额 这是第一次接触这个,我按照网上的教程配置了一个CPU点亮LED,以下是程序:
* "Hello World" example.
* This example prints 'Hello from Nios II' to the STDOUT stream. It runs on
* the Nios II 'standard', 'full_featured', 'fast', and 'low_cost' example
* designs. It runs with or without the MicroC/OS-II RTOS and requires a STDOUT
* device in your system's hardware.
* The memory footprint of this hosted application is ~69 kbytes by default
* using the standard reference design.
* For a reduced footprint version of this template, and an explanation of how
* to reduce the memory footprint for a given application, see the
* "small_hello_world" template.
#include "stdio.h"
#include "unistd.h"
#include "system.h"
#define _LED 1
typedef struct
unsigned long int DATA;
unsigned long int DIRECTION;
unsigned long int INTERRUPT_MASK;
unsigned long int EDGE_CAPTURE;
}PIO_STR;
#ifdef _LED
#define LED((PIO_STR *)PIO_LED_BASE)
int main()
int i;
for(i=0;i<8;i++){
LED->DATA=1<<i;
usleep(50000);
return 0;
但在编译时 提示 LED没有定义?求高手解答! |
