前段时间有网友关心百为LPC1788开发板的硬件信息,现在移植好了一个新的UBOOT,支持NAND,下面启动信息可以看出板的部分配置了
U-Boot 2011.06-00001-g6a982da-dirty (Oct 25 2013 - 17:09:39)
NXP LPC1788 Cortex-M3
DRAM: 64 MiB
Flash: 512 KiB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
uboot> tftp uImage
TFTP from server 192.168.1.104; our IP address is 192.168.1.10
Filename 'uImage'.
Load address: 0xa0000000
Loading: #################################################################
done
Bytes transferred = 1898304 (1cf740 hex)
uboot> bootm
## Booting kernel from Legacy Image at a0000000 ...
Image Name: Linux-2.6.33-arm1
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1898240 Bytes = 1.8 MiB
Load Address: a0008000
Entry Point: a0008001
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.33-arm1 (root@xiliang-desktop) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-189) ) #36 Tue Oct 29 23:48:44 PDT 2013
CPU: ARMv7-M Processor [412fc230] revision 0 (ARMv7M)
CPU: NO data cache, NO instruction cache
Machine: NXP LPC178x/7x
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd /dev/nfs nfsroot=192.168.1.200:/home/bw-1788/rootfs lpc178x_platform=ea-lpc1788 console=ttyS0,115200 ip=192.168.1.10:192.168.1.200:192.168.1.1:255.255.255.0:ea-lpc1788:eth0:off init=/sbin/init
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 63016k/63016k available, 2520k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0x00000000 - 0x00001000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0x00000000 - 0xffffffff (4095 MB)
lowmem : 0xa0000000 - 0xa4000000 ( 64 MB)
modules : 0xa0000000 - 0x01000000 (1552 MB)
.init : 0xa0008000 - 0xa001b000 ( 76 kB)
.text : 0xa001b000 - 0xa01a9000 (1592 kB)
.data : 0xa01be000 - 0xa01d7700 ( 102 kB)
Hierarchical RCU implementation.
NR_IRQS:41
Calibrating delay loop... 30.92 BogoMIPS (lpj=154624)
uart_init ***debug by zxl***eth_init ***debug by zxl***lpc178x_init ***debug by zxl***bio: create slab <bio-0> at 0
Switching to clocksource cm3-systick
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
ROMFS MTD (C) 2007 Red Hat, Inc.
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x4000c000 (irq = 5) is a 16550A
console [ttyS0] enabled
physmap platform flash device: 00400000 at 80000000
physmap-flash: Found 1 x16 devices at 0x0 in 16-bit bank
Support for command set 0701 not present
gen_probe: No supported Vendor Command Set found
physmap-flash physmap-flash: map_probe failed
lpc_net_drv_probe: ethernet address is not set or invalid, using random.
lpc_mii_bus: probed
eth0: using RMII interface
eth0: LPC mac at 0x20084000 irq 28
eth0: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=0:01, irq=-1)
mmci-pl18x dev:mmc0: DMA buffer: phy:10000000, virt:10000000
mmci-pl18x dev:mmc0: mmc0: MMCI rev 0 cfg 00 at 0x00000000400c0000 irq 29,-1
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
TCP cubic registered
NET: Registered protocol family 17
IP-Config: Complete:
device=eth0, addr=192.168.1.10, mask=255.255.255.0, gw=192.168.1.1,
host=ea-lpc1788, domain=, nis-domain=(none),
bootserver=192.168.1.200, rootserver=192.168.1.200, rootpath=
Looking up port of RPC 100003/2 on 192.168.1.200
Looking up port of RPC 100005/1 on 192.168.1.200
VFS: Mounted root (nfs filesystem) on device 0:11.
Freeing init memory: 76K
init started: BusyBox v1.17.0 (2013-10-29 16:56:03 PDT)
starting pid 27, tty '': '/etc/init.d/rcS'
starting pid 32, tty '': '/bin/hush -i'
