这个是STC12c5a60S2单片机驱动的,picture.h、chinese.h、char.h里都是要显示的字符,问题出现在屏幕显示的都是花点,不然就是全白,是什么问题?- #include <reg52.h>
- #include"LCD_driver.h"
- #include"picture.h"
- #include"chinese.h"
- #include"char.h"
- uint colors[]=
- 0xf800,0x07e0,0x001f,0xffe0,0x0000,0x07ff,0xf81f,0xffff //颜色数据
- void LCD_Init(void)
- LCD_REST=1;
- delayms(5);
- LCD_REST=0;
- delayms(5);
- LCD_REST=1;
- delayms(5);
- LCD_CS =0; //打开片选使能
- //************* Start Initial Sequence **********//
- LCD_Write_COM(0x00,0xE5); LCD_Write_DATA(0x78,0xF0); // set SRAM internal timing 设置静态存储器内部定时
- LCD_Write_COM(0x00,0x01); LCD_Write_DATA(0x01,0x00); // set SS and SM bit
- LCD_Write_COM(0x00,0x02); LCD_Write_DATA(0x07,0x00); // set 1 line inversion 倒转
- LCD_Write_COM(0x00,0x03); LCD_Write_DATA(0x10,0x30); // set GRAM write direction and BGR=1.
- LCD_Write_COM(0x00,0x04); LCD_Write_DATA(0x00,0x00); // Resize register
- LCD_Write_COM(0x00,0x08); LCD_Write_DATA(0x02,0x07); // set the back porch and front porch
- LCD_Write_COM(0x00,0x09); LCD_Write_DATA(0x00,0x00); // set non-display area refresh cycle ISC[3:0]
- LCD_Write_COM(0x00,0x0A); LCD_Write_DATA(0x00,0x00); // FMARK function
- LCD_Write_COM(0x00,0x0C); LCD_Write_DATA(0x00,0x00); // RGB interface setting
- LCD_Write_COM(0x00,0x0D); LCD_Write_DATA(0x00,0x00); // Frame marker Position
- LCD_Write_COM(0x00,0x0F); LCD_Write_DATA(0x00,0x00); // RGB interface polarity
- //*************Power On sequence ****************//
- LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x00,0x00); // SAP, BT[3:0], AP, DSTB, SLP, STB
- LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x00,0x07); // DC1[2:0], DC0[2:0], VC[2:0]
- LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x00); // VREG1OUT voltage
- LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x00,0x00); // VDV[4:0] for VCOM amplitude
- LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x00,0x01);
- delayms(50); // Dis-charge capacitor power voltage
- LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x10,0x90); // 1490//SAP, BT[3:0], AP, DSTB, SLP, STB
- LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x02,0x27); // DC1[2:0], DC0[2:0], VC[2:0]
- delayms(50); // Delay 50ms
- LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x1F); //001C// Internal reference voltage= Vci;
- LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x15,0x00); //0x1000//1400 Set VDV[4:0] for VCOM amplitude 1A00
- LCD_Write_COM(0x00,0x29); LCD_Write_DATA(0x00,0x27); //0x0012 //001a Set VCM[5:0] for VCOMH //0x0025 0034
- LCD_Write_COM(0x00,0x2B); LCD_Write_DATA(0x00,0x0D); // Set Frame Rate 000C
- LCD_Write_COM(0x00,0x20); LCD_Write_DATA(0x00,0x00); // GRAM horizontal Address
- LCD_Write_COM(0x00,0x21); LCD_Write_DATA(0x00,0x00); // GRAM Vertical Address
- // ----------- Adjust the Gamma Curve ----------//
- LCD_Write_COM(0x00,0x30); LCD_Write_DATA(0x00,0x00);
- LCD_Write_COM(0x00,0x31); LCD_Write_DATA(0x07,0x07);
- LCD_Write_COM(0x00,0x32); LCD_Write_DATA(0x03,0x07);
- LCD_Write_COM(0x00,0x35); LCD_Write_DATA(0x02,0x00);
