发表于 2013-10-30 14:02:43
用什么IDE都无所谓的,都是 code. 直接操作寄存器就好。我可能比较忙,不一定赶出来
我给你贴下Lib的代码吧:gpio.c- /******************************************************************************
- #include "gpio.h"
- * Local variables
- * Local function prototypes
- * Local functions
- * Global functions
- * define GPIO APIs
- *//*! @addtogroup gpio_api_list
- * @brief Initialize the GPIO registers to the default reset values.
- * @param[in] pGPIO Pointer to GPIO module, can be GPIOA/GPIOB.
- * @return none
- * @ Pass/ Fail criteria: none
- void GPIO_DeInit(GPIO_Type *pGPIO)
- /* Sanity check */
- #if defined(CPU_KE02)
- ASSERT((pGPIO == GPIOA) || (pGPIO == GPIOB));
- #endif
- #if defined(CPU_KE04)
- ASSERT(pGPIO == GPIOA);
- #endif
- #if defined(CPU_KE06)
- ASSERT((pGPIO == GPIOA) || (pGPIO == GPIOB) || (pGPIO == GPIOC));
- #endif
- pGPIO->PCOR = 0x00000000; /* Port Clear Output Register */
- pGPIO->PDDR = 0x00000000; /* Port Data Direction */
- //pGPIO->PDIR = 0x00000000; /* Port Data Input Register */
- pGPIO->PDOR = 0x00000000; /* Port Data Output Register */
- pGPIO->PIDR = 0xFFFFFFFF; /* Port Input Disable Register */
- pGPIO->PSOR = 0x00000000; /* Port Set Output Register */
- pGPIO->PTOR = 0x00000000; /* Port Toggle Output Register */
- * @brief Initialize GPIO pins which are specified by u32PinMask
- * @param[in] u32PinMask GPIO pin mask need to be set
- * @param[in] sGpioType pin attribute
- * @return none
- * @Note
- * . High-current drive function is disabled, if the pin is configured as an input
- * . Internal pullup is disabled if the pin is configured as an output
- void GPIO_Init(GPIO_Type *pGPIO, uint32_t u32PinMask, GPIO_PinConfigType sGpioType)
- #endif
- #endif
- #endif
- /* Config GPIO for Input or Output */
- if ((sGpioType == GPIO_PinOutput) || (sGpioType == GPIO_PinOutput_HighCurrent))
- pGPIO->PDDR |= u32PinMask; /* Enable Port Data Direction Register */
- pGPIO->PIDR |= u32PinMask; /* Set Port Input Disable Register */
- else if ((sGpioType == GPIO_PinInput) || (sGpioType == GPIO_PinInput_InternalPullup))
- pGPIO->PDDR &= ~u32PinMask; /* Disable Port Data Direction Register */
- pGPIO->PIDR &= ~u32PinMask; /* Clear Port Input Disable Register */
- /* Config PORT Pull select for GPIO */
- switch((uint32_t)pGPIO)
- case GPIOA_BASE:
- (sGpioType == GPIO_PinInput_InternalPullup)?(PORT->PUEL |= u32PinMask):(PORT->PUEL &= ~u32PinMask);
- break;
- case GPIOB_BASE:
