发表于 2013-7-13 11:57:00
- /* Name: usbdrvasm12.inc
- * Project: V-USB, virtual USB port for Atmel's(r) AVR(r) microcontrollers
- * Author: Christian Starkjohann
- * Creation Date: 2004-12-29
- * Tabsize: 4
- * Copyright: (c) 2007 by OBJECTIVE DEVELOPMENT Software GmbH
- * License: GNU GPL v2 (see License.txt), GNU GPL v3 or proprietary (CommercialLicense.txt)
- * This Revision: $Id$
- /* Do not link this file! Link usbdrvasm.S instead, which includes the
- * appropriate implementation!
- General Description:
- This file is the 12 MHz version of the asssembler part of the USB driver. It
- requires a 12 MHz crystal (not a ceramic resonator and not a calibrated RC
- oscillator).
- See usbdrv.h for a description of the entire driver.
- Since almost all of this code is timing critical, don't change unless you
- really know what you are doing! Many parts require not only a maximum number
- of CPU cycles, but even an exact number of cycles!
- Timing constraints according to spec (in bit times):
- timing subject min max CPUcycles
- EOP of OUT/SETUP to sync pattern of DATA0 (both rx) 2 16 16-128
- EOP of IN to sync pattern of DATA0 (rx, then tx) 2 7.5 16-60
- DATAx (rx) to ACK/NAK/STALL (tx) 2 7.5 16-60
- #if USB_CFG_CLOCK_KHZ == 12000
- #define nop8
- #elif USB_CFG_CLOCK_KHZ == 24000
- #define nop8 rcall delay8
- #else
- #error "USB_CFG_CLOCK_KHZ is not one of the supported non-crc-rates!"
- #endif
- ;Software-receiver engine. Strict timing! Don't change unless you can preserve timing!
- ;interrupt response time: 4 cycles + insn running = 7 max if interrupts always enabled
- ;max allowable interrupt latency: 34 cycles -> max 25 cycles interrupt disable
- ;max stack usage: [ret(2), YL, SREG, YH, shift, x1, x2, x3, cnt, x4] = 11 bytes
- ;Numbers in brackets are maximum cycles since SOF.
- USB_INTR_VECTOR:
- ;order of registers pushed: YL, SREG [sofError], YH, shift, x1, x2, x3, cnt
- push YL ;2 [35] push only what is necessary to sync with edge ASAP
- in YL, SREG ;1 [37]
- push YL ;2 [39]
- push x5 ; //新增加寄存器变量
- ; Synchronize with sync pattern:
- ;sync byte (D-) pattern LSb to MSb: 01010100 [1 = idle = J, 0 = K]
- ;sync up with J to K edge during sync pattern -- use fastest possible loops
- ;The first part waits at most 1 bit long since we must be in sync pattern.
- ;YL is guarenteed to be < 0x80 because I flag is clear. When we jump to
- ;waitForJ, ensure that this prerequisite is met.
- ;原始LGT 移植代码 此处可能会引起错误当开启USB_COUNT_SOF, USB_SOF_HOOK或者电平错误时将导致死循环或不执行代码
- ;通过增加新寄存器变量修正
- waitForJ:
- inc YL
- in x5, USBIN
- sbrs x5, USBMINUS
- brne waitForJ ; just make sure we have ANY timeout
- waitForK:
- ;The following code results in a sampling window of 1/4 bit which meets the spec.
