如题。好多年了,今年从7.3升级到7.4了。
release note
- VERSION 7.4 *version-7.4* *version7.4*
- This section is about improvements made between version 7.3 and 7.4.
- This release has hundreds of bug fixes and there are a few new features. The
- most notable new features are:
- - New regexp engine |new-regexp-engine|
- - A more pythonic Python interface |better-python-interface|
- New regexp engine *new-regexp-engine*
- What is now called the "old" regexp engine uses a backtracking algorithm. It
- tries to match the pattern with the text in one way, and when that fails it
- goes back and tries another way. This works fine for simple patterns, but
- complex patterns can be very slow on longer text.
- The new engine uses a state machine. It tries all possible alternatives at
- the current character and stores the possible states of the pattern. This is
- a bit slower for simple patterns, but much faster for complex patterns and
- long text.
- Most notably, syntax highlighting for Javascript and XML files with long lines
- is now working fine. Previously Vim could get stuck.
- More information here: |two-engines|
- Better Python interface *better-python-interface*
- Added |python-bindeval| function. Unlike |python-eval| this one returns
- |python-Dictionary|, |python-List| and |python-Function| objects for
- dictionaries lists and functions respectively in place of their Python
- built-in equivalents (or None if we are talking about function references).
- For simple types this function returns Python built-in types and not only
- Python `str()` like |python-eval| does. On Python 3 it will return `bytes()`
- objects in place of `str()` ones avoiding possibility of UnicodeDecodeError.
- Interface of new objects mimics standard Python `dict()` and `list()`
- interfaces to some extent. Extent will be improved in the future.
- Added special |python-vars| objects also available for |python-buffer| and
- |python-window|. They ease access to VimL variables from Python.
- Now you no longer need to alter `sys.path` to import your module: special
- hooks are responsible for importing from {rtp}/python2, {rtp}/python3 and
- {rtp}/pythonx directories (for Python 2, Python 3 and both respectively).
- See |python-special-path|.
- Added possibility to work with |tabpage|s through |python-tabpage| object.
- Added automatic conversion of Vim errors and exceptions to Python
- exceptions.
- Changed the behavior of the |python-buffers| object: it now uses buffer numbers
- as keys in place of the index of the buffer in the internal buffer list.
- This should not break anything as the only way to get this index was
- iterating over |python-buffers|.
- Added |:pydo| and |:py3do| commands.
- Added the |pyeval()| and |py3eval()| functions.
- Now in all places which previously accepted `str()` objects, `str()` and
- `unicode()` (Python 2) or `bytes()` and `str()` (Python 3) are accepted.
- |python-window| has gained `.col` and `.row` attributes that are currently
- the only way to get internal window positions.
- Added or fixed support for `dir()` in Vim Python objects.
- Changed *changed-7.4*
- Old Python versions (鈮?.2) are no longer supported. Building with them did
- not work anyway.
- Options:
- Added ability to automatically save the selection into the system
- clipboard when using non-GUI version of Vim (autoselectplus in
- 'clipboard'). Also added ability to use the system clipboard as
- default register (previously only primary selection could be used).
- (Ivan Krasilnikov, Christian Brabandt, Bram Moolenaar)
- Added a special 'shiftwidth' value that makes 'sw' follow 'tabstop'.
- As indenting via 'indentexpr' became tricky |shiftwidth()| function
- was added. Also added equivalent special value to 'softtabstop'
- option. (Christian Brabandt, so8res)
- Show absolute number in number column when 'relativenumber' option is
- on. Now there are four combinations with 'number' and
- 'relativenumber'. (Christian Brabandt)
- Commands:
- |:diffoff| now saves the local values of some settings and restores
- them in place of blindly resetting them to the defaults. (Christian
- Brabandt)
- Other:
- Lua interface now also uses userdata binded to Vim structures. (Taro
- Muraoka, Luis Carvalho)
- glob() and autocommand patterns used to work with the undocumented
- "\{n,m\}" item from a regexp. "\{" is now used for a literal "{", as
- this is normal in shell file patterns. Now used "\\\{n,m\}" to get
- "\{n,m}" in the regexp pattern.
- Added *added-7.4*
- Various syntax, indent and other plugins were added.
- Added support for |Lists| and |Dictionaries| in |viminfo|. (Christian
- Brabandt)
- Functions:
- Bitwise functions: |and()|, |or()|, |invert()|, |xor()|.
