uint ad_data;
uchar ge,shi,bai,qian;
uint shu;
void wei();
void xianshi();
void hc595_out(unsigned char out_data);
uint ADC_Convert(void);
const unsigned char Data[]={0x3f,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6f};//,0x66, //0,1,2,3,4
//0x6D,0x7D,0x07,0x7F,0x6F, //5,6,7,8,9
//0x77,0x7C,0x39,0x5E,0x79,0x71};
int main(void)
DDRF&=0xfe;
ADMUX = 0X40;
ADCSRA = 0XE0;
DDRB=0xff;
PORTB=0xf8;
DDRC=0x80;
PORTC &=~ 0x80;
PORTB |= 0xf0;
PORTB&=~HC_595_SRCLk;
PORTB&=~HC_595_RCLK;
ad_data = ADC_Convert();
wei();
xianshi();
void hc595_out(unsigned char data)
uchar i,j;
j=0x80;
for(i=0;i<8;i++)
//PORTB=(0xf8&Data[p]);
if((data&j)>0)
PORTB |= HC_595_SER;
PORTB &=~ HC_595_SER;
asm("nop");
j=j>>1;
asm("nop");
PORTB |= HC_595_SRCLk;
asm("nop");
PORTB &=~ HC_595_SRCLk;
PORTB |= HC_595_RCLK;
asm("nop");
asm("nop");
PORTB &=~ HC_595_RCLK;
void wei()
uint adc_result;
adc_result=(unsigned long)ad_data*5000/1024;
ge = adc_result%10;
shi = adc_result%100/10;
bai = adc_result%1000/100;
qian = adc_result/1000;
void xianshi()
_delay_ms(10);
PORTB &=~0XF0;
PORTB |= 1<<4;
hc595_out(Data[ge]);
_delay_ms(10);
PORTB &=~0XF0;
PORTB |= 1<<5;
hc595_out(Data[shi]);
_delay_ms(10);
PORTB &=~0XF0;
PORTB |= 1<<6;
hc595_out(Data[bai]);
_delay_ms(10);
PORTB &=~0XF0;
PORTB |= 1<<7;
hc595_out(Data[qian]);
uint temp1,temp2;
temp1 = ADCL;
temp2 = ADCH;
temp2 = (temp2<<8)|temp1;
return (temp2);