- LCD_Write_COM(0x00,0x36); LCD_Write_DATA(0x00,0x08);//0207
- LCD_Write_COM(0x00,0x37); LCD_Write_DATA(0x00,0x04);//0306
- LCD_Write_COM(0x00,0x38); LCD_Write_DATA(0x00,0x00);//0102
- LCD_Write_COM(0x00,0x39); LCD_Write_DATA(0x07,0x07);//0707
- LCD_Write_COM(0x00,0x3C); LCD_Write_DATA(0x00,0x02);//0702
- LCD_Write_COM(0x00,0x3D); LCD_Write_DATA(0x1D,0x04);//1604
- //------------------ Set GRAM area ---------------//
- LCD_Write_COM(0x00,0x50); LCD_Write_DATA(0x00,0x00); // Horizontal GRAM Start Address
- LCD_Write_COM(0x00,0x51); LCD_Write_DATA(0x00,0xEF); // Horizontal GRAM End Address
- LCD_Write_COM(0x00,0x52); LCD_Write_DATA(0x00,0x00); // Vertical GRAM Start Address
- LCD_Write_COM(0x00,0x53); LCD_Write_DATA(0x01,0x3F); // Vertical GRAM Start Address
- LCD_Write_COM(0x00,0x60); LCD_Write_DATA(0xA7,0x00); // Gate Scan Line
- LCD_Write_COM(0x00,0x61); LCD_Write_DATA(0x00,0x01); // NDL,VLE, REV
- LCD_Write_COM(0x00,0x6A); LCD_Write_DATA(0x00,0x00); // set scrolling line
- //-------------- Partial Display Control ---------//
- LCD_Write_COM(0x00,0x80); LCD_Write_DATA(0x00,0x00);
- LCD_Write_COM(0x00,0x81); LCD_Write_DATA(0x00,0x00);
- LCD_Write_COM(0x00,0x82); LCD_Write_DATA(0x00,0x00);
- LCD_Write_COM(0x00,0x83); LCD_Write_DATA(0x00,0x00);
- LCD_Write_COM(0x00,0x84); LCD_Write_DATA(0x00,0x00);
- LCD_Write_COM(0x00,0x85); LCD_Write_DATA(0x00,0x00);
- //-------------- Panel Control -------------------//
- LCD_Write_COM(0x00,0x90); LCD_Write_DATA(0x00,0x10);
- LCD_Write_COM(0x00,0x92); LCD_Write_DATA(0x06,0x00);
- LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x01,0x33); // 262K color and display ON
- LCD_CS =1; //关闭片选使能
- void delayms(int count) // /* X1ms */
- int i,j;
- for(i=0;i<count;i++)
- for(j=0;j<100;j++);
- #ifdef Bus_16 //条件编译-16位数据模式
- void LCD_Writ_Bus(char VH,char VL) //并行数据写入函数
- LCD_DataPortH=VH; //高位P1口
- LCD_DataPortL=VL; //低位P0口
- LCD_WR=0;
- LCD_WR=1;
- #else //条件编译-8位数据模式
- LCD_DataPortH=VH; //八位模式都用P0口送数据
- LCD_WR=0;
- LCD_WR=1;
- LCD_DataPortH=VL; //八位模式都用P0口送数据
- LCD_WR=0;
- LCD_WR=1;
- #endif
- void LCD_Write_COM(char VH,char VL) //发送命令
- LCD_RS=0;
- LCD_Writ_Bus(VH,VL);
- void LCD_Write_DATA(char VH,char VL) //发送数据
- LCD_RS=1;
- void Pant(char VH,char VL)
- int i,j;
- Address_set(0,0,239,319);
- for(i=0;i<320;i++)
- for (j=0;j<240;j++)
- LCD_Write_DATA(VH,VL);
- void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
- LCD_Write_COM(0x00,0x20);LCD_Write_DATA(x1>>8,x1); //设置X坐标位置
- LCD_Write_COM(0x00,0x21);LCD_Write_DATA(y1>>8,y1); //设置Y坐标位置
- LCD_Write_COM(0x00,0x50);LCD_Write_DATA(x1>>8,x1); //开始X
- LCD_Write_COM(0x00,0x52);LCD_Write_DATA(y1>>8,y1); //开始Y
- LCD_Write_COM(0x00,0x51);LCD_Write_DATA(x2>>8,x2); //结束X
- LCD_Write_COM(0x00,0x53);LCD_Write_DATA(y2>>8,y2); //结束Y
- LCD_Write_COM(0x00,0x22);
- 写汉字子函数
- void ChineseChar(uint x,uint y,int size,uint For_color,uint Bk_color ,char c)
- int e=0,i,j;
- int ed;
- uint ncols;
- uint nrows;
- uint nbytes;
- uchar *pfont;
- uchar *pchar;
- uchar *fonttable[]={(uchar *)hz16,(uchar *)hz24 , (uchar *)hz32};
- pfont=(uchar *)fonttable;
