求救!!MPU6050能读出who am i但是读加速度和陀螺仪都是0。读WHO_AM_I读到0x68.有点迷茫了- #include "stm32f10x.h"
- #include "led.h"
- #include "usart.h"
- #include "mpu6050.h"
- #include "i2c.h"
- #define uchar unsigned char
- #define uint unsigned int
- //定义MPU6050内部地址********************
- #define SMPLRT_DIV 0x19 //陀螺仪采样率,典型值:0x07(125Hz)
- #define CONFIG 0x1A //低通滤波频率,典型值:0x06(5Hz)
- #define GYRO_CONFIG 0x1B //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
- #define ACCEL_CONFIG 0x1C //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
- #define ACCEL_XOUT_H 0x3B
- #define ACCEL_XOUT_L 0x3C
- #define ACCEL_YOUT_H 0x3D
- #define ACCEL_YOUT_L 0x3E
- #define ACCEL_ZOUT_H 0x3F
- #define ACCEL_ZOUT_L 0x40
- #define TEMP_OUT_H 0x41
- #define TEMP_OUT_L 0x42
- #define GYRO_XOUT_H 0x43
- #define GYRO_XOUT_L 0x44
- #define GYRO_YOUT_H 0x45
- #define GYRO_YOUT_L 0x46
- #define GYRO_ZOUT_H 0x47
- #define GYRO_ZOUT_L 0x48
- #define PWR_MGMT_1 0x6B //电源管理,典型值:0x00(正常启用)
- #define WHO_AM_I 0x75 //IIC地址寄存器(默认数值0x68,只读)
- #define MPU6050_Addr 0xD0 //定义器件在IIC总线中的从地址,根据ALT ADDRESS地址引脚不同修改
- unsigned char TX_DATA[4]; //显示据缓存区
- unsigned char BUF[10]; //接收数据缓存区
- char test=0; //IIC用到
- short T_X,T_Y,T_Z,T_T; //X,Y,Z轴,温度
- /*模拟IIC端口输出输入定义*/
- #define SCL_H GPIOB->BSRR = GPIO_Pin_6
- #define SCL_L GPIOB->BRR = GPIO_Pin_6
- #define SDA_H GPIOB->BSRR = GPIO_Pin_7
- #define SDA_L GPIOB->BRR = GPIO_Pin_7
- #define SCL_read GPIOB->IDR & GPIO_Pin_6
- #define SDA_read GPIOB->IDR & GPIO_Pin_7
- //void Delay(__IO u32 nCount);
- * 函数名:main
- * 描述 :主函数
- * 输入 :无
- * 输出 :无
- * Function Name : I2C_GPIO_Config
- * Description : Configration Simulation IIC GPIO
- * Input : None
- * Output : None
- * Return : None
- void I2C_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
- * Function Name : I2C_delay
- * Description : Simulation IIC Timing series delay
- * Input : None
- * Output : None
- * Return : None
- void I2C_delay(void)
- u8 i=30; //这里可以优化速度 ,经测试最低到5还能写入
- while(i)
- i--;
- void delay5ms(void)
- int i=5000;
- while(i)
- i--;
- * Function Name : I2C_Start
- * Description : Master Start Simulation IIC Communication
- * Input : None
- * Output : None
- * Return : Wheather Start
- bool I2C_Start(void)
- SDA_H;
- SCL_H;
- I2C_delay();
- if(!SDA_read)return FALSE; //SDA线为低电平则总线忙,退出
- SDA_L;
- I2C_delay();
- if(SDA_read) return FALSE; //SDA线为高电平则总线出错,退出
- SDA_L;
- I2C_delay();
- return TRUE;
- * Function Name : I2C_Stop
- * Description : Master Stop Simulation IIC Communication
- * Input : None
- * Output : None
- * Return : None
- void I2C_Stop(void)
- SCL_L;
- I2C_delay();
- SDA_L;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SDA_H;
- I2C_delay();
- * Function Name : I2C_Ack
- * Description : Master Send Acknowledge Single
- * Input : None
- * Output : None
- * Return : None
- void I2C_Ack(void)
- SCL_L;
- I2C_delay();
- SDA_L;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SCL_L;
- I2C_delay();
- * Function Name : I2C_NoAck
- * Description : Master Send No Acknowledge Single
- * Input : None
- * Output : None
- * Return : None
- void I2C_NoAck(void)
- SCL_L;
- I2C_delay();
- SDA_H;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SCL_L;
- I2C_delay();
- * Function Name : I2C_WaitAck
- * Description : Master Reserive Slave Acknowledge Single
- * Input : None
- * Output : None
- * Return : Wheather Reserive Slave Acknowledge Single
- bool I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK
- SCL_L;
- I2C_delay();
- SDA_H;
- I2C_delay();
- SCL_H;
- I2C_delay();
- if(SDA_read)
- SCL_L;
- I2C_delay();
- return FALSE;
- SCL_L;
- I2C_delay();
- return TRUE;
- * Function Name : I2C_SendByte
- * Description : Master Send a Byte to Slave
- * Input : Will Send Date
- * Output : None
- * Return : None