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- #if USB_CFG_CLOCK_KHZ == 24000
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- in x5, USBIN
- sbrs x5, USBMINUS
- rjmp foundK
- #endif
- #if USB_COUNT_SOF
- lds YL, usbSofCount
- inc YL
- sts usbSofCount, YL
- #endif /* USB_COUNT_SOF */
- #ifdef USB_SOF_HOOK
- USB_SOF_HOOK
- #endif
- rjmp sofError
- foundK:
- ;{3, 5} after falling D- edge, average delay: 4 cycles [we want 4 for center sampling]
- ;we have 1 bit time for setup purposes, then sample again. Numbers in brackets
- ;are cycles from center of first sync (double K) bit after the instruction
- push YH ;1 [1]
- nop
- lds YL, usbInputBufOffset ;2 [4]
- clr YH ;1 [5]
- subi YL, lo8(-(usbRxBuf)) ;1 [6]
- sbci YH, hi8(-(usbRxBuf)) ;1 [7]
- in x5, USBIN ;1 [8]
- sbrs x5, USBMINUS ;1 [9]
- ;sbis USBIN, USBMINUS ;1 [8] we want two bits K [sample 1 cycle too early]
- rjmp haveTwoBitsK ;1 [10]
- pop YH ;1 [11] undo the push from before
- rjmp waitForK ;1 [12] this was not the end of sync, retry
- haveTwoBitsK:
- ; push more registers and initialize values while we sample the first bits:
- push shift ;1 [11];2 [16]
- push x1 ;1 [12];2 [12]
- push x2 ;1 [13];2 [14]
- ;原始LGT 移植代码 此处引起关键错误 可能因为上面读寄存器引起的时序偏差导致读bit 0后移
- ;未使用逻辑分析仪跟踪分析 上面只是推测减少两个时钟的延迟就无错误数据出现 说明读取bit 0
- ;向后移了很多
- ;nop2 ;2 [15]
- ;nop ;1 [16]
- ;新代码
- nop
- in x1, USBIN ;1 [17] <-- sample bit 0
- ldi shift, 0xff ;1 [18]
- bst x1, USBMINUS ;1 [19]
- bld shift, 0 ;1 [20]
- push x3 ;1 [21];2 [22]
- push cnt ;1 [22];2 [24]
- nop2 ;2 [24]
- in x2, USBIN ;1 [25] <-- sample bit 1
- ser x3 ;1 [26] [inserted init instruction]
- eor x1, x2 ;1 [27]
- bst x1, USBMINUS ;1 [28]
- bld shift, 1 ;1 [29]
- ldi cnt, USB_BUFSIZE;1 [30] [inserted init instruction]
- nop ;1 [31]
- rjmp rxbit2 ;1 [32];2[32]
- ; Receiver loop (numbers in brackets are cycles within byte after instr)
- unstuff0: ;1 (branch taken)
- andi x3, ~0x01 ;1 [15]
- mov x1, x2 ;1 [16] x2 contains last sampled (stuffed) bit
- in x2, USBIN ;1 [17] <-- sample bit 1 again
- ori shift, 0x01 ;1 [18]
- nop ;1 [19]
- rjmp didUnstuff0 ;1 [20];2 [20]
- unstuff1: ;1 (branch taken)
- mov x2, x1 ;1 [21] x1 contains last sampled (stuffed) bit
- andi x3, ~0x02 ;1 [22]
- ori shift, 0x02 ;1 [23]
- nop ;1 [24]
- in x1, USBIN ;1 [25] <-- sample bit 2 again
- nop ;1 [26]
- rjmp didUnstuff1 ;1 [27];2 [27]
- unstuff2: ;1 (branch taken)
- andi x3, ~0x04 ;1 [29]
- ori shift, 0x04 ;1 [30]
- mov x1, x2 ;1 [31] x2 contains last sampled (stuffed) bit
- nop ;1 [32]
- in x2, USBIN ;1 [33] <-- sample bit 3
- nop ;1 [34]
- rjmp didUnstuff2 ;1 [35];2 [35]
- unstuff3: ;1 (branch taken)
