#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdio.h>
unsigned int oldval,newval,nowval;
volatile unsigned int i;
static int Send_Byte(char c, FILE *stream); //添加自定义的putchar函数
static FILE mystdout = FDEV_SETUP_STREAM(Send_Byte, NULL,_FDEV_SETUP_WRITE);
void Port_Init(void)
PORTA = 0xff;
PORTB = 0xff;
PORTC = 0xff;
PORTD = 0xff;
DDRA = 0xff;
DDRB = 0xff;
DDRC = 0xff;
DDRD |= (1 << PD1);
DDRD &= ~(1 << PD6);
void Timer1_Init(void)
TCCR1B |= (1 << CS11);
TIMSK |= (1 << TICIE1) | (1 << TOIE1);
void Usart_Init(void)
UBRRH = 0x00;
UBRRL = 0x33;
UCSRB |= (1 << TXEN);
if (c == '\n')
Send_Byte('\r', stream);
loop_until_bit_is_set(UCSRA, UDRE);
UDR = c;
return 0;
int main(void)
unsigned int i = 10;
Port_Init();
Timer1_Init();
Usart_Init();
stdout = &mystdout;
sei();
_delay_ms(50);
// printf("test\n");
ISR(TIMER1_CAPT_vect)
static unsigned int t;
if(t == 0)
TCNT1H = 0x00;
TCNT1L = 0x00;
oldval = ICR1;
printf("oldval=%ud\n",oldval);
t = 1;
else if( t == 1)
newval = ICR1;
nowval = newval - oldval;
printf("newval=%ud\n",newval);
printf("timercnt=%ud",i);
t = 10;
ISR(TIMER1_OVF_vect)
i++;
输入的信号是周期500us的方波,高低电平各250us,现在程序打印出来的数据newval和oldval 相减是计算周期的,可是数值感觉不对,不知道为什么? |
