烧写mcs文件到FLASH XCF128X出错,使用的是xilinx Virtex-6 FPGA (Slave SelectMAP Configuration Mode )请大神看看是什么原因,如何解决。万分感谢!!!烧写报告如下:
Welcome to iMPACT
iMPACT Version: 13.4
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusbdfwu.sys found.
Driver version: src=1027, dest=1027.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 X86 32bit SYS 14:35:41, version = 1021.
Cable PID = 0008.
Max current requested during enumeration is 280 mA.
Type = 0x0605.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1027.
File version of C:/Xilinx/13.4/ISE_DS/ISE/data/xusbdfwu.hex = 1100.
Firmware hex file version = 1100.
Downloading C:/Xilinx/13.4/ISE_DS/ISE/data/xusbdfwu.hex.
Downloaded firmware version = 1100.
PLD file version = 0012h.
PLD version = 0012h.
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
Type = 0x0605.
ESN not available for this cable.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 2013/5/31 17:57:54
// *** BATCH CMD : Identify -inferir
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc6vlx240t, Version : 8
INFO:iMPACT:1777 -
Reading C:/Xilinx/13.4/ISE_DS/ISE/virtex6/data/xc6vlx240t.bsd...
INFO:iMPACT:501 - '1': Added Device xc6vlx240t successfully.
done.
// *** BATCH CMD : identifyMPM
Selected part: XCF128X
// *** BATCH CMD : attachflash -position 1 -bpi "XCF128X"
// *** BATCH CMD : assignfiletoattachedflash -position 1 -file "D:/WW/lifu_mcs_wenjian/Untitled_pcie_ok.mcs"
INFO:iMPACT - Current time: 2013/5/31 17:58:05
// *** BATCH CMD : Program -p 1 -dataWidth 16 -rs1 NONE -rs0 NONE -bpionly -e -v -loadfpga
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading: 39.05 C, Min. Reading: 30.20 C, Max. Reading: 39.55 C
1: VCCINT Supply: Current Reading: 0.993 V, Min. Reading: 0.973 V, Max. Reading: 1.011 V
1: VCCAUX Supply: Current Reading: 2.502 V, Min. Reading: 2.499 V, Max. Reading: 2.511 V
'1': BPI access core not detected. BPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/13.4/ISE_DS/ISE/virtex6/data/xc6vlx240t_jbpi.cor.
'1': Downloading core...
Match_cycle = NoWait.
Match cycle: NoWait
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1111 0111 1110 0000 1011 1100 0000
INFO:iMPACT:2492 - '1': Completed downloading core to device.
Current cable speed is set to 6.000 Mhz.
Cable speed is default to 3Mhz or lower for BPI operations.
Current cable speed is set to 3.000 Mhz.
Setting Flash Control Pins ...
Setting Configuration Register ...
Populating BPI common flash interface ...
INFO:iMPACT - Core Status Register: [80] : 1
INFO:iMPACT - Core Status Register: [81] : 0
INFO:iMPACT - Core Status Register: [82] : 0
INFO:iMPACT - Core Status Register: [83] : 1
INFO:iMPACT - Core Status Register: [84] : 0
INFO:iMPACT - Core Status Register: [85] : 0
INFO:iMPACT - Core Status Register: [86] : 0
INFO:iMPACT - Core Status Register: [87] : 0
INFO:iMPACT - Core Status Register: [88] : 0
INFO:iMPACT - Core Status Register: [89] : 0
INFO:iMPACT - Core Status Register: [90] : 0
INFO:iMPACT - Core Status Register: [91] : 0
INFO:iMPACT - Core Status Register: [92] : 0
INFO:iMPACT - Core Status Register: [93] : 0
INFO:iMPACT - Core Status Register: [94] : 0
INFO:iMPACT - Core Status Register: [95] : 0
'1': Errors encountered while loading microprogram.
INFO:iMPACT - Failed to query common flash interface.
Elapsed time = 26 sec. |