- in x2, USBIN ;1 [34] <-- sample stuffed bit 3 [one cycle too late]
- andi x3, ~0x08 ;1 [35]
- ori shift, 0x08 ;1 [36]
- nop ;1 [37]
- rjmp didUnstuff3 ;1 [38];2 [38]
- unstuff4: ;1 (branch taken)
- andi x3, ~0x10 ;1 [40]
- in x1, USBIN ;1 [41] <-- sample stuffed bit 4
- ori shift, 0x10 ;1 [42]
- nop ;1 [43]
- rjmp didUnstuff4 ;1 [44];2 [44]
- unstuff5: ;1 (branch taken)
- andi x3, ~0x20 ;1 [48]
- in x2, USBIN ;1 [49] <-- sample stuffed bit 5
- ori shift, 0x20 ;1 [50]
- nop ;1 [51]
- rjmp didUnstuff5 ;1 [52];2 [52]
- unstuff6: ;1 (branch taken)
- andi x3, ~0x40 ;1 [56]
- in x1, USBIN ;1 [57] <-- sample stuffed bit 6
- ori shift, 0x40 ;1 [58]
- nop ;1 [59]
- rjmp didUnstuff6 ;1 [60];2 [60]
- ; extra jobs done during bit interval:
- ; bit 0: store, clear [SE0 is unreliable here due to bit dribbling in hubs]
- ; bit 1: se0 check
- ; bit 2: overflow check
- ; bit 3: recovery from delay [bit 0 tasks took too long]
- ; bit 4: none
- ; bit 5: none
- ; bit 6: none
- ; bit 7: jump, eor
- rxLoop:
- eor x3, shift ;1 [0] reconstruct: x3 is 0 at bit locations we changed, 1 at others
- in x1, USBIN ;1 [1] <-- sample bit 0
- nop ;1 [2]
- st y+, x3 ;1 [3];2 [3] store data
- ser x3 ;1 [4]
- nop ;1 [5]
- eor x2, x1 ;1 [6]
- bst x2, USBMINUS;1 [7]
- bld shift, 0 ;1 [8]
- in x2, USBIN ;1 [9] <-- sample bit 1 (or possibly bit 0 stuffed)
- andi x2, USBMASK ;1 [10]
- breq se0 ;1 [11] SE0 check for bit 1
- andi shift, 0xf9 ;1 [12]
- didUnstuff0:
- breq unstuff0 ;1 [13]
- eor x1, x2 ;1 [14]
- bst x1, USBMINUS;1 [15]
- bld shift, 1 ;1 [16]
- rxbit2:
- in x1, USBIN ;1 [17] <-- sample bit 2 (or possibly bit 1 stuffed)
- andi shift, 0xf3 ;1 [18]
- breq unstuff1 ;1 [19] do remaining work for bit 1
- didUnstuff1:
- subi cnt, 1 ;1 [20]
- brcs overflow ;1 [21] loop control
- eor x2, x1 ;1 [22]
- bst x2, USBMINUS;1 [23]
- bld shift, 2 ;1 [24]
- in x2, USBIN ;1 [25] <-- sample bit 3 (or possibly bit 2 stuffed)
- andi shift, 0xe7 ;1 [26]
- breq unstuff2 ;1 [27]
- didUnstuff2:
- eor x1, x2 ;1 [28]
- bst x1, USBMINUS;1 [29]
- bld shift, 3 ;1 [30]
- didUnstuff3:
- andi shift, 0xcf ;1 [31]
- breq unstuff3 ;1 [32]
- in x1, USBIN ;1 [33] <-- sample bit 4
- eor x2, x1 ;1 [34]
- bst x2, USBMINUS;1 [35]
- bld shift, 4 ;1 [36]
- didUnstuff4:
- andi shift, 0x9f ;1 [37]
- breq unstuff4 ;1 [38]
- nop2 ;2 [40]
- in x2, USBIN ;1 [41] <-- sample bit 5
- eor x1, x2 ;1 [42]
- bst x1, USBMINUS;1 [43]
- bld shift, 5 ;1 [44]
- didUnstuff5:
- andi shift, 0x3f ;1 [45]
- breq unstuff5 ;1 [46]
- nop2 ;2 [48]
- in x1, USBIN ;1 [49] <-- sample bit 6
- eor x2, x1 ;1 [50]
- bst x2, USBMINUS;1 [51]
- bld shift, 6 ;1 [52]
- didUnstuff6:
- cpi shift, 0x02 ;1 [53]