- Added |luaeval()| function. (Taro Muraoka, Luis Carvalho)
- Added |sha256()| function. (Tyru, Hirohito Higashi)
- Added |wildmenumode()| function. (Christian Brabandt)
- Debugging functions: |screenattr()|, |screenchar()|, |screencol()|,
- |screenrow()|. (Simon Ruderich, Bram Moolenaar)
- Added ability to use |Dictionary-function|s for |sort()|ing, via
- optional third argument. (Nikolay Pavlov)
- Added special |expand()| argument that expands to the current line
- number.
- Made it possible to force |char2nr()| always give unicode codepoints
- regardless of current encoding. (Yasuhiro Matsumoto)
- Made it possible for functions generating file list generate |List|
- and not NL-separated string. (e.g. |glob()|, |expand()|) (Christian
- Brabandt)
- Functions that obtain variables from the specific window, tabpage or
- buffer scope dictionary can now return specified default value in
- place of empty string in case variable is not found. (|gettabvar()|,
- |getwinvar()|, |getbufvar()|) (Shougo Matsushita, Hirohito Higashi)
- Autocommands:
- Added |InsertCharPre| event launched before inserting character.
- (Jakson A. Aquino)
- Added |CompleteDone| event launched after finishing completion in
- insert mode. (idea by Florian Klein)
- Added |QuitPre| event launched when commands that can either close Vim
- or only some window(s) are launched.
- Added |TextChanged| and |TextChangedI| events launched when text is
- changed.
- Commands:
- |:syntime| command useful for debugging.
- Made it possible to remove all signs from the current buffer using
- |:sign-unplace|. (Christian Brabandt)
- Added |:language| autocompletion. (Dominique Pelle)
- Added more |:command-complete| completion types: |:behave| suboptions,
- color schemes, compilers, |:cscope| suboptions, files from 'path',
- |:history| suboptions, locale names, |:syntime| suboptions, user
- names. (Dominique Pelle)
- Added |:map-nowait| creating mapping which when having lhs that is the
- prefix of another mapping鈥檚 lhs will not allow Vim to wait for user to
- type more characters to resolve ambiguity, forcing Vim to take the
- shorter alternative: one with <nowait>.
- Options:
- Made it possible to ignore case when completing: 'wildignorecase'.
- Added ability to delete comment leader when using |J| by `j` flag in
- 'formatoptions' (|fo-table|). (Lech Lorens)
- Added ability to control indentation inside namespaces: |cino-N|.
- (Konstantin Lepa)
- Added ability to control alignment inside `if` condition separately
- from alignment inside function arguments: |cino-k|. (Lech Lorens)
- Other:
- Improved support for cmd.exe. (Ben Fritz, Bram Moolenaar)
- Added |v:windowid| variable containing current window number in GUI
- Vim. (Christian J. Robinson, Lech Lorens)
- Added rxvt-unicode and SGR mouse support. (Yiding Jia, Hayaki Saito)
- All changes in 7.4 *fixed-7.4*
- Patch 7.3.001
- Problem: When editing "src/main.c" and 'path' set to "./proto",
- ":find e<C-D" shows ./proto/eval.pro instead of eval.pro.
- Solution: Check for path separator when comparing names. (Nazri Ramliy)
- Files: src/misc1.c
- Patch 7.3.002
- Problem: ":find" completion doesn't work when halfway an environment
- variable. (Dominique Pelle)
- Solution: Only use in-path completion when expanding file names. (Nazri
- Ramliy)
- Files: src/ex_docmd.c
- Patch 7.3.003
- Problem: Crash with specific BufWritePost autocmd. (Peter Odding)
- Solution: Don't free the quickfix title twice. (Lech Lorens)
- Files: src/quickfix.c
- Patch 7.3.004
- Problem: Crash when using very long regexp. (Peter Odding)
- Solution: Reset reg_toolong. (Carlo Teubner)
- Files: src/regexp.c
- Patch 7.3.005
- Problem: Crash when using undotree(). (Christian Brabandt)
- Solution: Increase the list reference count. Add a test for undotree()
- (Lech Lorens)
- Files: src/eval.c, src/testdir/Makefile, src/testdir/test61.in
- Patch 7.3.006
- Problem: Can't build some multi-byte code with C89.
- Solution: Move code to after declarations. (Joachim Schmitz)
- Files: src/mbyte.c, src/spell.c
- Patch 7.3.007
- Problem: Python code defines global "buffer". Re-implements a grow-array.
- Solution: Use a grow-array instead of coding the same functionality. Handle
- out-of-memory situation properly.
- Files: src/if_py_both.h
- Patch 7.3.008
- Problem: 'cursorbind' is kept in places where 'scrollbind' is reset.
