flash输出引脚会有正常的信号,但是一连接单片机所有的信号就都没了,布连单片机用示波器看的时候会有信号输出,读不出来,这是我的程序
#ifndef __w25x40_spi_H
#define __w25x40_spi_H
#define uint8 unsigned char
#define uint16 unsigned int
#define uint unsigned int
#define uint32 unsigned long
/*接口定义*/
#define CS_H PORTB|=(1<<4);DDRB|=(1<<4)
#define CS_L PORTB&=(0<<4);DDRB|=(1<<4)
#define DO_ (PINB&0X40);DDRB&=(0<<6)
#define WP_H PORTB|=(1<<2);DDRB|=(1<<2)
#define WP_L PORTB&=(0<<2);DDRB|=(1<<2)
#define CLK_H PORTB|=(1<<7);DDRB|=(1<<7)
#define CLK_L PORTB&=(0<<7);DDRB|=(1<<7)
#define DI_H PORTB|=(1<<5);DDRB|=(1<<5)
#define DI_L PORTB&=(0<<5);DDRB|=(1<<5)
#define HOLD_H PORTB|=(1<<3);DDRB|=(1<<3)
#define HOLD_L PORTB&=(0<<3);DDRB|=(1<<3)
/*命令定义*/
#define W25P_WriteEnable 0x06
#define W25P_WriteDisable 0x04
#define W25P_ReadStatusReg 0x05
#define W25P_WriteStatusReg 0x01
#define W25P_ReadData 0x03
#define W25P_FastReadData 0x0B
#define W25P_PageProgram 0x02
#define W25P_SectorErase 0xD8 // 64KB
#define W25P_ChipErase 0xC7
#define W25P_PowerDown 0xB9
#define W25P_ReleasePowerDown 0xAB
#define W25P_DeviceID 0xAB
#define W25P_ManufactDeviceID 0x90
/*所需函数声明*/
void init_cpu(void);
void IO_Send_Byte(uchar out);
uchar IO_Get_Byte();
void delay(uchar tt);
void IO_Wait_Busy();
void IO_init();
uchar IO_Read_StatusReg();
void IO_Write_StatusReg(uchar byte);
void IO_Write_Enable();
void IO_PowerDown();
void IO_ReleasePowerDown();
uchar IO_Read_ID1();
uint IO_Read_ID2(uchar ID_Addr);
uchar IO_Read_Byte(uint32 Dst_Addr);
void IO_Read_nBytes(uint32 Dst_Addr, uchar nBytes_128);
uchar IO_FastRead_Byte(uint32 Dst_Addr);
void IO_FastRead_nBytes(uint32 Dst_Addr, uchar nBytes_128);
void IO_Write_Byte(uint32 Dst_Addr, uchar byte);
void IO_Write_nBytes(uint32 Dst_Addr, uchar nBytes_128);
void IO_Erase_Chip();
void IO_Erase_Sector(uint32 Dst_Addr);
void Verify(uchar byte, uchar cor_byte);
void IO_Write_Disable();
void trace(uchar *str,uchar len);
uint IO_Read_ID3();
uint8 upper_128[16];
/*发送一个字节*/
uchar i=0;
CS_L;
for (i=0;i<8;i++)
if ((out & 0x80)==0x80)
{ DI_H; }
{ DI_L; }
CLK_H;
out=(out<<1);
NOP();
NOP();
NOP();
NOP();
CLK_L;
/*读取型号*/
uchar IO_Read_ID1()
uchar byte;
CS_L; /* enable device */
IO_Send_Byte(W25P_DeviceID); /* send read device ID command (ABh) */
IO_Send_Byte(0); /* send address */
IO_Send_Byte(0); /* send 3_Dummy address */
byte = IO_Get_Byte(); /* receive Device ID byte */
CS_H; /* disable device */
delay(20); /* remain CS high for tRES2 = 1.8uS */
return byte;
/*读取一个字节*/
uchar IO_Get_Byte(void)
uchar i=0,in=0,temp=0;
CS_L;
for (i=0;i<8;i++)
in=(in<<1); /* shift 1 place to the left or shift in 0 */
temp=DO_; /* save input */
CLK_H; /* toggle clock high */
if (temp==1) /* check to see if bit is high */
in|=0x01; /* if high, make bit high */
CLK_L; /* toggle clock low */
return in;
/*一段延时*/
while(tt--);
/*忙检测*/
void IO_Wait_Busy()
/* waste time until not busy WEL & Busy bit all be 1 (0x03). */
while (IO_Read_StatusReg() == 0x03)
/*读取状态寄存器*/