- (sGpioType == GPIO_PinInput_InternalPullup)?(PORT->PUEH |= u32PinMask):(PORT->PUEH &= ~u32PinMask);
- break;
- default:
- break;
- #endif
- case GPIOA_BASE:
- break;
- default:
- break;
- #endif
- case GPIOA_BASE:
- (sGpioType == GPIO_PinInput_InternalPullup)?(PORT->PUE0 |= u32PinMask):(PORT->PUE0 &= ~u32PinMask);
- break;
- case GPIOB_BASE:
- (sGpioType == GPIO_PinInput_InternalPullup)?(PORT->PUE1 |= u32PinMask):(PORT->PUE1 &= ~u32PinMask);
- break;
- case GPIOC_BASE:
- (sGpioType == GPIO_PinInput_InternalPullup)?(PORT->PUE2 |= u32PinMask):(PORT->PUE2 &= ~u32PinMask);
- break;
- default:
- break;
- #endif
- /* Config PORT GPIO_PinOutput_HighCurrent for GPIO */
- if (u32PinMask & GPIO_PTC5_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTC5_MASK;
- if (u32PinMask & GPIO_PTC1_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTC1_MASK;
- if (u32PinMask & GPIO_PTB5_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTB5_MASK;
- #endif
- #if defined(CPU_KE02) | defined(CPU_KE06)
- if (pGPIO == GPIOA)
- if (u32PinMask & GPIO_PTB4_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTB4_MASK;
- if (u32PinMask & GPIO_PTD0_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTD0_MASK;
- if (u32PinMask & GPIO_PTD1_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTD1_MASK;
- if (pGPIO == GPIOB)
- if (u32PinMask & GPIO_PTE0_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTE0_MASK;
- if (u32PinMask & GPIO_PTE1_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTE1_MASK;
- if (u32PinMask & GPIO_PTH0_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTH0_MASK;
- if (u32PinMask & GPIO_PTH1_MASK)
- PORT->HDRVE |= PORT_HDRVE_PTH1_MASK;
- #endif
- * @brief Toggle the pins which are specified by u32PinMask
- * @param[in] u32PinMask Specify GPIO pin need to be toggled
- * @return none
- void GPIO_Toggle(GPIO_Type *pGPIO, uint32_t u32PinMask)
- #endif
- #endif
- #endif
- pGPIO->PTOR = u32PinMask; /* Toggle the pins specified by u32PinMask */
- * @brief Read input data from GPIO which is specified by pGPIO
- * @return GPIO input value unsigned int 32-bit
- uint32_t GPIO_Read(GPIO_Type *pGPIO)
- #endif
- #endif
- #endif
- return (pGPIO->PDIR); /* Read Port Data Input Register */
- * @brief Write output data to GPIO which is specified by pGPIO
- * @param[in] u32Value value to output
- * @return none
- void GPIO_Write(GPIO_Type *pGPIO, uint32_t u32Value)
- #endif
- #endif
- #endif
- pGPIO->PDOR = u32Value; /* Write Port Ouput Data Register */