- Solution: Reset 'cursorbind'.
- Files: src/buffer.c, src/diff.c, src/ex_cmds.c, src/ex_cmds2.c,
- src/ex_docmd.c, src/ex_getln.c, src/if_cscope.c, src/macros.h,
- src/quickfix.c, src/search.c, src/tag.c, src/window.c
- Patch 7.3.009
- Problem: Win32: Crash on Windows when using a bad argument for strftime().
- (Christian Brabandt)
- Solution: Use the bad_param_handler(). (Mike Williams)
- Files: src/os_win32.c
- Patch 7.3.010
- Problem: Mac GUI: Missing break statements.
- Solution: Add the break statements. (Dominique Pelle)
- Files: src/gui_mac.c
- Patch 7.3.011
- Problem: X11 clipboard doesn't work in Athena/Motif GUI. First selection
- after a shell command doesn't work.
- Solution: When using the GUI use XtLastTimestampProcessed() instead of
- changing a property. (partly by Toni Ronkko)
- When executing a shell command disown the selection.
- Files: src/ui.c, src/os_unix.c
- Patch 7.3.012
- Problem: Problems building with MingW.
- Solution: Adjust the MingW makefiles. (Jon Maken)
- Files: src/Make_ming.mak, src/GvimExt/Make_ming.mak
- Patch 7.3.013
- Problem: Dynamic loading with Ruby doesn't work for 1.9.2.
- Solution: Handle rb_str2cstr differently. Also support dynamic loading on
- Unix. (Jon Maken)
- Files: src/if_ruby.c
- Patch 7.3.014
- Problem: Ending a line in a backslash inside an ":append" or ":insert"
- command in Ex mode doesn't work properly. (Ray Frush)
- Solution: Halve the number of backslashes, only insert a NUL after an odd
- number of backslashes.
- Files: src/ex_getln.c
- Patch 7.3.015
- Problem: Test is using error message that no longer exists.
- Solution: Change E106 to E121. (Dominique Pelle)
- Files: src/testdir/test49.vim
- Patch 7.3.016
- Problem: Netbeans doesn't work under Athena.
- Solution: Support Athena, just like Motif. (Xavier de Gaye)
- Files: runtime/doc/netbeans.txt, src/gui.c, src/main.c, src/netbeans.c
- Patch 7.3.017
- Problem: smatch reports errors.
- Solution: Fix the reported errors. (Dominique Pelle)
- Files: src/spell.c, src/syntax.c
- Patch 7.3.018 (after 7.3.012)
- Problem: Missing argument to windres in MingW makefiles.
- Solution: Add the argument that was wrapped in the patch. (Jon Maken)
- Patch 7.3.019
- Problem: ":nbstart" can fail silently.
- Solution: Give an error when netbeans is not supported by the GUI. (Xavier
- de Gaye)
- Files: src/netbeans.c
- Patch 7.3.020
- Problem: Cursor position wrong when joining multiple lines and
- 'formatoptions' contains "a". (Moshe Kamensky)
- Solution: Adjust cursor position for skipped indent. (Carlo Teubner)
- Files: src/ops.c, src/testdir/test68.in, src/testdir/test68.ok
- Patch 7.3.021
- Problem: Conflict for defining Boolean in Mac header files.
- Solution: Define NO_X11_INCLUDES. (Rainer Muller)
- Files: src/os_macosx.m, src/vim.h
- Patch 7.3.022
- Problem: When opening a new window the 'spellcapcheck' option is cleared.
- Solution: Copy the correct option value. (Christian Brabandt)
- Files: src/option.c
- Patch 7.3.023
- Problem: External program may hang when it tries to write to the tty.
- Solution: Don't close the slave tty until after the child exits. (Nikola
- Knezevic)
- Files: src/os_unix.c
- Patch 7.3.024
- Problem: Named signs do not use a negative number as intended.
- Solution: Fix the numbering of named signs. (Xavier de Gaye)
- Files: src/ex_cmds.c
- Patch 7.3.025
- Problem: ":mksession" does not square brackets escape file name properly.
- Solution: Improve escaping of file names. (partly by Peter Odding)
- Patch 7.3.026
- Problem: CTRL-] in a help file doesn't always work. (Tony Mechelynck)
- Solution: Don't escape special characters. (Carlo Teubner)
- Files: src/normal.c
- Patch 7.3.027
- Problem: Opening a file on a network share is very slow.