uchar byte = 0;
IO_Send_Byte(W25P_ReadStatusReg); /* send Read Status Register co mmand */
byte = IO_Get_Byte(); /* receive byte */
return byte;
/*状态寄存器赋值*/
IO_Send_Byte(W25P_WriteStatusReg); /* select write to status register */
IO_Send_Byte(byte); /* data that will change the status(only bits 2,3,7 can be written) */
CS_H; /* disable the device */
/*写使能*/
IO_Send_Byte(W25P_WriteEnable); /* send W25P_Write_Enable command */
uint IData16;
IO_Send_Byte(W25P_ManufactDeviceID); /* send read ID command (90h) */
IO_Send_Byte(0x00); /* send address */
IO_Send_Byte(ID_Addr); /* send W25Pxx selectable ID address 00H or 01H */
IData16 = IO_Get_Byte()<<8; /* receive Manufature or Device ID byte */
IData16 |= IO_Get_Byte(); /* receive Device or Manufacture ID byte */
return IData16;
/*读取固定地址下一个字节*/
uchar byte = 0;
IO_Send_Byte(W25P_ReadData); /* read command */
IO_Send_Byte(((Dst_Addr & 0xFFFFFF) >> 16)); /* send 3 address bytes */
IO_Send_Byte(((Dst_Addr & 0xFFFF) >> 8));
IO_Send_Byte(Dst_Addr & 0xFF);
return byte; /* return one byte read */
/*读取数据*/
uint32 i = 0;
for (i = 0; i < nBytes_128; i++) /* read until no_bytes is reached */
upper_128[i] = IO_Get_Byte(); /* receive byte and store at address 80H - FFH */
/*快速读取一个字节*/
uchar byte = 0;
IO_Send_Byte(W25P_FastReadData); /* fast read command */
IO_Send_Byte(0xFF); /*dummy byte*/
/*快速读取数据*/
uchar i = 0;
IO_Send_Byte(W25P_FastReadData); /* read command */
/*写一个字节*/
IO_Write_Enable(); /* set WEL */
IO_Wait_Busy();
CS_L;
IO_Send_Byte(W25P_PageProgram); /* send Byte Program command */
IO_Send_Byte(byte); /* send byte to be programmed */
uchar i, byte;
CS_L;
byte = upper_128[i];
//printf("\nPage program (%d nBytes)! please waiting....\n");
/*擦出芯片*/
CS_L;
IO_Wait_Busy();
CS_L;
IO_Send_Byte(W25P_ChipErase); /* send Chip Erase command */
/*擦出寄存器*/
CS_L;
IO_Send_Byte(W25P_SectorErase); /* send Sector Erase command */
IO_Send_Byte(Dst_Addr & 0xFF );
/*检验*/
if (byte != cor_byte)
while(1);
//LED_Error = 0; /* display to view error on LED. */
/*禁止写*/
IO_Send_Byte(W25P_WriteDisable); /* send W25P_Write_Disable command */
下面是主程序
//ICC-AVR application builder : 2013/8/12 13:23:46
// Target : M8515
// Crystal: 16.000Mhz
#include <iom8515v.h>
#include <macros.h>
#include "w25x40_spi.h"
/*端口初始化*/
void IO_init()
CLK_L; /* set clock to low initial state for SPI operation mode 0 *
// _clk = 1; /* set clock to low initial state for SPI operation mode 3 */
HOLD_H;
// _hold = 1;
WP_H;
CS_H;
IO_Write_Disable();
void uart0_init(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = BIT(URSEL) | 0x06;
UBRRL = 0x67; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
UCSRB = 0x08;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
IO_init();
uart0_init();
SEI(); //re-enable interrupts
//all peripherals are now initialized
init_devices();
//insert your functional code here...
// IO_Read_ID2(0x22);
UDR=IO_Read_ID1();
大神帮忙看看啊!!
布连单片机的时候flash会有数据输出,连单片机就没有了