- * @brief Initialize GPIO single pin which is specified by GPIO_Pin
- * @param[in] GPIO_Pin GPIO pin name, can be GPIO_PTA0,1 ...
- * @param[in] GPIO_PinConfig Config output or input
- * @return none
- void GPIO_PinInit(GPIO_PinType GPIO_Pin, GPIO_PinConfigType GPIO_PinConfig)
- ASSERT(GPIO_Pin <= GPIO_PTI7);
- /* Config GPIO and pull select*/
- if (GPIO_Pin < GPIO_PTE0)
- switch (GPIO_PinConfig)
- case GPIO_PinOutput:
- GPIOA->PDDR |= (1<<GPIO_Pin); /* Enable Port Data Direction Register */
- GPIOA->PIDR |= (1<<GPIO_Pin); /* Set Port Input Disable Register */
- PORT->PUEL &= ~(1<<GPIO_Pin); /* Disable Pullup */
- break;
- case GPIO_PinInput:
- GPIOA->PDDR &= ~(1<<GPIO_Pin); /* Disable Port Data Direction Register */
- GPIOA->PIDR &= ~(1<<GPIO_Pin); /* Clear Port Input Disable Register */
- break;
- case GPIO_PinInput_InternalPullup:
- PORT->PUEL |= (1<<GPIO_Pin); /* Enable Pullup */
- break;
- case GPIO_PinOutput_HighCurrent:
- break;
- else if (GPIO_Pin < GPIO_PTI0)
- GPIO_Pin = (GPIO_PinType)(GPIO_Pin - 32);
- GPIOB->PDDR |= (1<<GPIO_Pin); /* Enable Port Data Direction Register */
- GPIOB->PIDR |= (1<<GPIO_Pin); /* Set Port Input Disable Register */
- PORT->PUEH &= ~(1<<GPIO_Pin); /* Disable Pullup */
- break;
- GPIOB->PDDR &= ~(1<<GPIO_Pin); /* Disable Port Data Direction Register */
- GPIOB->PIDR &= ~(1<<GPIO_Pin); /* Clear Port Input Disable Register */
- break;
- PORT->PUEH |= (1<<GPIO_Pin); /* Enable Pullup */
- break;
- break;
- #endif
- break;
- break;
- break;
- break;
- #endif
- PORT->PUE0 &= ~(1<<GPIO_Pin); /* Disable Pullup */
- break;
- break;
- PORT->PUE0 |= (1<<GPIO_Pin); /* Enable Pullup */
- break;
- break;
- PORT->PUE1 &= ~(1<<GPIO_Pin); /* Disable Pullup */
- break;
- break;
- PORT->PUE1 |= (1<<GPIO_Pin); /* Enable Pullup */
- break;
- break;
- else
- GPIO_Pin = (GPIO_PinType)(GPIO_Pin - 64);
- GPIOC->PDDR |= (1<<GPIO_Pin); /* Enable Port Data Direction Register */
- GPIOC->PIDR |= (1<<GPIO_Pin); /* Set Port Input Disable Register */
- PORT->PUE2 &= ~(1<<GPIO_Pin); /* Disable Pullup */
- break;
- GPIOC->PDDR &= ~(1<<GPIO_Pin); /* Disable Port Data Direction Register */
- GPIOC->PIDR &= ~(1<<GPIO_Pin); /* Clear Port Input Disable Register */
- break;
- PORT->PUE2 |= (1<<GPIO_Pin); /* Enable Pullup */
- break;
- break;
- #endif
- /* Config GPIO HDRV */
- if(GPIO_PinConfig == GPIO_PinOutput_HighCurrent)
- switch (GPIO_Pin)
- case GPIO_PTB5:
- break;
- case GPIO_PTC1:
- break;