- Solution: When fixing file name case append "\*" to directory, server and
- network share names. (David Anderson, John Beckett)
- Patch 7.3.028 (after 7.3.024)
- Problem: Signs don't show up. (Charles Campbell)
- Solution: Don't use negative numbers. Also assign a number to signs that
- have a name of all digits to avoid using a sign number twice.
- Patch 7.3.029
- Problem: ":sort n" sorts lines without a number as number zero. (Beeyawned)
- Solution: Make lines without a number sort before lines with a number. Also
- fix sorting negative numbers.
- Files: src/ex_cmds.c, src/testdir/test57.in, src/testdir/test57.ok
- Patch 7.3.030
- Problem: Cannot store Dict and List in viminfo file.
- Solution: Add support for this. (Christian Brabandt)
- Files: runtime/doc/options.txt, src/eval.c, src/testdir/Make_amiga.mak,
- src/testdir/Make_dos.mak, src/testdir/Make_ming.mak,
- src/testdir/Make_os2.mak, src/testdir/Make_vms.mms,
- src/testdir/Makefile, src/testdir/main.aap, src/testdir/test74.in,
- src/testdir/test74.ok
- Patch 7.3.031
- Problem: Can't pass the X window ID to another application.
- Solution: Add v:windowid. (Christian J. Robinson, Lech Lorens)
- Files: runtime/doc/eval.txt, src/eval.c, src/gui.c, src/vim.h,
- src/os_unix.c
- Patch 7.3.032
- Problem: maparg() doesn't return the flags, such as <buffer>, <script>,
- <silent>. These are needed to save and restore a mapping.
- Solution: Improve maparg(). (also by Christian Brabandt)
- Files: runtime/doc/eval.txt, src/eval.c, src/getchar.c, src/gui_w48.c,
- src/message.c, src/proto/getchar.pro, src/proto/message.pro,
- src/structs.h src/testdir/test75.in, src/testdir/test75.ok
- Patch 7.3.033 (after 7.3.032)
- Problem: Can't build without FEAT_LOCALMAP.
- Solution: Add an #ifdef. (John Marriott)
- Files: src/getchar.c
- Patch 7.3.034
- Problem: Win32: may be loading .dll from the wrong directory.
- Solution: Go to the Vim executable directory when opening a library.
- Files: src/gui_w32.c, src/if_lua.c, src/if_mzsch.c, src/if_perl.xs,
- src/if_python.c, src/if_python3.c, src/if_ruby.c, src/mbyte.c,
- src/os_mswin.c, src/os_win32.c, src/proto/os_win32.pro
- Patch 7.3.035 (after 7.3.034)
- Problem: Stray semicolon after if statement. (Hari G)
- Solution: Remove the semicolon.
- Patch 7.3.036
- Problem: Win32 GUI: When building without menus, the font for dialogs and
- tab page headers also changes.
- Solution: Define USE_SYSMENU_FONT always. (Harig G.)
- Patch 7.3.037
- Problem: Compiler warnings for loss of data. (Mike Williams)
- Solution: Add type casts.
- Files: src/if_py_both.h, src/getchar.c, src/os_win32.c
- Patch 7.3.038
- Problem: v:windowid isn't set on MS-Windows.
- Solution: Set it to the window handle. (Chris Sutcliffe)
- Files: runtime/doc/eval.txt, src/gui_w32.c
- Patch 7.3.039
- Problem: Crash when using skk.vim plugin.
- Solution: Get length of expression evaluation result only after checking for
- NULL. (Noriaki Yagi, Dominique Pelle)
- Patch 7.3.040
- Problem: Comparing strings while ignoring case goes beyond end of the
- string when there are illegal bytes. (Dominique Pelle)
- Solution: Explicitly check for illegal bytes.
- Patch 7.3.041
- Problem: Compiler warning for accessing mediumVersion. (Tony Mechelynck)
- Solution: Use the pointer instead of the array itself. (Dominique Pelle)
- Files: src/version.c
- Patch 7.3.042
- Problem: No spell highlighting when re-using an empty buffer.
- Solution: Clear the spell checking info only when clearing the options for a
- buffer. (James Vega)
- Patch 7.3.043
- Problem: Can't load Ruby dynamically on Unix.
- Solution: Adjust the configure script. (James Vega)
- Files: src/Makefile, src/config.h.in, src/configure.in,
- src/auto/configure, src/if_ruby.c
- Patch 7.3.044
- Problem: The preview window opened by the popup menu is larger than
- specified with 'previewheight'. (Benjamin Haskell)
- Solution: Use 'previewheight' if it's set and smaller.
- Files: src/popupmnu.c
- Patch 7.3.045
- Problem: Compiler warning for uninitialized variable.
