硬件:ATMEGA32U4,8MHZ
目标:通过CONTROL端口0,实现HID免驱通信
现上位机从GET REPORT接收到的数据是对的,经SET REPORT发给下位机数据不对。麻烦各位有经验的朋友看看什么问题。
代码如下:
static void USB_Read_Bytes(uint8 len_r , uint8 *pbuffp_r)
for (uint8 i=0;i<len_r;i++)
*(pbuffp_r+i) = Usb_read_byte();
static void USB_Write_Bytes(void)
for(uint8 i=0;i<len_w;i++)
Usb_write_byte(*(pbuffp_w + i));
Usb_send_control_in(); //UEINTX &= ~(1<<TXINI);
static void hid_set_report (void)
uint8 temp_len;
ZLP();
while(!(UEINTX & (1<<RXOUTI)));
if (USB_ControlRequest.wLength > sizeof(USB_HID_SET_BUFFER))
temp_len = sizeof(USB_HID_SET_BUFFER);
temp_len = (USB_ControlRequest.wLength & 0xFF);
USB_Read_Bytes(temp_len,USB_HID_SET_BUFFER);
Usb_ack_receive_out();//UEINTX &= ~(1<<RXOUTI)
ZLP();
static void hid_get_report(void)
if (USB_ControlRequest.wLength > sizeof(USB_HID_GET_BUFFER))
len_w = sizeof(USB_HID_GET_BUFFER);
len_w = (USB_ControlRequest.wLength & 0xFF);
pbuffp_w = USB_HID_GET_BUFFER;
USB_Write_Bytes();
static void usb_process_request(void)
USB_Read_Bytes(8,USB_READ_BUFFER);
USB_ControlRequest.bmRequestType = USB_READ_BUFFER[0];
USB_ControlRequest.bRequest = USB_READ_BUFFER[1];
USB_ControlRequest.wValue = USB_READ_BUFFER[3];
USB_ControlRequest.wValue = ((USB_ControlRequest.wValue << 8) | USB_READ_BUFFER[2]);
USB_ControlRequest.wIndex = USB_READ_BUFFER[5];
USB_ControlRequest.wIndex = ((USB_ControlRequest.wIndex << 8) | USB_READ_BUFFER[4]);
USB_ControlRequest.wLength = USB_READ_BUFFER[7];
USB_ControlRequest.wLength = ((USB_ControlRequest.wLength << 8) | USB_READ_BUFFER[6]);
Usb_ack_receive_setup(); //UEINTX &= ~(1<<RXSTPI)
if ((USB_ControlRequest.bmRequestType & 0x60) == Std_Requests)
switch (USB_ControlRequest.bRequest)
case GET_STATUS:
usb_get_status();
case SET_ADDRESS:
usb_set_address();
case GET_DESCRIPTOR:
usb_get_descriptor();
case GET_CONFIGURATION:
usb_get_configuration();
case CLEAR_FEATURE:
case SET_FEATURE:
case SET_DESCRIPTOR:
case SET_CONFIGURATION:
case GET_INTERFACE:
case SET_INTERFACE:
case SYNCH_FRAME:*/
default:
ZLP();
switch(USB_ControlRequest.bRequest)
case GET_REPORT:
hid_get_report();
case SET_REPORT:
hid_set_report();
/*case GET_IDLE:
case GET_PROTOCOL:
case SET_IDLE:
case SET_PROTOCOL:*/
default:
ZLP();
