发表于 2013-10-21 09:00:53
楼主的芯片 不算最牛 看看这个芯片 8031内核的 俺不是来拍砖的。
Support H.264 baseline profile with maximum 1280x720 (720p) image resolution
Seamless interface with most CMOS and CCD Image Sensor
Support multiple-windowed auto focus (AF), auto white balance (AWB) and auto exposure (AE)
Built-in Face Detection Engine
Built-in headphone amlifier and AGC audio codec
Memory Support:
- Secure Digital (SD)
- Multimedia Memory Card (MMC)
Built-in USB 2.0 High Speed transceiver
Supports major LCD (incl. AU, Topoly) panels with flexible digital interface (8 bit)
Built-in TV encoder (NTSC/PAL) and DAC
Support HDMI transmitter interface (8 bit CCIR-656)
Battery-low voltage detector
Real Time Clock
128-pin LQFP
这个芯片 就是有点不好 要外挂 RAM DDR2的都是BGA的 DDR1 和SDRAM有贴片的。 |