- case GPIO_PTC5:
- break;
- default:
- break;
- #endif
- #if defined(CPU_KE06) | defined(CPU_KE02)
- switch (GPIO_Pin)
- case GPIO_PTB4:
- break;
- case GPIO_PTB5:
- break;
- case GPIO_PTD0:
- break;
- case GPIO_PTD1:
- break;
- case GPIO_PTE0:
- break;
- case GPIO_PTE1:
- break;
- case GPIO_PTH0:
- break;
- case GPIO_PTH1:
- break;
- default:
- break;
- #endif
- * @brief Toggle GPIO single pin which is specified by GPIO_Pin
- * @return none
- void GPIO_PinToggle(GPIO_PinType GPIO_Pin)
- /* PTA0-7, PTB0-7, PTC0-7, PTD0-7 */
- GPIOA->PTOR = (1<<GPIO_Pin);
- #if !defined(CPU_KE04)
- else
- /* PTE0-7, PTF0-7, PTH0-7, PTI0-7 */
- GPIO_Pin = (GPIO_PinType)(GPIO_Pin - GPIO_PTE0);
- GPIOB->PTOR = (1<<GPIO_Pin);
- #endif
- * @brief Set GPIO single pin which is specified by GPIO_Pin
- * @return none
- void GPIO_PinSet(GPIO_PinType GPIO_Pin)
- GPIOA->PSOR = (1<<GPIO_Pin);
- else
- GPIOB->PSOR = (1<<GPIO_Pin);
- #endif
- * @brief Clear GPIO single pin which is specified by GPIO_Pin
- * @return none
- void GPIO_PinClear(GPIO_PinType GPIO_Pin)
- GPIOA->PCOR = (1<<GPIO_Pin);
- else
- GPIOB->PCOR = (1<<GPIO_Pin);
- #endif
- /*! @} End of gpio_api_list */
复制代码 gpio.h- /******************************************************************************
- #ifndef _GPIO_H_
- #define _GPIO_H_
- #ifdef __cplusplus
- extern "C" {
- #endif
- #include "common.h"
- #include "stdint.h"
- *define gpio pin name
- *//*! @addtogroup gpio_pin_name_list
- typedef enum
- /* in GPIOA register */
- GPIO_PTA0 = 0, /*!< GPIO Pin PTA0 */
- GPIO_PTA1, /*!< GPIO Pin PTA1 */
- GPIO_PTA2, /*!< GPIO Pin PTA2 */
- GPIO_PTA3, /*!< GPIO Pin PTA3 */
- GPIO_PTA4, /*!< GPIO Pin PTA4 */
- GPIO_PTA5, /*!< GPIO Pin PTA5 */
- GPIO_PTA6, /*!< GPIO Pin PTA6 */
- GPIO_PTA7, /*!< GPIO Pin PTA7 */
- GPIO_PTB0, /*!< GPIO Pin PTB0 */
- GPIO_PTB1, /*!< GPIO Pin PTB1 */
- GPIO_PTB2, /*!< GPIO Pin PTB2 */
- GPIO_PTB3, /*!< GPIO Pin PTB3 */
- GPIO_PTB4, /*!< GPIO Pin PTB4 */
- GPIO_PTB5, /*!< GPIO Pin PTB5 */
- GPIO_PTB6, /*!< GPIO Pin PTB6 */
- GPIO_PTB7, /*!< GPIO Pin PTB7 */
- GPIO_PTC0, /*!< GPIO Pin PTC0 */
- GPIO_PTC1, /*!< GPIO Pin PTC1 */
- GPIO_PTC2, /*!< GPIO Pin PTC2 */
- GPIO_PTC3, /*!< GPIO Pin PTC3 */
- GPIO_PTC4, /*!< GPIO Pin PTC4 */
- GPIO_PTC5, /*!< GPIO Pin PTC5 */
- GPIO_PTC6, /*!< GPIO Pin PTC6 */
- GPIO_PTC7, /*!< GPIO Pin PTC7 */
- GPIO_PTD0, /*!< GPIO Pin PTD0 */
- GPIO_PTD1, /*!< GPIO Pin PTD1 */
- GPIO_PTD2, /*!< GPIO Pin PTD2 */
- GPIO_PTD3, /*!< GPIO Pin PTD3 */