- Solution: Initialize the variable always.
- Patch 7.3.046 (after 7.3.043)
- Problem: Can't build Ruby on MS-Windows.
- Solution: Add #ifdef, don't use WIN3264 before including vim.h.
- Patch 7.3.047 (after 7.3.032)
- Problem: Missing makefile updates for test 75.
- Solution: Update the makefiles.
- Files: src/testdir/Make_amiga.mak, src/testdir/Make_dos.mak,
- src/testdir/Makefile, src/testdir/Make_ming.mak,
- Patch 7.3.048
- Problem: ":earlier 1f" doesn't work after loading undo file.
- Solution: Set b_u_save_nr_cur when loading an undo file. (Christian
- Brabandt)
- Fix only showing time in ":undolist"
- Files: src/undo.c
- Patch 7.3.049
- Problem: PLT has rebranded their Scheme to Racket.
- Solution: Add support for Racket 5.x. (Sergey Khorev)
- Files: src/Make_cyg.mak, src/Make_ming.mak, src/Make_mvc.mak,
- src/auto/configure, src/configure.in, src/if_mzsch.c
- Patch 7.3.050
- Problem: The link script is clumsy.
- Solution: Use the --as-needed linker option if available. (Kirill A.
- Shutemov)
- Files: src/Makefile, src/auto/configure, src/config.mk.in,
- src/configure.in, src/link.sh
- Patch 7.3.051
- Problem: Crash when $PATH is empty.
- Solution: Check for vim_getenv() returning NULL. (Yasuhiro Matsumoto)
- Files: src/ex_getln.c, src/os_win32.c
- Patch 7.3.1306
- Problem: When redrawing the screen during startup the intro message may be
- cleared.
- Solution: Redisplay the intro message when appropriate.
- Files: src/screen.c, src/version.c, src/proto/version.pro
- Patch 7.3.1307
- Problem: MS-Windows build instructions are outdated.
- Solution: Adjust for building on Windows 7. Drop Windows 95/98/ME support.
- Files: Makefile, nsis/gvim.nsi
- Patch 7.3.1308
- Problem: Typos in MS-Windows build settings and README.
- Solution: Minor changes to MS-Windows files.
- Files: src/msvc2008.bat, src/msvc2010.bat, src/VisVim/README_VisVim.txt
- Patch 7.3.1309
- Problem: When a script defines a function the flag to wait for the user to
- hit enter is reset.
- Solution: Restore the flag. (Yasuhiro Matsumoto) Except when the user was
- typing the function.
- Files: src/eval.c
- Patch 7.3.1310
- Problem: Typos in nsis script. Can use better compression.
- Solution: Fix typos. Use lzma compression. (Ken Takata)
- Files: nsis/gvim.nsi
- Patch 7.3.1311
- Problem: Compiler warnings on Cygwin.
- Solution: Add type casts. Add windows include files. (Ken Takata)
- Files: src/mbyte.c, src/ui.c
- Patch 7.3.1312 (after 7.3.1287)
- Problem: Not giving correct error messages for SystemExit().
- Solution: Move E858 into an else. (Ken Takata)
- Patch 7.3.1313
- Problem: :py and :py3 don't work when compiled with Cygwin or MingW with 64
- bit.
- Solution: Add -DMS_WIN64 to the build command. (Ken Takata)
- Patch 7.3.1314
- Problem: Test 87 fails with Python 3.3.
- Solution: Filter the error messages. (Taro Muraoka)
- Files: src/testdir/test87.in
- Patch 7.4a.001
- Problem: Script to update syntax menu is outdated.
- Solution: Add the missing items.
- Files: runtime/makemenu.vim
- Patch 7.4a.002
- Problem: Valgrind errors in test 89. (Simon Ruderich)
- Solution: Allocate one more byte. (Dominique Pelle)
- Files: src/misc2.c
- Patch 7.4a.003
- Problem: Copyright year is outdated.
- Solution: Only use the first year.
- Files: src/vim.rc, src/vim16.rc
- Patch 7.4a.004
- Problem: MSVC 2012 Update 3 is not recognized.
- Solution: Add the version number. (Raymond Ko)
- Files: src/Make_mvc.mak
- Patch 7.4a.005
- Problem: Scroll binding causes unexpected scroll.
- Solution: Store the topline after updating scroll binding. Add a test.
- (Lech Lorens)
- Files: src/testdir/test98.in, src/testdir/test98a.in,
- src/testdir/test98.ok, src/option.c, src/testdir/Make_amiga.mak,
- Patch 7.4a.006
- Problem: Failure in po file check goes unnoticed.
