最近忙乎一些信号处理的程序,用CCS4.13,下载器是SEED-XDS560PLUS,安装好4.13的驱动后一切正常。但是在调试过程中就不能停止程序,出现以下错误提示:
C55xx: Trouble Halting Target CPU: Error 0x00000022/-2130 Error during: Memory, Execution, Cannot access memory address at 0x00000400
C55xx: Trouble Halting Target CPU: Error 0x80000022/-1144 Fatal Error during: Memory, Execution, The memory at 0x00000400 continually indicated it was 'not
ready' The emulator was unable to regain control of the processor. The processor must be reset.
C55xx: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended
that you reset the emulator before you connect and reload your program before you continue debugging
很奇怪。我去TI官网看了一些解释,说是驱动没安装好。我是以管理员身份运行的驱动安装程序,重启电脑后显示设备可用,也看到了驱动正常。前天还用的好好的,可以随意Halt,自从我把CCS3.3的程序导入4.13版本后就出现这种情况,好苦恼,求大神指点,感激不尽。 |