- brlo unstuff6 ;1 [54]
- nop2 ;2 [56]
- in x2, USBIN ;1 [57] <-- sample bit 7
- eor x1, x2 ;1 [58]
- bst x1, USBMINUS;1 [59]
- bld shift, 7 ;1 [60]
- didUnstuff7:
- cpi shift, 0x04 ;1 [61]
- brsh rxLoop ;2 [63] loop control
- unstuff7:
- andi x3, ~0x80 ;1 [63]
- ori shift, 0x80 ;1 [64]
- in x2, USBIN ;1 [65] <-- sample stuffed bit 7
- nop2 ;2 [67];1 [66]
- rjmp didUnstuff7 ;1 [68];2 [68]
- macro POP_STANDARD ; 12 cycles
- pop cnt
- pop x3
- pop x2
- pop x1
- pop shift
- pop YH
- endm
- macro POP_RETI ; 5 cycles
- pop x5
- pop YL
- out SREG, YL
- pop YL
- endm
- #include "asmcommon.inc"
- ; Transmitting data
- txByteLoop:
- txBitloop:
- stuffN1Delay: ; [03]
- ror shift ;[-5] [11] [59]
- brcc doExorN1 ;[-4] [60]
- subi x4, 1 ;[-3]
- brne commonN1 ;[-2]
- lsl shift ;[-1] compensate ror after rjmp stuffDelay
- nop ;[00] stuffing consists of just waiting 8 cycles
- nop
- rjmp stuffN1Delay ;[01] after ror, C bit is reliably clear
- sendNakAndReti: ;0 [-19] 19 cycles until SOP
- ldi x3, USBPID_NAK ;1 [-18]
- nop ;1 [-17]
- rjmp usbSendX3 ;1;[-16];2 [-16]
- sendAckAndReti: ;0 [-19] 19 cycles until SOP
- ldi x3, USBPID_ACK ;1 [-18]
- nop ;1 [-17]
- rjmp usbSendX3 ;1 [-16];2 [-16]
- sendCntAndReti: ;0 [-17] 17 cycles until SOP
- nop
- mov x3, cnt ;1 [-16]
- usbSendX3: ;0 [-16]
- ldi YL, 20 ;1 [-15] 'x3' is R20
- ldi YH, 0 ;1 [-14]
- ldi cnt, 2 ;1 [-13]
- ; rjmp usbSendAndReti fallthrough
- ; USB spec says:
- ; idle = J
- ; J = (D+ = 0), (D- = 1) or USBOUT = 0x01
- ; K = (D+ = 1), (D- = 0) or USBOUT = 0x02
- ; Spec allows 7.5 bit times from EOP to SOP for replies (= 60 cycles)
- ;usbSend:
- ;pointer to data in 'Y'
- ;number of bytes in 'cnt' -- including sync byte
- ;uses: x1...x2, x4, shift, cnt, Y [x1 = mirror USBOUT, x2 = USBMASK, x4 = bitstuff cnt]
- ;Numbers in brackets are time since first bit of sync pattern is sent (start of instruction)
- usbSendAndReti:
- in x2, USBDDR ;[-12] 12 cycles until SOP
- ori x2, USBMASK ;[-11]
- sbi USBOUT, USBMINUS ;[-10] prepare idle state; D+ and D- must have been 0 (no pullups)
- nop ;[-9]
- out USBDDR, x2 ;[-8] <--- acquire bus
- in x1, USBOUT ;[-7] port mirror for tx loop
- ldi shift, 0x40 ;[-6] sync byte is first byte sent (we enter loop after ror)
- ldi x2, USBMASK ;[-5]
- push x4 ;[-4]
- nop ;[-3]
- doExorN1:
- eor x1, x2 ;[-2] [06] [62]
- ldi x4, 6 ;[-1] [07] [63]
- commonN1:
- stuffN2Delay:
- out USBOUT, x1 ;[00] [08] [64] <--- set bit
- ror shift ;[01]
- brcc doExorN2 ;[02]
- subi x4, 1 ;[03]
- brne commonN2 ;[04]
- lsl shift ;[05] compensate ror after rjmp stuffDelay
- nop ;[06]
- rjmp stuffN2Delay ;[07];[06] after ror, C bit is reliably clear
