电路和程序都放上来,大家帮我看看,现在屏还是显示不了数据,只是背光亮了而已。
#include<reg52.h>
#include<intrins.h>
#define uint unsigned int
sbit bm=P1^0;
sbit cs=P1^1;
sbit cd=P1^2;
sbit rd=P1^3;//WR1
sbit wr=P1^4;//WR0
sbit rst=P1^5;
#define dport P2
void delay_us(uint us)
while(us--);
void delay_ms(uint ms)
uchar i;
while(ms--)
for(i=0;i<120;i++);
//void write(bit flag,uchar dat)
//{ cs=0;
//_nop_();
// cd=flag;
// _nop_();
// rd=0;
// wr=0;
// _nop_();
// dport=dat;
// _nop_();
//// _nop_();
// wr=1;
// rd=1;
// _nop_();
// cd=~flag;
// _nop_();
// cs=1;
cs=0;
cd=flag; //flag=1,write command;flag=0,write data
wr=0;
rd=1;
dport=dat;
wr=1;
void lcdscan(uchar dat1,uchar dat2)
uchar i,j;
write(0,0x60); //row address LSB
write(0,0x70); //row address MSB
write(0,0x00); //culomn address LSB
write(0,0x10); //culomn address MSB
for(j=0;j<160;j++)
for(i=0;i<40;i++)
if(j%2==0)
write(1,dat1);
write(1,dat1);
write(1,dat1);
write(1,dat2);
write(1,dat2);
write(1,dat2);
//void init()
//cs=0 ;
///*reset*/
//rst=0;
//delay_ms(2);//power on reset
//rst=1;
//delay_ms(200);
//write(0,0xe2);
//delay_ms(10); //delay(2000);
//write(0,0x2b);
//write(0,0xa0);
//write(0,0xeb); //set bias BR[1:0] 111010xx
//write(0,0xf1); //set com end CEN 11110001
//write(0,0x9f); //duty=1/160
//write(0,0x81); //set VLCD value
//write(0,0x45); //VLCD=(CV0+Cpm*pm)*(1+(T-25)*CT%)
//write(0,0xc4); //LCD mapping control LC[2:0]=100
//write(0,0x89); //set ram address control
//write(0,0xd1); //set color pattern=RGB
//write(0,0xd5); //set color mode=4k-color
//write(0,0xc8); //设置不当会有flicker
//write(0,0x18); //LCMCOMM=0x0018;
//write(0,0xa6); //inverse display: 0:darkest 15:lightest
////write(0,0xad); //set ON/OFF display enable
//write(0,0xaf);//set ON/OFF display enable G16
////set column addr: 0,0
//write(0,0x60);
//write(0,0x70);
////set row addr: 0,0
//write(0,0x10);
//write(0,0x00);
void init(void)
cs=0;
/*reset*/
rst=0;
delay_ms(2); //power on reset
rst=1;
delay_ms(200);
write(0,0xe2); //reset by command
delay_ms(2);
/*power control*/
write(0,0xe9); //Bias Ratio:1/10 bias
write(0,0x2b); //power control set as internal power
write(0,0x24); //set temperate compensation as 0%
write(0,0x81); //electronic potentionmeter
write(0,198);
/*display control*/
write(0,0xa4); //all pixel off
write(0,0xa6); //inverse display off
/*lcd control*/
write(0,0xc0); //19:partial display and MX disable,MY enable
write(0,0xa3); //line rate 15.2klps
write(0,0xd1); //rgb-rgb
write(0,0xd5); //4k color mode
write(0,0x84); //12:partial display control disable
/*n-line inversion*/
write(0,0xc8);
write(0,0x10); //enable NIV
/*com scan fuction*/
write(0,0xda); //enable FRC,PWM,LRM sequence
/*window*/
write(0,0xf4); //wpc0:column
write(0,0x25); //start from 130
write(0,0xf6); //wpc1
write(0,0x5A); //end:272
write(0,0xf5); //wpp0:row
write(0,0x00); //start from 0
write(0,0xf7); //wpp1
write(0,0x9F); //end 160
write(0,0xf8); //inside mode
write(0,0x89); //RAM control
write(0,0xad); //display on,select on/off mode.Green Enhance mode disable
/*scroll line*/
write(0,0x40); //low bit of scroll line
write(0,0x50); //high bit of scroll line
write(0,0xc4); //19,enable FLT and FLB
write(0,0x90); //14:FLT,FLB set
write(0,0x00);
/*partial display*/
write(0,0x84); //12,set partial display control:off
write(0,0xf1); //com end
write(0,0x9f); //160
write(0,0xf2); //display start
write(0,0); //0
write(0,0xf3); //display end
write(0,159); //160
void main()
bm=0;
rst=1;
delay_us(10);
init();
// write(0,0x84);
lcdscan(0xf0,0x0f);
delay_ms(1000);
write(0xff,0xff); //all pixel on
delay_ms(1500);
lcdscan(0xff,0x00); //横线
delay_ms(1000);
write(0,0x41); //scroll 1 line
delay_ms(1300);
write(0,0x40); //no scroll
lcdscan(0x0f,0x0f); //竖线
delay_ms(1000);
write(0,0xa7); //inverse display
delay_ms(1500);
write(0,0xa6);
