//ICC-AVR application builder :
// Target : M16
// Crystal: 8.0000Mhz
#include <iom16v.h>
#include <macros.h>
//--------------------------------NRF24L01接口定义--------------------------------
//#define NRF24L01_MISO PB4 //输入0
#define Hign_24L01_MISO PORTA |= (1 << PA4)
#define Low_24L01_MISO PORTA &= ~(1 << PA4)
#define Read_24L01_MISO PINA & (1 << PA4)
//#define NRF24L01_MOSI PB2 //输出1
#define Hign_24L01_MOSI PORTA |= (1 << PA2)
#define Low_24L01_MOSI PORTA &= ~(1 << PA2)
#define Read_24L01_MOSI PINA & (1 << PA2)
//#define NRF24L01_CSN PB7 //输出1
#define Low_24L01_CSN PORTA &= ~(1 << PA7)
#define Hign_24L01_CSN PORTA |= (1 << PA7)
//#define NRF24L01_SCK PB6 //输出1
#define Hign_24L01_SCK PORTA |= (1 << PA6)
#define Low_24L01_SCK PORTA &= ~(1 << PA6)
#define Read_24L01_SCK PINA & (1 << PA6);
//#define NRF24L01_CE PB5 //输出1
#define Hign_24L01_CE PORTA |= (1 << PA5)
#define Low_24L01_CE PORTA &= ~(1 << PA5)
#define Read_24L01_CE PINA & (1 << PA5)
//#define NRF24L01_IRQ PB3 //输入
#define Hign_NRF24L01_IRQ PORTA |= (1 << PA3)
#define Low_NRF24L01_IRQ PORTA &= ~(1 << PA3)
#define Read_NRF24L01_IRQ PINA & (1 << PA3)
char TxBuf[32]=
{0
//0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08,
//0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,
//0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,
//0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32, //一次可以发送最多32个字节,每个字节8位
char sta,count,tf;
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH 5 // 5 uints TX address width
#define RX_ADR_WIDTH 5 // 5 uints RX address width
//#define TX_PLOAD_WIDTH 32 // 20 uints TX payload
//#define RX_PLOAD_WIDTH 32 // 20 uints TX payload
#define TX_PLOAD_WIDTH 16 // 20 uints TX payload
#define RX_PLOAD_WIDTH 16 // 20 uints TX payload
char TX_ADDRESS[TX_ADR_WIDTH]= {0x32,0x33,0x11,0x10,0x11}; //本地地址
char RX_ADDRESS[RX_ADR_WIDTH]= {0x32,0x33,0x11,0x10,0x11}; //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG 0x00 // 读寄存器指令
#define WRITE_REG 0x20 // 写寄存器指令
#define RD_RX_PLOAD 0x61 // 读取接收数据指令
#define WR_TX_PLOAD 0xA0 // 写待发数据指令
#define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令
#define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令
#define REUSE_TX_PL 0xE3 // 定义重复装载数据指令
#define NOP1 0xFF // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 寄存器第0位设置为0为发送模式
#define EN_AA 0x01 // 自动应答功能设置 0x01表示通道0自动应答模式
#define EN_RXADDR 0x02 // 可用信道设置
#define SETUP_AW 0x03 // 收发地址宽度设置
#define SETUP_RETR 0x04 // 自动重发功能设置
#define RF_CH 0x05 // 工作频率设置
#define RF_SETUP 0x06 // 发射速率、功耗功能设置
#define STATUS 0x07 // 状态寄存器
#define OBSERVE_TX 0x08 // 发送监测功能
#define CD 0x09 // 地址检测
#define RX_ADDR_P0 0x0A // 频道0接收数据地址
#define RX_ADDR_P1 0x0B // 频道1接收数据地址
#define RX_ADDR_P2 0x0C // 频道2接收数据地址
#define RX_ADDR_P3 0x0D // 频道3接收数据地址
#define RX_ADDR_P4 0x0E // 频道4接收数据地址
#define RX_ADDR_P5 0x0F // 频道5接收数据地址
#define TX_ADDR 0x10 // 发送地址寄存器
#define RX_PW_P0 0x11 // 接收频道0接收数据长度
#define RX_PW_P1 0x12 // 接收频道0接收数据长度
#define RX_PW_P2 0x13 // 接收频道0接收数据长度
#define RX_PW_P3 0x14 // 接收频道0接收数据长度
#define RX_PW_P4 0x15 // 接收频道0接收数据长度
#define RX_PW_P5 0x16 // 接收频道0接收数据长度
#define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置
void Delay(int s);
void inerDelay_us(char n);
void init_NRF24L01(void);
char SPI_RW(char data);
char SPI_Read(char reg);
char SPI_RW_Reg(char reg, char value);
char SPI_Read_Buf(char reg, char *pBuf, char uchars);
char SPI_Write_Buf(char reg, char *pBuf, char uchars);
void SetRX_Mode(void);
char nRF24L01_RxPacket(char* rx_buf);
void nRF24L01_TxPacket(char * tx_buf);
void StartUART(void);
void R_S_Byte(char R_Byte);
void display();
/*void Delay(unsigned int ms)
unsigned int i,j;
for(i=0;i<ms;i++)
for(j=0;j<1141;j++);
void Delay(int s)
unsigned int i;
for(i=0; i<s; i++);
for(i=0; i<s; i++);
/*函数:uint SPI_RW(uint uchar)
/*功能:NRF24L01的SPI写时序
char i,temp=0;
for(i=0;i<8;i++) // output 8-bit
if(data & 0x80)
Hign_24L01_MOSI ; // output 'uchar', MSB to MOSI
Low_24L01_MOSI;
data = (data << 1); // shift next bit into MSB..
