51+MCP2515+TJA1050
当我单节点通讯的时候是一切正常的 。当我使用两个节点时 我是这样设计的 我用定时器设定一定的时间 主机发送一个与节点1相同标识符的远程幀 然后该节点本应该回复一个数据帧 然后再过一段时间发送一个与节点2相同标识符的远程幀 ,本来节点二这时候也会回一个数据帧的 但是现在的现象是 节点1有收到远程幀而且在不断的发数据 但是节点二收到一个远程幀后只发出一个数据帧后就不在发数据了 ,而主机收不到任何数据。这是怎么回事呢?我只用发送缓冲器0且禁止了滚存 波特率也有设一样 。好痛苦啊 我主机的程序如下:
#include<reg52.h>
#include <intrins.h>
#include"main.h"
uchar TX_ID1[2] = {0x00,0x20}; //节点1地址
uchar RX_ID[2]; //接收目标节点地址缓冲器
uchar RX_Buffer1[9]=" "; //接收缓冲器1
uchar TX_ID2[2] = {0x00,0x40}; //节点2地址
uchar RX_Buffer2[9]=" "; //接收缓冲器2
uchar inter;
uint time;
bit TX1_flag = 0 ;
bit RX_flag = 0;
bit TX2_flag = 0 ;
void Time0_Init(void)
TMOD = (TMOD & 0xfc)|0x01;
TH0 = 0x0B8;
TL0 = 0x00;
ET0 = 1;
TR0 = 1;
void InitUART(void)
TMOD = (TMOD & 0xcf)|0x20; //波特率9600
SCON = 0x50;
TH1 = 0xFD;
TL1 = TH1;
PCON = 0x00;
TR1 = 1;
void SendOneByte(uchar c)
SBUF = c;
while(!TI);
TI = 0;
void Uart_Printf(uchar *Uart_Buffer)
uint i=0;
while(Uart_Buffer[i] != '\0')
SendOneByte(Uart_Buffer[i]);
i++;
void init_mcu(void)
IT0 = 0; //MCU外部中断INT0设置为电平触发
EX0 = 1; //开MCU外部中断INT0
EA = 1; //开MCU总中断
void inter0_can_rxd(void) interrupt 0 using 1
IE0 = 0;
RX_flag = 1;
void Timer0Interrupt(void) interrupt 1 using 2
TH0 = 0xB8;
TL0 = 0x00;
time++;
if(time == 50)
TX1_flag = 1;
if(time == 100)
TX2_flag = 1;
time = 0;
void main()
InitUART();
Time0_Init();
Uart_Printf("chu_si_hu_MCP2515\n");
CAN_Init();
Uart_Printf("chu_si_hu_cheng_gong\n");
init_mcu();
if(TX1_flag == 1)
TX1_flag = 0;
CAN_Send_RTR(TX_ID1); //发送远程幀 对节点1
if(TX2_flag == 1)
TX2_flag = 0;
CAN_Send_RTR(TX_ID2); //发送远程幀 对节点2
if(RX_flag) //主机中断接收到数据
RX_flag = 0;
EA = 0;
inter = SPIByteRead(CANINTF);
if(inter & 0x01)
BitModiMcp2515(CANINTF,0x01,0x00);
CAN_Receive_ID(RX_ID);
if((RX_ID[1]&0xe0)== 0x20)
if(!(RX_ID[1] & 0x10))
CAN_Receive_Data(RX_Buffer1);
Uart_Printf("net1_data:");
Uart_Printf(RX_Buffer1);
Uart_Printf("\n");
if((RX_ID[1]&0xe0) == 0x40)
CAN_Receive_Data(RX_Buffer2);
Uart_Printf("net2_data:");
Uart_Printf(RX_Buffer2);
Uart_Printf("\n");
EA = 1;