- GPIO_PTD4, /*!< GPIO Pin PTD4 */
- GPIO_PTD5, /*!< GPIO Pin PTD5 */
- GPIO_PTD6, /*!< GPIO Pin PTD6 */
- GPIO_PTD7, /*!< GPIO Pin PTD7 */
- /* in GPIOB register */
- GPIO_PTE0, /*!< GPIO Pin PTE0 */
- GPIO_PTE1, /*!< GPIO Pin PTE1 */
- GPIO_PTE2, /*!< GPIO Pin PTE2 */
- GPIO_PTE3, /*!< GPIO Pin PTE3 */
- GPIO_PTE4, /*!< GPIO Pin PTE4 */
- GPIO_PTE5, /*!< GPIO Pin PTE5 */
- GPIO_PTE6, /*!< GPIO Pin PTE6 */
- GPIO_PTE7, /*!< GPIO Pin PTE7 */
- GPIO_PTF0, /*!< GPIO Pin PTF0 */
- GPIO_PTF1, /*!< GPIO Pin PTF1 */
- GPIO_PTF2, /*!< GPIO Pin PTF2 */
- GPIO_PTF3, /*!< GPIO Pin PTF3 */
- GPIO_PTF4, /*!< GPIO Pin PTF4 */
- GPIO_PTF5, /*!< GPIO Pin PTF5 */
- GPIO_PTF6, /*!< GPIO Pin PTF6 */
- GPIO_PTF7, /*!< GPIO Pin PTF7 */
- GPIO_PTG0, /*!< GPIO Pin PTG0 */
- GPIO_PTG1, /*!< GPIO Pin PTG1 */
- GPIO_PTG2, /*!< GPIO Pin PTG2 */
- GPIO_PTG3, /*!< GPIO Pin PTG3 */
- GPIO_PTG4, /*!< GPIO Pin PTG4 */
- GPIO_PTG5, /*!< GPIO Pin PTG5 */
- GPIO_PTG6, /*!< GPIO Pin PTG6 */
- GPIO_PTG7, /*!< GPIO Pin PTG7 */
- GPIO_PTH0, /*!< GPIO Pin PTH0 */
- GPIO_PTH1, /*!< GPIO Pin PTH1 */
- GPIO_PTH2, /*!< GPIO Pin PTH2 */
- GPIO_PTH3, /*!< GPIO Pin PTH3 */
- GPIO_PTH4, /*!< GPIO Pin PTH4 */
- GPIO_PTH5, /*!< GPIO Pin PTH5 */
- GPIO_PTH6, /*!< GPIO Pin PTH6 */
- GPIO_PTH7, /*!< GPIO Pin PTH7 */
- /* the following pins are not in KE02 */
- GPIO_PTI0, /*!< GPIO Pin PTI0 */
- GPIO_PTI1, /*!< GPIO Pin PTI1 */
- GPIO_PTI2, /*!< GPIO Pin PTI2 */
- GPIO_PTI3, /*!< GPIO Pin PTI3 */
- GPIO_PTI4, /*!< GPIO Pin PTI4 */
- GPIO_PTI5, /*!< GPIO Pin PTI5 */
- GPIO_PTI6, /*!< GPIO Pin PTI6 */
- GPIO_PTI7, /*!< GPIO Pin PTI7 */
- } GPIO_PinType;
- /*! @} End of gpio_pin_name_list */
- *define gpio pin mask
- *//*! @addtogroup gpio_pin_mask_list
- typedef enum
- GPIO_PTA0_MASK = (1<<0), /*!< GPIO Pin PTA0 bit mask */
- GPIO_PTA1_MASK = (1<<1), /*!< GPIO Pin PTA1 bit mask */
- GPIO_PTA2_MASK = (1<<2), /*!< GPIO Pin PTA2 bit mask */
- GPIO_PTA3_MASK = (1<<3), /*!< GPIO Pin PTA3 bit mask */
- GPIO_PTA4_MASK = (1<<4), /*!< GPIO Pin PTA4 bit mask */
- GPIO_PTA5_MASK = (1<<5), /*!< GPIO Pin PTA5 bit mask */
- GPIO_PTA6_MASK = (1<<6), /*!< GPIO Pin PTA6 bit mask */
- GPIO_PTA7_MASK = (1<<7), /*!< GPIO Pin PTA7 bit mask */
- GPIO_PTB0_MASK = (1<<8), /*!< GPIO Pin PTB0 bit mask */
- GPIO_PTB1_MASK = (1<<9), /*!< GPIO Pin PTB1 bit mask */
- GPIO_PTB2_MASK = (1<<10), /*!< GPIO Pin PTB2 bit mask */
- GPIO_PTB3_MASK = (1<<11), /*!< GPIO Pin PTB3 bit mask */
