大家好,接触cc430不久,rf相关的程序都是在demo程序的基础稍作修改的。我应用的方式是一块设备以一定的时间间隔发送一包数据(仅发送),另一块设备仅负责接收。现在遇到的问题是接收设备运行一段时间后就接收不到数据了,重新复位后又可以收到数据,如此反复。调试时发现OPERR位置位,跟踪发现在ReceiveOn()->Strobe()-> ReadSingleReg()->data_out = RF1ADOUT1B时(我用demo板的demo程序也出现这种情况)。
相关的代码如下:
接收设备:
#define PATABLE_VAL (0x05)
void RF_Init(void)
SetVCore(2);
ResetRadioCore();
InitRadio();
ReceiveOn();
_EINT();
#pragma vector=CC1101_VECTOR
__interrupt void CC1101_ISR(void)
// ReceiveOff();
switch(__even_in_range(RF1AIV,32)) // Prioritizing Radio Core Interrupt
case 0: break; // No RF core interrupt pending
case 2: break; // RFIFG0
case 4: break; // RFIFG1
case 6: break; // RFIFG2
case 8: break; // RFIFG3
case 10: break; // RFIFG4
case 12: break; // RFIFG5
case 14: break; // RFIFG6
case 16: break; // RFIFG7
case 18: break; // RFIFG8
case 20: // RFIFG9
// Read the length byte from the FIFO
RxBufferLength = ReadSingleReg(RXBYTES);
if (RxBufferLength && (RxBufferLength <= sizeof(RxBuffer)))
ReadBurstReg(RF_RXFIFORD, RxBuffer, RxBufferLength);
RxBufferLength = 0;
// Stop here to see contents of RxBuffer
__no_operation();
// Check the validity and CRC results
if (RF_IsValidData(RxBuffer, RxBufferLength))
&& (RxBuffer[CRC_LQI_IDX] & CRC_OK))
/* 保存数据 */
ReceiveOn();
case 22: break; // RFIFG10
case 24: break; // RFIFG11
case 26: break; // RFIFG12
case 28: break; // RFIFG13
case 30: break; // RFIFG14
case 32: break; // RFIFG15
__bic_SR_register_on_exit(LPM3_bits);
发射设备:
#define PATABLE_VAL (0xc4)
void RF_Init(void)
SetVCore(2);
ResetRadioCore();
InitRadio();
ReceiveOn();
_EINT();
void RF_Send(void)
u8 *p_tmp = TxBuffer;
*p_tmp++ = 16;
*p_tmp++ = 'T';
*p_tmp++ = 'T';
memcpy((char *)p_tmp, (char *)g_rfData, 8);
p_tmp += 8;
*p_tmp++ = MMBYTE(g_rfState);
*p_tmp++ = MLBYTE(g_rfState);
*p_tmp++ = LMBYTE(g_rfState);
*p_tmp++ = LLBYTE(g_rfState);
*p_tmp++ = 'T';
*p_tmp++ = 'T';
Transmit( (unsigned char*)TxBuffer,sizeof(TxBuffer));
debug("Send data\r\n");
就是这个问题,困扰我很久了,请高手指点,不胜感激。 |