- Solution: Fail "make test" if the po file check fails.
- Patch 7.4a.007
- Problem: After "g$" with 'virtualedit' set, "k" moves to a different
- column. (Dimitar Dimitrov)
- Solution: Set w_curswant. (Christian Brabandt)
- Patch 7.4a.008
- Problem: Python 3 doesn't handle multibyte characters properly when
- 'encoding' is not utf-8.
- Solution: Use PyUnicode_Decode() instead of PyUnicode_FromString(). (Ken
- Takata)
- Files: src/if_python3.c
- Patch 7.4a.009
- Problem: Compiler warnings for function prototypes.
- Solution: Add "void". Move list_features() prototype. (Ken Takata)
- Files: src/gui_w48.c, src/if_py_both.h, src/version.c
- Patch 7.4a.010
- Problem: Test 86 and 87 fail when building with Python or Python 3 and
- using a static library.
- Solution: Add configure check to add -fPIE compiler flag.
- Files: src/configure.in, src/auto/configure
- Patch 7.4a.011
- Problem: Configure check for Python 3 config name isn't right.
- Solution: Always include vi_cv_var_python3_version. (Tim Harder)
- Patch 7.4a.012
- Problem: "make test" fails when using a shadow directory.
- Solution: Create links for files in src/po. (James McCoy)
- Patch 7.4a.013
- Problem: Setting/resetting 'lbr' in the main help file changes alignment
- after a Tab. (Dimitar Dimitrov)
- Solution: Also use the code for conceal mode where n_extra is computed for
- 'lbr'.
- Files: src/screen.c, src/testdir/test88.in, src/testdir/test88.ok
- Patch 7.4a.014
- Problem: Test 86 and 89 have a problem with using a shadow dir.
- Solution: Adjust for the different directory structure. (James McCoy)
- Files: src/testdir/test89.in, src/testdir/test86.in, src/Makefile
- Patch 7.4a.015
- Problem: No Japanese man pages.
- Solution: Add Japanese translations of man pages. (Ken Takata, Yukihiro
- Nakadaira, et al.)
- Files: Filelist, src/Makefile, runtime/doc/evim-ja.UTF-8.1,
- runtime/doc/vim-ja.UTF-8.1, runtime/doc/vimdiff-ja.UTF-8.1,
- runtime/doc/vimtutor-ja.UTF-8.1, runtime/doc/xxd-ja.UTF-8.1
- Patch 7.4a.016 (after 7.4a.014)
- Problem: Features enabled in Makefile.
- Solution: Undo accidental changes.
- Patch 7.4a.017
- Problem: When 'foldmethod' is "indent", using ">>" on a line just above a
- fold makes the cursor line folded. (Evan Laforge)
- Solution: Call foldOpenCursor(). (Christian Brabandt)
- Files: src/ops.c
- Patch 7.4a.018
- Problem: Compiler warning for code unreachable. (Charles Campbell)
- Solution: Use "while" instead of endless loop. Change break to continue.
- Files: src/regexp_nfa.c, src/ui.c
- Patch 7.4a.019
- Problem: Invalid closing parenthesis in test 62. Command truncated at
- double quote.
- Solution: Remove the parenthesis. Change double quote to ''. (ZyX)
- Files: src/testdir/test62.in, src/testdir/test62.ok
- Patch 7.4a.020
- Problem: Superfluous mb_ptr_adv().
- Solution: Remove the call. (Dominique Pelle)
- Patch 7.4a.021
- Problem: Using feedkeys() doesn't always work.
- Solution: Omit feedkeys(). (Ken Takata)
- Files: src/testdir/test98a.in
- Patch 7.4a.022
- Problem: Using "d2g$" does not delete the last character. (ZyX)
- Solution: Set the "inclusive" flag properly.
- Patch 7.4a.023 (after 7.4a.019)
- Problem: Still another superfluous parenthesis. (ZyX)
- Solution: Remove it.
- Patch 7.4a.024
- Problem: X11 GUI: Checking icon height twice.
- Solution: Check height and width. (Dominique Pelle)
- Files: src/gui_x11.c
- Patch 7.4a.025
- Problem: Get the press-Enter prompt even after using :redraw.
- Solution: Clear need_wait_return when executing :redraw.
- Patch 7.4a.026
- Problem: ":diffoff" does not remove folds. (Ramel)
- Solution: Do not restore 'foldenable' when 'foldmethod' is "manual".