- void I2C_SendByte(u8 SendByte) //数据从高位到低位//
- u8 i=8;
- while(i--)
- SCL_L;
- I2C_delay();
- if(SendByte&0x80)
- SDA_H;
- else
- SDA_L;
- SendByte<<=1;
- I2C_delay();
- SCL_H;
- I2C_delay();
- SCL_L;
- * Function Name : I2C_RadeByte
- * Description : Master Reserive a Byte From Slave
- * Input : None
- * Output : None
- * Return : Date From Slave
- unsigned char I2C_RadeByte(void) //数据从高位到低位//
- u8 i=8;
- u8 ReceiveByte=0;
- SDA_H;
- while(i--)
- ReceiveByte<<=1;
- SCL_L;
- I2C_delay();
- SCL_H;
- I2C_delay();
- if(SDA_read)
- ReceiveByte|=0x01;
- SCL_L;
- return ReceiveByte;
- //ZRX
- //单字节写入*******************************************
- bool Single_Write(unsigned char SlaveAddress,unsigned char REG_Address,unsigned char REG_data) //void
- if(!I2C_Start())return FALSE;
- I2C_SendByte(SlaveAddress); //发送设备地址+写信号//I2C_SendByte(((REG_Address & 0x0700) >>7) | SlaveAddress & 0xFFFE);//设置高起始地址+器件地址
- if(!I2C_WaitAck()){I2C_Stop(); return FALSE;}
- I2C_SendByte(REG_Address ); //设置低起始地址
- I2C_WaitAck();
- I2C_SendByte(REG_data);
- I2C_WaitAck();
- I2C_Stop();
- delay5ms();
- return TRUE;
- //单字节读取*****************************************
- unsigned char Single_Read(unsigned char SlaveAddress,unsigned char REG_Address)
- { unsigned char REG_data;
- I2C_SendByte(SlaveAddress); //I2C_SendByte(((REG_Address & 0x0700) >>7) | REG_Address & 0xFFFE);//设置高起始地址+器件地址
- if(!I2C_WaitAck()){I2C_Stop();test=1; return FALSE;}
- I2C_SendByte((u8) REG_Address); //设置低起始地址
- I2C_WaitAck();
- I2C_Start();
- I2C_SendByte(SlaveAddress+1);
- I2C_WaitAck();
- REG_data= I2C_RadeByte();
- I2C_NoAck();
- I2C_Stop();
- //return TRUE;
- return REG_data;
- //初始化MPU3050,根据需要请参考pdf进行修改************************
- void Init_MPU6050(void)
- Single_Write(MPU6050_Addr,PWR_MGMT_1, 0x00); //解除休眠状态
- Single_Write(MPU6050_Addr,SMPLRT_DIV, 0x07);
- Single_Write(MPU6050_Addr,CONFIG, 0x06);
- Single_Write(MPU6050_Addr,GYRO_CONFIG, 0x18);
- Single_Write(MPU6050_Addr,ACCEL_CONFIG, 0x01);
- //******读取MPU6050数据****************************************
- void READ_MPU6050(void)
- BUF[0]=Single_Read(MPU6050_Addr,GYRO_XOUT_L);
- BUF[1]=Single_Read(MPU6050_Addr,GYRO_XOUT_H);
- T_X= (BUF[1]<<8)|BUF[0];
- T_X/=16.4; //读取计算X轴数据
- BUF[2]=Single_Read(MPU6050_Addr,GYRO_YOUT_L);
- BUF[3]=Single_Read(MPU6050_Addr,GYRO_YOUT_H);
- T_Y= (BUF[3]<<8)|BUF[2];
- T_Y/=16.4; //读取计算Y轴数据
- BUF[4]=Single_Read(MPU6050_Addr,GYRO_ZOUT_L);
- BUF[5]=Single_Read(MPU6050_Addr,GYRO_ZOUT_H);
- T_Z= (BUF[5]<<8)|BUF[4];
- T_Z/=16.4; //读取计算Z轴数据
- // BUF[6]=Single_Read(MPU6050_Addr,TEMP_OUT_L);
- // BUF[7]=Single_Read(MPU6050_Addr,TEMP_OUT_H);
- // T_T=(BUF[7]<<8)|BUF[6];
- // T_T = 35+ ((double) (T_T + 13200)) / 280;// 读取计算出温度
- ** 函数名称 : Delay(vu32 nCount)
- ** 函数功能 : 延时函数
- ** 输 入 : 无
- ** 输 出 : 无
- ** 返 回 : 无
- void Delay(vu32 nCount)
- for(; nCount != 0; nCount--);
- ** 函数名称 : void Delayms(vu32 m)
- ** 函数功能 : 长延时函数 m=1,延时1ms
- ** 输 入 : 无
- ** 输 出 : 无
- ** 返 回 : 无
- void Delayms(vu32 m)
- u32 i;
- for(; m != 0; m--)
- for (i=0; i<50000; i++);
- int main(void)
- /* 配置系统时钟为72M */
- SystemInit();
- /* LED 端口初始化 */
- LED_GPIO_Config();
- USART_Configuration();
- USART_Test();
- I2C_GPIO_Config(); //配置IIC使用端口
- Delayms(10); //延时
- Init_MPU6050(); //初始化MPU3050
- while (1)
- LED1( ON ); // 亮
- Delay(0x6FFFEF);
- LED1( OFF ); // 灭
- LED2( ON );
- Delay(0x6FFFEF);
- LED2( OFF );
- LED3( ON );
- Delay(0x6FFFEF);
- LED3( OFF );
- //USART_SendData(USART1,Single_Read(MPU6050_Addr,0x75));
- USART_SendData(USART1,Single_Read(MPU6050_Addr,TEMP_OUT_H));
- USART_SendData(USART1,Single_Read(MPU6050_Addr,TEMP_OUT_L));
- // READ_MPU6050(); //读取MPU3050数据
- /* printf("X:%d\r\n",T_X);//转换X轴数据到数组
- printf("Y:%d\r\n",T_Y);;//转换Y轴数据到数组
- printf("Z:%d\r\n",T_Z);;//转换Z轴数据到数组
- printf("T:%d\r\n",T_T);//转换温度数据到数组
复制代码 |
