将ucGUI 移植到 STM32F407 RT-thread1.1 系统下,ucGUI 刷屏才得分 4xxxxxx,而在相同情况下 把rt-thread 换成ucos ucGUI 刷屏得分能到1xxxxxxx,相差几乎3倍,lcd驱动ucgui版本硬件都是一样的,就是所用的操作系统不一样而已,不知问题出在哪里?
rt-thread的ucGUI移植部分:
#include "GUI.h"
#include "GUI_X.h"
#include <rtthread.h>
* Global data
volatile int OS_TimeMS;
static rt_sem_t DispSem;
//static rt_mailbox_t EventMbox;
* Timing:
* GUI_X_GetTime()
* GUI_X_Delay(int)
Some timing dependent routines require a GetTime
and delay function. Default time unit (tick), normally is
1 ms.
int GUI_X_GetTime(void) {
return ((int)rt_tick_get());
void GUI_X_Delay(int ms) {
rt_tick_t temp;
temp=(ms*1000)/RT_TICK_PER_SECOND;
rt_thread_delay(temp);
* GUI_X_Init()
* Note:
* GUI_X_Init() is called from GUI_Init is a possibility to init
* some hardware which needs to be up and running before the GUI.
* If not required, leave this routine blank.
void GUI_X_Init(void) {}
* GUI_X_ExecIdle
* Note:
* Called if WM is in idle state
void GUI_X_ExecIdle(void)
rt_thread_delay(1);
U32 GUI_X_GetTaskId (void)
return 0;
void GUI_X_InitOS (void)
DispSem = rt_sem_create("sem",1,0);
//EventMbox = rt_mb_create("mbx",0,0);
void GUI_X_Lock (void)
rt_sem_take(DispSem,RT_WAITING_FOREVER);
void GUI_X_Unlock (void)
rt_sem_release(DispSem);
* Logging: OS dependent
Note:
Logging is used in higher debug levels only. The typical target
build does not use logging and does therefor not require any of
the logging routines below. For a release build without logging
the routines below may be eliminated to save some space.
(If the linker is not function aware and eliminates unreferenced
functions automatically)
void GUI_X_Log (const char *s) { GUI_USE_PARA(s); }
void GUI_X_Warn (const char *s) { GUI_USE_PARA(s); }
void GUI_X_ErrorOut(const char *s) { GUI_USE_PARA(s); } |
