conclusions. Go ahead, can and will succeed.
Good luck
Evgeny972
Thanks to all the members of the ru-board who participated in the testing of the Assembly.
其它各版本下载(太爽了!均已和谐,进入后简单搜一下即可)
