发表于 2013-5-28 17:42:04
问题多多,我编译老是出错,解决一个又一个,我编译好的固件烧进去,系统跑了,但发现GOAHEAD无法打开,SDK的来源可以说是没问题,大联大的FAE给的,从3600到4110我全都有,发现只有3600可以选5350之后用默认配置可以顺利编译,其他的都需要小修改;
我试着编译进去MINIUPNP,和USB-MODESWITCH都不行,都需要小修改;
编译过了吧,兴致勃勃烧进去,发现GOAHEAD无法打开,看到提示如下:大大们帮我看下:
0x00000000-0x00030000 : "Bootloader"
0x00030000-0x00040000 : "Config"
0x00040000-0x00050000 : "Factory"
0x00050000-0x00157e29 : "Kernel"
mtd: partition "Kernel" doesn't end on an erase block -- force read-only
0x00157e29-0x01000000 : "RootFS"
mtd: partition "RootFS" extends beyond the end of device "raspi" -- size truncated to 0x6a81d7
mtd: partition "RootFS" doesn't start on an erase block boundary -- force read-only
0x00050000-0x01000000 : "Kernel_RootFS"
mtd: partition "Kernel_RootFS" extends beyond the end of device "raspi" -- size truncated to 0x7b0000
Load Timer Module(Wdg/Soft)
squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
squashfs: LZMA suppport for slax.org by jro
io scheduler noop registered (default)
Ralink gpio driver initialized
HDLC line discipline: version $Revision: 1.1.1.1 $, maxframe=4096
N_HDLC line discipline registered.
Serial: 8250/16550 driver $Revision: 1.8 $ 2 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xb0000500 (irq = 37) is a 16550A
serial8250: ttyS1 at I/O 0xb0000c00 (irq = 12) is a 16550A
loop: loaded (max 8 devices)
rdm_major = 253
Ralink APSoC Ethernet Driver Initilization. v2.1 256 rx/tx descriptors allocated, mtu = 1500!
MAC_ADRH -- : 0x0000000a
MAC_ADRL -- : 0xeb380d4e
PROC INIT OK!
IMQ starting with 2 devices...
IMQ driver loaded successfully.
Hooking IMQ after NAT on PREROUTING.
Hooking IMQ before NAT on POSTROUTING.
PPP generic driver version 2.4.2
PPP BSD Compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V0.17
PPTP driver version 0.8.1
block2mtd: version $Revision: 1.1.1.1 $
nf_conntrack version 0.5.0 (128 buckets, 1024 max)
ip_tables: (C) 2000-2006 Netfilter Core Team, Type=Restricted Cone
TCP cubic registered
NET: Registered protocol family 1
NET: Registered protocol family 10
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 116k freed
init started: BusyBox v1.12.1 (2013-05-25 14:22:02 CST)
starting pid 13, tty '': '/etc_ro/rcS'
Algorithmics/MIPS FPU Emulator v1.5
devpts: called with bogus options
Welcome to
_______ _______ ___ __ ____ _ _ ___
| ___ \| __ || | |__|| \ | || | / /
| |___| || |__| || |__ __ | \| || |/ /
| _ /| _ || || || |\ || \
|__| \__\|__| |__||______||__||_| \____||_|\___\
=System Architecture Department=
starting pid 23, tty '/dev/ttyS1': '/bin/sh'
BusyBox v1.12.1 (2013-05-25 14:22:02 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# internet.sh
Password for 'admin' changed
rmmod: ralink_wdt: No such file or directory
rmmod: cls: No such file or directory
rmmod: hw_nat: No such file or directory
rmmod: raeth: No such file or directory
insmod: bridge.ko: module not found
insmod: mii.ko: module not found
insmod: raeth.ko: module not found
phy_tx_ring = 0x009a6000, tx_ring = 0xa09a6000
phy_rx_ring0 = 0x009a7000, rx_ring0 = 0xa09a7000
RT305x_ESW: Link Status Changed
##### disable 1st wireless interface #####
rmmod: rt2860v2_ap_net: No such file or directory
rmmod: rt2860v2_ap: No such file or directory
rmmod: rt2860v2_ap_util: No such file or directory
rmmod: rt2860v2_sta_net: No such file or directory
rmmod: rt2860v2_sta: No such file or directory
rmmod: rt2860v2_sta_util: No such file or directory
insmod: rt2860v2_ap_util.ko: module not found
rt2860v2_ap: module license 'unspecified' taints kernel.
=== pAd = c004c000, size = 804848 ===
<-- RTMPAllocAdapterBlock, Status=0
insmod: rt2860v2_ap_net.ko: module not found
rmmod: nf_nat_pptp: No such file or directory
rmmod: nf_conntrack_pptp: No such file or directory
rmmod: nf_nat_proto_gre: No such file or directory
rmmod: nf_conntrack_proto_gre: No such file or directory
insmod: nf_conntrack_proto_gre.ko: module not found
insmod: nf_nat_proto_gre.ko: module not found
insmod: nf_conntrack_pptp.ko: module not found
insmod: nf_nat_pptp.ko: module not found
RX DESC a0900000 size = 2048
<-- RTMPAllocTxRxRingMemory, Status=0
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
1. Phy Mode = 9
2. Phy Mode = 9
3. Phy Mode = 9
pAd->TxPowerCtrl.bInternalTxALC == FALSE !