- if(size==0)
- ncols =16-1;
- nrows =16-1;
- nbytes =32; //(16*16)/8
- else
- if(size==1)
- ncols =24-1;
- nrows =24-1;
- nbytes =72; //(24*24)/8
- else
- if(size==2)
- ncols =32-1;
- nrows =32-1;
- nbytes =132; //(32*32)/8
- pchar=pfont + (nbytes*(c-1));
- Address_set(x, y, x+nrows,y+ncols);
- for(i=0;i<nbytes;i++)
- ed=*pchar++;
- if(size==0)
- if(i%2==0)
- e=8;
- else
- e=4;
- else
- e=8;
- for(j=0;j<e;j++)
- {// unsigned char temp;
- if((ed>>j)&0x01)
- //temp = For_color&0x00ff
- LCD_Write_DATA(For_color>>8 , For_color ); //textcolor
- else
- LCD_Write_DATA( Bk_color>>8 , Bk_color); //backcolor
- 字符显示子函数
- void LCD_ShowChar(uint x,uint y,uint For_color,uint Bk_color, char ch)
- uchar temp , Bytes;
- uchar pos,t;
- uint CHAR_W,CHAR_H;
- //CHAR_W = 8; //8*16
- //CHAR_H = 16;
- CHAR_W = 16; //16*24
- CHAR_H = 24;
- if(x>(LCD_SIZE_X-CHAR_W)||y>(LCD_SIZE_Y-CHAR_H))
- return;
- Address_set(x, y, x+CHAR_W-1, y+CHAR_H-1);
- ch = ch-32; //按照ASCII编码顺序的到相应字母的编码
- Bytes = (CHAR_W*CHAR_H)/8;
- for(pos=0;pos<Bytes;pos++) //CHAR_H (CHAR_W*CHAR_H)/8
- // temp= Font8x16[ch][pos];
- //temp= Font16x24[ch][pos];
- temp= Font16x24[ch][pos];
- for(t=0;t<8;t++) //CHAR_W
- if(temp&0x80)
- else
- LCD_Write_DATA(Bk_color>>8 , Bk_color ); //backcolor
- temp<<=1;
- 显示字符串子函数
- x,y:起点坐标
- *p:字符串起始地址
- void LCD_ShowString(uint x,uint y,uint For_color,uint Bk_color,char *p)
- while(*p!='\0')
- LCD_ShowChar(x,y,For_color,Bk_color,*p);
- // x+=8;
- x+=16;
- p++;
复制代码- main()
- //int i,j,k;
- LCD_Init(); //TFT初始化
- // Pant(0xff,0xff); //TFT清屏
- //Pant(0xf8,0x00); //红色
- //Pant(0X07,0xE0); //绿色
- Pant(0x00,0x1f); //蓝色
- ChineseChar(14+46,10,2,colors[2],colors[7],1);
- ChineseChar(46+46,10,2,colors[2],colors[7],2);
- ChineseChar(78+46,10,2,colors[2],colors[7],3);
- ChineseChar(110+46,10,2,colors[2],colors[7],4);
- LCD_ShowString(12,60,colors[0],colors[7],"-");
- ChineseChar(20,60,1,colors[0],colors[7],1); //带
- ChineseChar(44,60,1,colors[0],colors[7],2); //您
- ChineseChar(68,60,1,colors[0],colors[7],3); //进
- ChineseChar(92,60,1,colors[0],colors[7],4); //入
- ChineseChar(116,60,1,colors[0],colors[7],5); //单
- ChineseChar(140,60,1,colors[0],colors[7],6); //片
- ChineseChar(164,60,1,colors[0],colors[7],7); //机
- ChineseChar(188,60,1,colors[0],colors[7],8); //世
- ChineseChar(212,60,1,colors[0],colors[7],9); //界
- LCD_ShowString(0,90,colors[0],colors[5],"WWW.PRECHIN.com");
- ChineseChar(0,120,1,colors[4],colors[7],10);
- ChineseChar(24,120,1,colors[4],colors[7],11);
- ChineseChar(48,120,1,colors[6],colors[7],12);
- ChineseChar(72,120,1,colors[6],colors[7],13);
- ChineseChar(96,120,1,colors[2],colors[7],14);
- ChineseChar(120,120,1,colors[2],colors[7],15);
- LCD_ShowString(0,150,colors[7],colors[2],"www.PRECHIN.net");
- LCD_ShowString(12,180,colors[0],colors[7],"TELL:");
- LCD_ShowString(12,210,colors[2],colors[7],"0755-61190227");
- LCD_ShowString(0,240,colors[2],colors[7],"abcdefJhiJKLMNOP");
- LCD_ShowString(0,265,colors[2],colors[7],"pqrstuvwxyz!@#$");
- LCD_ShowString(0,290,colors[2],colors[7],"<>CDEF^&*()/,[]");
- while(1){}
复制代码 |