- doExorN2:
- eor x1, x2 ;[04] [12]
- ldi x4, 6 ;[05] [13]
- commonN2:
- nop ;[06] [14]
- subi cnt, 171 ;[07] [15] trick: (3 * 171) & 0xff = 1
- out USBOUT, x1 ;[08] [16] <--- set bit
- brcs txBitloop ;[09] [25] [41]
- stuff6Delay:
- ror shift ;[42] [50]
- brcc doExor6 ;[43]
- subi x4, 1 ;[44]
- brne common6 ;[45]
- lsl shift ;[46] compensate ror after rjmp stuffDelay
- nop2 ;[48] stuffing consists of just waiting 8 cycles
- rjmp stuff6Delay ;[49] after ror, C bit is reliably clear
- doExor6:
- eor x1, x2 ;[45] [53]
- ldi x4, 6 ;[46]
- common6:
- stuff7Delay:
- ror shift ;[47] [55]
- out USBOUT, x1 ;[48] <--- set bit
- brcc doExor7 ;[49]
- subi x4, 1 ;[50]
- brne common7 ;[51]
- lsl shift ;[52] compensate ror after rjmp stuffDelay
- nop
- rjmp stuff7Delay ;[53] after ror, C bit is reliably clear
- doExor7:
- eor x1, x2 ;[51] [59]
- ldi x4, 6 ;[52]
- common7:
- ld shift, y+ ;[53]
- nop ;[54]
- tst cnt ;[55];[55]
- out USBOUT, x1 ;[56];[56] <--- set bit
- ;brne txByteLoop ;[57]
- breq makeSE0 ;[57]
- rjmp txByteLoop ;[58]
- makeSE0:
- ;make SE0:
- cbr x1, USBMASK ;[59] prepare SE0 [spec says EOP may be 15 to 18 cycles]
- lds x2, usbNewDeviceAddr;[60]
- lsl x2 ;[62] we compare with left shifted address
- subi YL, 2 + 20 ;[63] Only assign address on data packets, not ACK/NAK in x3
- out USBOUT, x1 ;[00] <-- out SE0 -- from now 2 bits = 16 cycles until bus idle
- sbci YH, 0 ;[01]
- ;2006-03-06: moved transfer of new address to usbDeviceAddr from C-Code to asm:
- ;set address only after data packet was sent, not after handshake
- breq skipAddrAssign ;[02]
- sts usbDeviceAddr, x2 ; if not skipped: SE0 is one cycle longer
- skipAddrAssign:
- ;end of usbDeviceAddress transfer
- ldi x2, 1<<USB_INTR_PENDING_BIT;[04] int0 occurred during TX -- clear pending flag
- USB_STORE_PENDING(x2) ;[05]
- ori x1, USBIDLE ;[06]
- in x2, USBDDR ;[07]
- cbr x2, USBMASK ;[08] set both pins to input
- mov x3, x1 ;[09]
- cbr x3, USBMASK ;[10] configure no pullup on both pins
- pop x4 ;[11]
- nop2 ;[12]
- nop2 ;[14]
- out USBOUT, x1 ;[16] <-- out J (idle) -- end of SE0 (EOP signal)
- out USBDDR, x2 ;[17] <-- release bus now
- out USBOUT, x3 ;[18] <-- ensure no pull-up resistors are active
- rjmp doReturn
- ;延时8个时钟周期从调用到返回
- ;rcall delay8 ;[0] [8]
- ;xxx ;[0]
- delay8:
- nop ;[1] [9]
- nop ;[2] [10]
- nop ;[3] [11]
- nop ;[4] [12]
- nop ;[1] [9]
- ret ;[6] [14]
- #endif
复制代码 只为测速度这个也许还能用
不过跑32m用这种代码有些浪费了, 最好从usbdrvasm18-crc.inc类似的文件移植
之前测试内部rc在常温下还是很稳定的 不过温度如果变化大些就会出问题
我的想法刚好相反用PL2303+LGT完成编程器, 波特率到5000kbps或1mbps 这个速度是vusb不能比的
目前用上面这种方案使用swim协议读stm8 8kflash只要500多ms swim还是跑在低速位格式![](static/image/smiley/default/lol.gif) |
