马老师的音乐播放例程中,外部中断和比较中断执行顺序...
外部中断优先级高于定时器
画了流程图,外部中断响应后开启了定时器,但是计数器要加到溢出才会执行比较中断吧?
而这个时候按键应该是松开了对吗?然后执行--int_n,那不就成了-1?条件不成立就退出了,怎么会可以播放音乐呢?
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
prog_uint16_t t[] = {0,956,865,759,638,568,506,470};
prog_uchar d[] = {0,105,116,132,140,157,176,198,209};
#define Max_note 32
prog_uchar music[] = {5,2,8,2,5,2,4,2,3,2,2,2,1,4,1,2,1,2,2,2,3,2,3,2,1,2,3,2,4,2,5,8};
unsigned char note_n;
unsigned int int_n;
unsigned char play_on;
int main(void)
PORTD = 0x08;
DDRD = 0x02;
TCCR1A = 0x40;
TCCR1B = 0x08;
TIMSK = 0x10;
GICR |= 0x80;
MCUCR = 0x08;
MCUCSR = 0x00;
GIFR = 0x80;
sei();
ISR(INT1_vect)
if(!play_on)
TCCR1B = 0x09;
ISR(TIMER1_COMPA_vect)
if(!play_on)
note_n = 0;
int_n = 1;
play_on = 1;
if(--int_n == 0)
TCCR1B = 0x08;
if(note_n < Max_note)
OCR1A = t[music[note_n]];
int_n = d[music[note_n]];
note_n++;
int_n = int_n * music[note_n];
note_n++;
TCCR1B = 0x09;
play_on = 0;