- Files: src/diff.c
- Patch 7.4a.027
- Problem: When Python adds lines to another buffer the cursor position is
- wrong, it might be below the last line causing ml_get errors.
- (Vlad Irnov)
- Solution: Temporarily change the current window, so that marks are corrected
- properly.
- Files: src/if_py_both.h, src/window.c, src/proto/buffer.pro
- Patch 7.4a.028
- Problem: Crash when spell checking in new buffer.
- Solution: Set the b_p_key field. (Mike Williams)
- Files: src/spell.c, src/testdir/test58.in
- Patch 7.4a.029
- Problem: Can't build with MzScheme on Ubuntu 13.04.
- Solution: Add configure check for the "ffi" library.
- Patch 7.4a.030 (after 7.4.027)
- Problem: Missing find_win_for_buf(). (toothpik)
- Solution: Add missing changes.
- Patch 7.4a.031
- Problem: Compiler warnings. (Charles Campbell)
- Solution: Initialize variables even when not needed.
- Files: src/regexp_nfa.c, src/search.c
- Patch 7.4a.032
- Problem: New regexp engine: Does not match shorter alternative. (Ingo
- Karkat)
- Solution: Do not drop a new state when the PIM info is different.
- Patch 7.4a.033
- Problem: Test 98 always passes.
- Solution: Include test98a.in in test98.in, execute the crucial command in
- one line. (Yukihiro Nakadaira)
- Patch 7.4a.034
- Problem: The tabline may flicker when opening a new tab after 7.3.759 on
- Win32.
- Solution: Move call to TabCtrl_SetCurSel(). (Ken Takata)
- Patch 7.4a.035
- Problem: Fix in patch 7.4a.032 is not tested.
- Solution: Add test.
- Files: src/testdir/test64.in, src/testdir/test64.ok
- Patch 7.4a.036
- Problem: "\p" in a regexp does not match double-width characters.
- (Yukihiro Nakadaira)
- Solution: Don't count display cells, use vim_isprintc().
- Files: src/regexp.c, src/regexp_nfa.c, src/testdir/test64.in,
- src/testdir/test64.ok, src/testdir/test95.in,
- src/testdir/test95.ok
- Patch 7.4a.037
- Problem: Win32: When mouse is hidden and in the toolbar, moving it won't
- make it appear. (Sami Salonen)
- Solution: Add tabline_wndproc() and toolbar_wndproc(). (Ken Takata)
- Files: src/gui_w32.c, src/gui_w48.c
- Patch 7.4a.038
- Problem: When using MSVC 2012 there are various issues, including GUI size
- computations.
- Solution: Use SM_CXPADDEDBORDER. (Mike Williams)
- Files: src/gui_w32.c, src/gui_w48.c, src/os_win32.h
- Patch 7.4a.039
- Problem: New regexp engine doesn't match pattern. (Ingo Karkat)
- Solution: When adding a state also check for different PIM if the list of
- states has any state with a PIM.
- Files: src/regexp_nfa.c, src/testdir/test64.in, src/testdir/test64.ok
- Patch 7.4a.040
- Problem: Win32: using uninitialized variable.
- Solution: (Yukihiro Nakadaira)
- Patch 7.4a.041
- Problem: When using ":new ++ff=unix" and "dos" is first in 'fileformats'
- then 'ff' is set to "dos" instead of "unix". (Ingo Karkat)
- Solution: Create set_file_options() and invoke it from do_ecmd().
- Files: src/fileio.c, src/proto/fileio.pro, src/ex_cmds.c,
- src/testdir/test91.in, src/testdir/test91.ok
- Patch 7.4a.042
- Problem: Crash when BufUnload autocommands close all buffers. (Andrew
- Pimlott)
- Solution: Set curwin->w_buffer to curbuf to avoid NULL.
- Files: src/window.c, src/testdir/test8.in, src/testdir/test8.ok
- Patch 7.4a.043
- Problem: More ml_get errors when adding or deleting lines from Python.
- (Vlad Irnov)
- Solution: Switch to a window with the buffer when possible.
- Patch 7.4a.044
- Problem: Test 96 sometimes fails.
- Solution: Clear window from b_wininfo in win_free(). (Suggestion by
- Yukihiro Nakadaira)
- Patch 7.4a.045
- Problem: Configure does not always find the right library for Lua. Missing
- support for LuaJit.
- Solution: Improve the configure detection of Lua. (Hiroshi Shirosaki)
- Files: src/Makefile, src/configure.in, src/auto/configure
- Patch 7.4a.046
- Problem: Can't build without mbyte feature.
- Solution: Add #ifdefs.