- GPIO_PTB4_MASK = (1<<12), /*!< GPIO Pin PTB4 bit mask */
- GPIO_PTB5_MASK = (1<<13), /*!< GPIO Pin PTB5 bit mask */
- GPIO_PTB6_MASK = (1<<14), /*!< GPIO Pin PTB6 bit mask */
- GPIO_PTB7_MASK = (1<<15), /*!< GPIO Pin PTB7 bit mask */
- GPIO_PTC0_MASK = (1<<16), /*!< GPIO Pin PTC0 bit mask */
- GPIO_PTC1_MASK = (1<<17), /*!< GPIO Pin PTC1 bit mask */
- GPIO_PTC2_MASK = (1<<18), /*!< GPIO Pin PTC2 bit mask */
- GPIO_PTC3_MASK = (1<<19), /*!< GPIO Pin PTC3 bit mask */
- GPIO_PTC4_MASK = (1<<20), /*!< GPIO Pin PTC4 bit mask */
- GPIO_PTC5_MASK = (1<<21), /*!< GPIO Pin PTC5 bit mask */
- GPIO_PTC6_MASK = (1<<22), /*!< GPIO Pin PTC6 bit mask */
- GPIO_PTC7_MASK = (1<<23), /*!< GPIO Pin PTC7 bit mask */
- GPIO_PTD0_MASK = (1<<24), /*!< GPIO Pin PTD0 bit mask */
- GPIO_PTD1_MASK = (1<<25), /*!< GPIO Pin PTD1 bit mask */
- GPIO_PTD2_MASK = (1<<26), /*!< GPIO Pin PTD2 bit mask */
- GPIO_PTD3_MASK = (1<<27), /*!< GPIO Pin PTD3 bit mask */
- GPIO_PTD4_MASK = (1<<28), /*!< GPIO Pin PTD4 bit mask */
- GPIO_PTD5_MASK = (1<<29), /*!< GPIO Pin PTD5 bit mask */
- GPIO_PTD6_MASK = (1<<30), /*!< GPIO Pin PTD6 bit mask */
- GPIO_PTD7_MASK = (1<<31), /*!< GPIO Pin PTD7 bit mask */
- GPIO_PTE0_MASK = (1<<0), /*!< GPIO Pin PTE0 bit mask */
- GPIO_PTE1_MASK = (1<<1), /*!< GPIO Pin PTE1 bit mask */
- GPIO_PTE2_MASK = (1<<2), /*!< GPIO Pin PTE2 bit mask */
- GPIO_PTE3_MASK = (1<<3), /*!< GPIO Pin PTE3 bit mask */
- GPIO_PTE4_MASK = (1<<4), /*!< GPIO Pin PTE4 bit mask */
- GPIO_PTE5_MASK = (1<<5), /*!< GPIO Pin PTE5 bit mask */
- GPIO_PTE6_MASK = (1<<6), /*!< GPIO Pin PTE6 bit mask */
- GPIO_PTE7_MASK = (1<<7), /*!< GPIO Pin PTE7 bit mask */
- GPIO_PTF0_MASK = (1<<8), /*!< GPIO Pin PTF0 bit mask */
- GPIO_PTF1_MASK = (1<<9), /*!< GPIO Pin PTF1 bit mask */
- GPIO_PTF2_MASK = (1<<10), /*!< GPIO Pin PTF2 bit mask */
- GPIO_PTF3_MASK = (1<<11), /*!< GPIO Pin PTF3 bit mask */
- GPIO_PTF4_MASK = (1<<12), /*!< GPIO Pin PTF4 bit mask */
- GPIO_PTF5_MASK = (1<<13), /*!< GPIO Pin PTF5 bit mask */
- GPIO_PTF6_MASK = (1<<14), /*!< GPIO Pin PTF6 bit mask */
- GPIO_PTF7_MASK = (1<<15), /*!< GPIO Pin PTF7 bit mask */
- GPIO_PTG0_MASK = (1<<16), /*!< GPIO Pin PTG0 bit mask */
- GPIO_PTG1_MASK = (1<<17), /*!< GPIO Pin PTG1 bit mask */
- GPIO_PTG2_MASK = (1<<18), /*!< GPIO Pin PTG2 bit mask */
- GPIO_PTG3_MASK = (1<<19), /*!< GPIO Pin PTG3 bit mask */
- GPIO_PTG4_MASK = (1<<20), /*!< GPIO Pin PTG4 bit mask */