temp<<=1;
Hign_24L01_SCK ; // Set SCK high..
//if(PINB&0x10)temp++; // capture current MISO bit**************************************************///*************
if(PINA&0x10)temp++;
Low_24L01_SCK; // ..then set SCK low again
return(temp); // return read uchar
/*函数:uchar SPI_Read(uchar reg)
/*功能:NRF24L01的SPI时序
char reg_val;
Low_24L01_CSN; // CSN low, initialize SPI communication...
SPI_RW(reg); // Select register to read from..
reg_val = SPI_RW(0); // ..then read registervalue
Hign_24L01_CSN; // CSN high, terminate SPI communication
return(reg_val); // return register value
/*功能:NRF24L01读写寄存器函数
char status;
Low_24L01_CSN; // CSN low, init SPI transaction
status = SPI_RW(reg); // select
SPI_RW(value); // ..and write value to it..
Hign_24L01_CSN; // CSN high again
return(status); // return nregisterRF24L01 status uchar
/*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数
int status1,uchar_ctr;
Low_24L01_CSN; // Set CSN low, init SPI tranaction
status1 = SPI_RW(reg); // Select register to write to and read status uchar
for(uchar_ctr=0;uchar_ctr<uchars;uchar_ctr++)
pBuf[uchar_ctr] = SPI_RW(0); //
Hign_24L01_CSN;
return(status1); // return nRF24L01 status uchar
/*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数
char status1,uchar_ctr;
Low_24L01_CSN; //SPI使能
for(uchar_ctr=0; uchar_ctr<uchars; uchar_ctr++) //
SPI_RW(*pBuf++);
Hign_24L01_CSN; //关闭SPI
return(status1); //
/*函数:void SetRX_Mode(void)
/*功能:数据接收配置
Low_24L01_CE;
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收
Hign_24L01_CE;
Delay(1000);//注意不能太小
/*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
/*功能:数据读取后放如rx_buf接收缓冲区中
char revale=0;
sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况
if(sta&0x40) // 判断是否接收到数据
Low_24L01_CE; //SPI使能
SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
revale =1; //读取数据完成标志
SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
return revale;
/*函数:void nRF24L01_TxPacket(char * tx_buf)
/*功能:发送 tx_buf中数据
Low_24L01_CE; //StandBy I模式
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送
Hign_24L01_CE; //置高CE,激发数据发送
Delay(600);
/*NRF24L01初始化
Low_24L01_CE; // chip enable
Hign_24L01_CSN; // Spi disable
Low_24L01_SCK; // Spi clock line init high
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21
SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致
SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0X04); //自动重发4次
SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为16字节
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收}
Delay(6000);
main()
char i,RxBuf[32];//接收缓冲区
MCUCSR |= 1 << JTD; //禁止JTAG接口
MCUCSR |= 1 << JTD; //需要连续两次操作才能被有效执行 使PC2-PC5口变正常io口使用
DDRA=0xe4;
//PORTC=0XFF;
//DDRA=0x1e;
//PORTA=0x00;
//PORTC=0xbf;
DDRD=0XFF;
PORTD=0;
init_NRF24L01();
/*while(1) //发射模块
if((PINC&BIT(3))==0)
TxBuf[0]=0xFE;
if((PINC&BIT(4))==0)
TxBuf[0]=0xFD;
if((PINC&BIT(5))==0)
TxBuf[0]=0xFB;
nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data
Delay(1000);
SPI_RW_Reg(WRITE_REG+STATUS,0XFF);
while(1) //接收模块
SetRX_Mode();
if(nRF24L01_RxPacket(RxBuf)) //判断是否收到数据
PORTD=RxBuf[0];
Delay(1000);