MCS Set = ff 00 00 00 01
SYNC - BBP R4 to 20MHz.l
The 2-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 2
Main bssid = 00:0a:eb:38:0d:4d
<==== rt28xx_init, Status=0
0x1300 = 00064380
vconfig: ioctl error for rem: Invalid argument
rmmod: 8021q: No such file or directory
insmod: 8021q.ko: module not found
eth2.2: Setting MAC address to 00 0a eb 38 0d 52.
device eth2 entered promiscuous mode
VLAN (eth2.2): Setting underlying device (eth2) to promiscious mode.
ifconfig: ioctl 0x8913 failed: No such device
brctl: bridge br0: No such device or address
##### config Ralink ESW vlan partition (LLLLW) #####
switch reg write offset=14, value=405555
switch reg write offset=50, value=2001
switch reg write offset=98, value=7f3f
switch reg write offset=e4, value=3f
switch reg write offset=40, value=1001
switch reg write offset=44, value=1001
switch reg write offset=48, value=1002
switch reg write offset=70, value=ffff506f
done.
device ra0 entered promiscuous mode
eth2.1: dev_set_promiscuity(master, 1)
device eth2.1 entered promiscuous mode
udhcpc (v1.12.1) started
br0: port 2(eth2.1) entering learning state
br0: port 1(ra0) entering learning state
ifconfig: ioctl 0x8914 failed: Cannot assign requested address
/sbin/lan.sh: line 63: hostname: not found
br0: topology change detected, propagating
br0: port 2(eth2.1) entering forwarding state
br0: port 1(ra0) entering forwarding state
killall: udhcpd: no process killed
Set: phy[0].reg[0] = 3900
Set: phy[1].reg[0] = 3900
Set: phy[2].reg[0] = 3900
Set: phy[3].reg[0] = 3900
Set: phy[0].reg[0] = 3100
Set: phy[1].reg[0] = 3100
Set: phy[2].reg[0] = 3100
Set: phy[3].reg[0] = 3100
libupnp: using UDP SSDP_PORT = 1900
upnpd[819]: UPnP SDK Successfully Initialized.
Jan 1 00:00:17 upnpd[819]: UPnP SDK Successfully Initialized.
upnpd[819]: Succesfully set the Web Server Root Directory.
Jan 1 00:00:17 upnpd[819]: Succesfully set the Web Server Root Directory.
upnpd[819]: IGD root device successfully registered.
Jan 1 00:00:17 upnpd[819]: IGD root device successfully registered.
killall rt2860apd 1>/dev/null 2>&1
iptables -F -t filter 1>/dev/null 2>&1
iptables -D FORWARD -j macipport_filter 1>/dev/null 2>&1
iptables -F macipport_filter 1>/dev/null 2>&1
iptables -D FORWARD -j web_filter 1>/dev/null 2>&1
iptables -F web_filter 1>/dev/null 2>&1
iptables -D FORWARD -j malicious_filter 1>/dev/null 2>&1
iptables -F malicious_filter 1>/dev/null 2>&1
iptables -D INPUT -j malicious_input_filter 1>/dev/null 2>&1
iptables -F malicious_input_filter 1>/dev/null 2>&1
iptables -P INPUT ACCEPT
iptables -P OUTPUT ACCEPT
iptables -P FORWARD ACCEPT
iptables -t filter -N web_filter 1>/dev/null 2>&1
iptables -t filter -N macipport_filter 1>/dev/null 2>&1
iptables -t filter -N malicious_filter 1>/dev/null 2>&1
iptables -t filter -N synflood_filter 1>/dev/null 2>&1
iptables -t filter -N malicious_input_filter 1>/dev/null 2>&1
iptables -t filter -N synflood_input_filter 1>/dev/null 2>&1
iptables -t filter -A FORWARD -j web_filter 1>/dev/null 2>&1
iptables -t filter -A FORWARD -j macipport_filter 1>/dev/null 2>&1
iptables -t filter -A FORWARD -j malicious_filter 1>/dev/null 2>&1
iptables -t filter -A malicious_filter -p tcp --syn -j synflood_filter 1>/dev/null 2>&1
iptables -t filter -A INPUT -j malicious_input_filter 1>/dev/null 2>&1
iptables -t filter -A malicious_input_filter -p tcp --syn -j synflood_input_filter 1>/dev/null 2>&1
iptables -A FORWARD -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 1>/dev/null 2>&1
iptables -A malicious_input_filter -i eth2.2 -p tcp --dport 80 -j DROP
/bin/super_dmz -f
upnpd[819]: Advertisements Sent. Listening for requests ...
Jan 1 00:00:19 upnpd[819]: Advertisements Sent. Listening for requests ...
sh: arptables: not found
superdmz:Can't get WAN gateway
iptables -t nat -D PREROUTING -j port_forward 1>/dev/null 2>&1
iptables -t nat -F port_forward 1>/dev/null 2>&1; iptables -t nat -X port_forward 1>/dev/null 2>&1
iptables -t nat -D PREROUTING -j DMZ 1>/dev/null 2>&1
iptables -t nat -F DMZ 1>/dev/null 2>&1; iptables -t nat -X DMZ 1>/dev/null 2>&1
iptables -t nat -N port_forward 1>/dev/null 2>&1; iptables -t nat -I PREROUTING 1 -j port_forward 1>/dev/null 2>&1
iptables -t nat -N DMZ 1>/dev/null 2>&1; iptables -t nat -I PREROUTING 2 -j DMZ 1>/dev/null 2>&1
ntp.sh
greenap.sh init
ddns.sh
kill -9 `cat /var/run/wscd.pid.ra0`
cat: can't open '/var/run/wscd.pid.ra0': No such file or directory
kill: you need to specify whom to kill
iwpriv ra0 set WscConfMode=0 1>/dev/null 2>&1
route delete 239.255.255.250 1>/dev/null 2>&1
killall -q klogd
killall -q syslogd
syslogd -C8 1>/dev/null 2>&1
klogd 1>/dev/null 2>&1
killall -q zebra
killall -q ripd
/bin/qos_run
gohead.c: Can't get host address |