- GPIO_PTG5_MASK = (1<<21), /*!< GPIO Pin PTG5 bit mask */
- GPIO_PTG6_MASK = (1<<22), /*!< GPIO Pin PTG6 bit mask */
- GPIO_PTG7_MASK = (1<<23), /*!< GPIO Pin PTG7 bit mask */
- GPIO_PTH0_MASK = (1<<24), /*!< GPIO Pin PTH0 bit mask */
- GPIO_PTH1_MASK = (1<<25), /*!< GPIO Pin PTH1 bit mask */
- GPIO_PTH2_MASK = (1<<26), /*!< GPIO Pin PTH2 bit mask */
- GPIO_PTH3_MASK = (1<<27), /*!< GPIO Pin PTH3 bit mask */
- GPIO_PTH4_MASK = (1<<28), /*!< GPIO Pin PTH4 bit mask */
- GPIO_PTH5_MASK = (1<<29), /*!< GPIO Pin PTH5 bit mask */
- GPIO_PTH6_MASK = (1<<30), /*!< GPIO Pin PTH6 bit mask */
- GPIO_PTH7_MASK = (1<<31), /*!< GPIO Pin PTH7 bit mask */
- } GPIO_PinMaskType;
- /*! @} End of gpio_pin_mask_list */
- *define gpio pin config type
- *//*! @addtogroup gpio_pin_config_type_list
- * Only PTH1/0, PTE1/0, PTD1/0, PTB5/4 support Hight-current Drive.
- typedef enum
- GPIO_PinOutput = 0, /*!< set pin as outout */
- GPIO_PinInput, /*!< set pin as input */
- GPIO_PinInput_InternalPullup, /*!< set internal pullup for input pin */
- GPIO_PinOutput_HighCurrent, /*!< set high drive for output pin */
- } GPIO_PinConfigType;
- /*! @} End of gpio_pin_config_type_list */
- * @brief Toggle the pins which are specified by u32PinMask in single cycle.
- * @param[in] pGPIO Pointer to GPIO module, can be FGPIOA/FGPIOB.
- * @return none
- __STATIC_INLINE void FGPIO_Toggle(FGPIO_Type *pFGPIO, uint32_t u32PinMask)
- pFGPIO->PTOR = u32PinMask; /* Toggle the pins specified by u32PinMask */
- * @brief Read input data from GPIO which is specified by pGPIO in single cycle.
- __STATIC_INLINE uint32_t FGPIO_Read(FGPIO_Type *pFGPIO)
- return (pFGPIO->PDIR); /* Read Port Data Input Register */
- * @brief Write output data to GPIO which is specified by pGPIO in single cycle.
- * @return none
- __STATIC_INLINE void FGPIO_Write(FGPIO_Type *pFGPIO, uint32_t u32Value)
- pFGPIO->PDOR = u32Value; /* Write Port Ouput Data Register */
- void GPIO_DeInit(GPIO_Type *pGPIO);
- void GPIO_Init(GPIO_Type *pGPIO, uint32_t u32PinMask, GPIO_PinConfigType sGpioType);
- void GPIO_Toggle(GPIO_Type *pGPIO, uint32_t u32PinMask);
- uint32_t GPIO_Read(GPIO_Type *pGPIO);
- void GPIO_Write(GPIO_Type *pGPIO, uint32_t u32Value);
- void GPIO_PinInit(GPIO_PinType GPIO_Pin, GPIO_PinConfigType GPIO_PinConfig);
- void GPIO_PinToggle(GPIO_PinType GPIO_Pin);
- void GPIO_PinSet(GPIO_PinType GPIO_Pin);
- void GPIO_PinClear(GPIO_PinType GPIO_Pin);
- #endif
- #endif /* #ifndef _GPIO_H_ */
复制代码 |
