module wireExample (BpW,Error,Wait,Valid,Clear);
input Error,Wait,Valid,Clear;
output BpW;
wire BpW;
assign BpW = Error & Wait;
assign BpW = Valid | Clear;
endmodule
错误信息如下
Info: *******************************************************************
Info: Running Quartus II 32-bit Analysis & Synthesis
Info: Version 12.0 Build 178 05/31/2012 SJ Full Version
Info: Processing started: Thu Aug 15 09:53:34 2013
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off wireExample -c wireExample
Info (20030): Parallel compilation is enabled and will use 2 of the 2 processors detected
Error (10170): Verilog HDL syntax error at wireExample.v(8) near text "wire"; expecting an identifier ("wire" is a reserved keyword )
Error (10112): Ignored design unit "wireExample" at wireExample.v(1) due to previous errors
Info (12021): Found 0 design units, including 0 entities, in source file wireexample.v
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 260 megabytes
Error: Processing ended: Thu Aug 15 09:53:35 2013
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