- Patch 7.4a.047
- Problem: Some comments are not so nice.
- Solution: Change the comments.
- Files: src/ex_docmd.c, src/message.c, src/ops.c, src/option.c
- Patch 7.4b.001
- Problem: Win32: dialog may extend off-screen.
- Solution: Reduce the size, use correct borders. (Andrei Olsen)
- Patch 7.4b.002
- Problem: Crash searching for \%(\%(\|\d\|-\|\.\)*\|\*\). (Marcin
- Szamotulski) Also for \(\)*.
- Solution: Do add a state for opening parenthesis, so that we can check if it
- was added before at the same position.
- Patch 7.4b.003
- Problem: Regexp code is not nicely aligned.
- Solution: Adjust white space. (Ken Takata)
- Patch 7.4b.004
- Problem: Regexp crash on pattern "@\%[\w\-]*". (Axel Kielhorn)
- Solution: Add \%(\) around \%[] internally.
- Patch 7.4b.005
- Problem: Finding %s in shellpipe and shellredir does not ignore %%s.
- Solution: Skip over %%. (lcd 47)
- Patch 7.4b.006 (after 7.3.1295)
- Problem: Using \{n,m} in an autocommand pattern no longer works.
- Specifically, mutt temp files are not recognized. (Gary Johnson)
- Solution: Make \\\{n,m\} work.
- Files: runtime/doc/autocmd.txt, src/fileio.c
- Patch 7.4b.007
- Problem: On 32 bit MS-Windows :perldo does not work.
- Solution: Make sure time_t uses 32 bits. (Ken Takata)
- Files: src/if_perl.xs, src/vim.h
- Patch 7.4b.008
- Problem: 'autochdir' causes setbufvar() to change the current directory.
- (Ben Fritz)
- Solution: When disabling autocommands also reset 'acd' temporarily.
- Patch 7.4b.009
- Problem: When setting the Visual area manually and 'selection' is
- exclusive, a yank includes one character too much. (Ingo Karkat)
- Solution: Default the Visual operation to "v". (Christian Brabandt)
- Files: src/mark.c
- Patch 7.4b.010
- Problem: Win32: Tcl library load does not use standard mechanism.
- Solution: Call vimLoadLib() instead of LoadLibraryEx(). (Ken Takata)
- Files: src/if_perl.xs, src/if_tcl.c
- Patch 7.4b.011
- Problem: ":he \%(\)" does not work. (ZyX)
- Solution: Add an exception to the list.
- Patch 7.4b.012
- Problem: Output from a shell command is truncated at a NUL. (lcd 47)
- Solution: Change every NUL into an SOH.
- Patch 7.4b.013
- Problem: Install dir for JP man pages is wrong.
- Solution: Remove ".UTF-8" from the directory name. (Ken Takata)
- Patch 7.4b.014 (after 7.4b.012)
- Problem: Stupid mistake.
- Solution: Changle "len" to "i".
- Patch 7.4b.015 (after 7.4b.008)
- Problem: Can't compile without the 'acd' feature.
- Solution: Add #ifdefs. (Kazunobu Kuriyama)
- Patch 7.4b.016
- Problem: Ruby detection fails on Fedora 19.
- Solution: Use one way to get the Ruby version. (Michael Henry)
- Patch 7.4b.017
- Problem: ":he \^x" gives a strange error message. (glts)
- Solution: Do not translate \^x to \_CTRL-x.
- Patch 7.4b.018 (after 7.4b.001)
- Problem: Win32: Dialog can still be too big.
- Solution: Move the check for height further down. (Andrei Olsen)
- Patch 7.4b.019 (after 7.4a.034)
- Problem: Tabline is not updated properly when closing a tab on Win32.
- Solution: Only reduce flickering when adding a tab. (Ken Takata)
- Patch 7.4b.020
- Problem: "g~ap" changes first character of next paragraph. (Manuel Ortega)
- Solution: Avoid subtracting (0 - 1) from todo. (Mike Williams)
- Files: src/ops.c, src/testdir/test82.in, src/testdir/test82.ok
- Patch 7.4b.021
- Problem: Pressing "u" after an external command results in multiple
- press-enter messages. (glts)
- Solution: Don't call hit_return_msg() when we have K_IGNORE. (Christian
- Brabandt)
- Files: src/message.c
- Patch 7.4b.022
- Problem: Not waiting for a character when the tick count overflows.
- Solution: Subtract the unsigned numbers and cast to int. (Ken Takata)
- vim:tw=78:ts=8:ft=help:norl:
复制代码 软件:
