发表于 2013-5-3 10:24:02
// C8051F390_defs.h
// Copyright 2011, Silicon Laboratories, Inc.
// http://www.silabs.com
// Program Description:
// Register/bit definitions for the C8051F39x and C8051F37x family.
// **Important Note**: The compiler_defs.h header file should be included
// before including this header file.
// Target: C8051F39x/C8051F37x
// Tool chain: Generic
// Command Line: None
// Release 0.2 - 20 AUG 2012 (TP)
// -Added #define for _XPAGE to provide support for SDCC memory paging
// (pdata)
// Release 0.1 - 23 NOV 2011 (BD)
// -Initial revision (beta)
// Header File Preprocessor Directive
#ifndef C8051F390_DEFS_H
#define C8051F390_DEFS_H
// Byte Registers
SFR (ACC, 0xE0); //Accumulator
SFR (ADC0CF, 0xBC); //ADC0 Configuration
SFR (ADC0CN, 0xE8); //ADC0 Control
SFR (ADC0GTH, 0xC4); //ADC0 Greater-Than Compare High
SFR (ADC0GTL, 0xC3); //ADC0 Greater-Than Compare Low
SFR (ADC0H, 0xBE); //ADC0 High
SFR (ADC0L, 0xBD); //ADC0 Low
SFR (ADC0LTH, 0xC6); //ADC0 Less-Than Compare Word High
SFR (ADC0LTL, 0xC5); //ADC0 Less-Than Compare Word Low
SFR (AMX0N, 0xBA); //AMUX0 Negative Channel Select
SFR (AMX0P, 0xBB); //AMUX0 Positive Channel Select
SFR (B, 0xF0); //B Register
SFR (CKCON, 0x8E); //Clock Control
SFR (CKCON1, 0xF4); //Clock Control 1
SFR (CLKSEL, 0xA9); //Clock Select
SFR (CPT0CN, 0x9B); //Comparator0 Control
SFR (CPT0MD, 0x9D); //Comparator0 Mode Selection
SFR (CPT0MX, 0x9F); //Comparator0 MUX Selection
SFR (CRC0AUTO, 0xDD); //
SFR (CRC0CN, 0xDF); //
SFR (CRC0CNT, 0xDE); //
SFR (CRC0DAT, 0x9E); //
SFR (CRC0FLIP, 0x9A); //
SFR (CRC0IN, 0x9C); //
SFR (DERIVID, 0xAB); //Derivative ID
SFR (DPH, 0x83); //Data Pointer High
SFR (DPL, 0x82); //Data Pointer Low
SFR (EIE1, 0xE6); //Extended Interrupt Enable 1
SFR (EIE2, 0xAF); //Extended Interrupt Enable 2
SFR (EIP1, 0xF6); //Extended Interrupt Priority 1
SFR (EIP1H, 0x85); //Extended Interrupt Priority High 1
SFR (EIP2, 0xBF); //Extended Interrupt Priority 2
SFR (EIP2H, 0x86); //Extended Interrupt Priority High 2
SFR (EMI0CN, 0xAA); //External Memory Interface Control
SFR (FLKEY, 0xB7); //Flash Lock and Key
SFR (FLSCL, 0xB6); //Flash Scale
SFR (IDA0CN, 0xB9); //IDAC0 Control
SFR (IDA0H, 0x97); //IDAC0 High Byte
SFR (IDA0L, 0x96); //IDAC0 Low Byte
SFR (IDA1CN, 0xB9); //IDAC1 Control
SFR (IDA1H, 0x97); //IDAC1 High Byte
SFR (IDA1L, 0x96); //IDAC1 Low Byte
SFR (IE, 0xA8); //Interrupt Enable
SFR (IP, 0xB8); //Interrupt Priority
SFR (IPH, 0x84); //Interrupt Priority High
SFR (IT01CF, 0xE4); //INT0/INT1 Configuration
SFR (OSCICL, 0xB3); //Internal Oscillator Calibration
SFR (OSCICN, 0xB2); //Internal Oscillator Control
SFR (OSCLCN, 0xE3); //Internal Low-Frequency Osc Control
SFR (OSCXCN, 0xB1); //External Oscillator Control
SFR (P0, 0x80); //Port 0 Latch
SFR (P0MASK, 0xFE); //Port 0 Mask Register
SFR (P0MAT, 0xFD); //Port 0 Match Register
SFR (P0MDIN, 0xF1); //Port 0 Input Mode Configuration
SFR (P0MDOUT, 0xA4); //Port 0 Output Mode Configuration
SFR (P0SKIP, 0xD4); //Port 0 Skip
SFR (P1, 0x90); //Port 1 Latch
SFR (P1MASK, 0xEE); //Port 1 Mask Register
SFR (P1MAT, 0xED); //Port 1 Match Register
SFR (P1MDIN, 0xF2); //Port 1 Input Mode Configuration
SFR (P1MDOUT, 0xA5); //Port 1 Output Mode Configuration
SFR (P1SKIP, 0xD5); //Port 1 Skip
SFR (P2, 0xA0); //Port 2 Latch
SFR (P2MDIN, 0xF3); //Port 2 Input Mode Configuration
SFR (P2MDOUT, 0xA6); //Port 2 Output Mode Configuration
SFR (P2SKIP, 0xD6); //Port 2 Skip
SFR (PCA0CLR, 0xCE); //PCA Comparator Clear Control
SFR (PCA0CN, 0xD8); //PCA Control
SFR (PCA0CPH0, 0xFC); //PCA Capture 0 High
SFR (PCA0CPH1, 0xEA); //PCA Capture 1 High
SFR (PCA0CPH2, 0xEC); //PCA Capture 2 High
SFR (PCA0CPL0, 0xFB); //PCA Capture 0 Low
SFR (PCA0CPL1, 0xE9); //PCA Capture 1 Low
SFR (PCA0CPL2, 0xEB); //PCA Capture 2 Low
SFR (PCA0CPM0, 0xDA); //PCA Module 0 Mode Register
SFR (PCA0CPM1, 0xDB); //PCA Module 1 Mode Register
SFR (PCA0CPM2, 0xDC); //PCA Module 2 Mode Register
SFR (PCA0H, 0xFA); //PCA Counter High
SFR (PCA0L, 0xF9); //PCA Counter Low
SFR (PCA0MD, 0xD9); //PCA Mode
SFR (PCA0PWM, 0xF7); //PCA0 PWM Control
SFR (PCON, 0x87); //Power Control
SFR (PFE0CN, 0xB5); //Prefetch Engine Control
SFR (PSCTL, 0x8F); //Program Store R/W Control
SFR (PSW, 0xD0); //Program Status Word
SFR (REF0CN, 0xD1); //Voltage Reference Control
SFR (REG0CN, 0xC9); //Voltage Regulator Control
SFR (REVISION, 0xAC); //Revision
SFR (RSTSRC, 0xEF); //Reset Source Configuration/Status
SFR (SBUF0, 0x99); //UART0 Data Buffer
SFR (SCON0, 0x98); //UART0 Control
SFR (SFRPAGE, 0xA7); //SFR Page Select
SFR (SFRPGCN, 0xCF); //SFR Page Control
SFR (SFRSTACK, 0xD3); //SFR Page Stack
SFR (SMB0ADM, 0xE7); //SMBus0 Slave Address Mask
SFR (SMB0ADR, 0xD7); //SMBus0 Slave Address
SFR (SMB0CF, 0xC1); //SMBus0 Configuration
SFR (SMB0CN, 0xC0); //SMBus0 Control
SFR (SMB0DAT, 0xC2); //SMBus0 Data
SFR (SMB1ADM, 0xE7); //SMBus1 Slave Address Mask
SFR (SMB1ADR, 0xD7); //SMBus1 Slave Address
SFR (SMB1CF, 0xC1); //SMBus1 Configuration
SFR (SMB1CN, 0xC0); //SMBus1 Control
SFR (SMB1DAT, 0xC2); //SMBus1 Data
SFR (SMBTC, 0xC7); //SMBus Timing Control
SFR (SN0, 0xAB); //Serial Number 0
SFR (SN1, 0xAC); //Serial Number 1
SFR (SN2, 0xAD); //Serial Number 2
SFR (SN3, 0xAE); //Serial Number 3
SFR (SP, 0x81); //Stack Pointer
SFR (SPI0CFG, 0xA1); //SPI Configuration
SFR (SPI0CKR, 0xA2); //SPI Clock Rate Control
SFR (SPI0CN, 0xF8); //SPI Control
SFR (SPI0DAT, 0xA3); //SPI Data
SFR (TCON, 0x88); //Timer/Counter Control
SFR (TH0, 0x8C); //Timer/Counter 0 High
SFR (TH1, 0x8D); //Timer/Counter 1 High
SFR (TL0, 0x8A); //Timer/Counter 0 Low
SFR (TL1, 0x8B); //Timer/Counter 1 Low
SFR (TMOD, 0x89); //Timer/Counter Mode
SFR (TMR2CN, 0xC8); //Timer/Counter 2 Control
SFR (TMR2H, 0xCD); //Timer/Counter 2 High
SFR (TMR2L, 0xCC); //Timer/Counter 2 Low
SFR (TMR2RLH, 0xCB); //Timer/Counter 2 Reload High
SFR (TMR2RLL, 0xCA); //Timer/Counter 2 Reload Low
SFR (TMR3CN, 0x91); //Timer/Counter 3 Control
SFR (TMR3H, 0x95); //Timer/Counter 3 High
SFR (TMR3L, 0x94); //Timer/Counter 3 Low
SFR (TMR3RLH, 0x93); //Timer/Counter 3 Reload High
SFR (TMR3RLL, 0x92); //Timer/Counter 3 Reload Low
SFR (TMR4CN, 0x91); //Timer/Counter 4 Control
SFR (TMR4H, 0x95); //Timer/Counter 4 High
SFR (TMR4L, 0x94); //Timer/Counter 4 Low
SFR (TMR4RLH, 0x93); //Timer/Counter 4 Reload High
SFR (TMR4RLL, 0x92); //Timer/Counter 4 Reload Low
SFR (TMR5CN, 0xC8); //Timer/Counter 5 Control
SFR (TMR5H, 0xCD); //Timer/Counter 5 High
SFR (TMR5L, 0xCC); //Timer/Counter 5 Low
SFR (TMR5RLH, 0xCB); //Timer/Counter 5 Reload High
SFR (TMR5RLL, 0xCA); //Timer/Counter 5 Reload Low
SFR (TS0CN, 0xD2); //Temperature Sensor Control
SFR (TS0DATL, 0xD2); //Temperature Sensor Data
SFR (TS0DATH, 0xD3); //Temperature Sensor Data
SFR (VDM0CN, 0xFF); //VDD Monitor Control
SFR (XBR0, 0xE1); //Port I/O Crossbar Control 0
SFR (XBR1, 0xE2); //Port I/O Crossbar Control 1
// 16-bit Register Definitions (might not be supported by all compilers)
SFR16 (DP, 0x82); // Data Pointer
SFR16 (TMR3RL, 0x92); // Timer 3 Reload
SFR16 (TMR3, 0x94); // Timer 3 Counter
SFR16 (TMR4RL, 0x92); // Timer 4 Reload
SFR16 (TMR4, 0x94); // Timer 4 Counter
SFR16 (IDA0, 0x96); // IDAC0 Data
SFR16 (IDA1, 0x96); // IDAC1 Data
SFR16 (ADC0, 0xBD); // ADC0 Data
SFR16 (ADC0GT, 0xC3); // ADC0 Greater-Than Compare
SFR16 (ADC0LT, 0xC5); // ADC0 Less-Than Compare
SFR16 (TMR2RL, 0xCA); // Timer 2 Reload
SFR16 (TMR2, 0xCC); // Timer 2 Counter
SFR16 (TMR5RL, 0xCA); // Timer 5 Reload
SFR16 (TMR5, 0xCC); // Timer 5 Counter
SFR16 (TS0DAT, 0xD2); // Temperature Sensor Data
SFR16 (PCA0CP1, 0xE9); // PCA0 Module 1 Capture/Compare
SFR16 (PCA0CP2, 0xEB); // PCA0 Module 2 Capture/Compare
SFR16 (PCA0, 0xF9); // PCA0 Counter
SFR16 (PCA0CP0, 0xFB); // PCA0 Module 0 Capture/Compare
// Address Definitions for Bit-addressable Registers
#define SFR_P0 0x80
#define SFR_TCON 0x88
#define SFR_P1 0x90
#define SFR_SCON0 0x98
#define SFR_P2 0xA0
#define SFR_IE 0xA8
#define SFR_IP 0xB8
#define SFR_SMB0CN 0xC0
#define SFR_SMB1CN 0xC0
#define SFR_TMR2CN 0xC8
#define SFR_TMR5CN 0xC8
#define SFR_PSW 0xD0
#define SFR_PCA0CN 0xD8
#define SFR_ACC 0xE0
#define SFR_ADC0CN 0xE8
#define SFR_B 0xF0
#define SFR_SPI0CN 0xF8
// Bit Definitions
// TCON 0x88
SBIT (TF1, SFR_TCON, 7); // Timer 1 Overflow Flag
SBIT (TR1, SFR_TCON, 6); // Timer 1 On/Off Control
SBIT (TF0, SFR_TCON, 5); // Timer 0 Overflow Flag
SBIT (TR0, SFR_TCON, 4); // Timer 0 On/Off Control
SBIT (IE1, SFR_TCON, 3); // Ext. Interrupt 1 Edge Flag
SBIT (IT1, SFR_TCON, 2); // Ext. Interrupt 1 Type
SBIT (IE0, SFR_TCON, 1); // Ext. Interrupt 0 Edge Flag
SBIT (IT0, SFR_TCON, 0); // Ext. Interrupt 0 Type
// SCON0 0x98
SBIT (S0MODE, SFR_SCON0, 7); // UART0 Mode
// Bit6 UNUSED
SBIT (MCE0, SFR_SCON0, 5); // UART0 MCE
SBIT (REN0, SFR_SCON0, 4); // UART0 RX Enable
SBIT (TB80, SFR_SCON0, 3); // UART0 TX Bit 8
SBIT (RB80, SFR_SCON0, 2); // UART0 RX Bit 8
SBIT (TI0, SFR_SCON0, 1); // UART0 TX Interrupt Flag
SBIT (RI0, SFR_SCON0, 0); // UART0 RX Interrupt Flag
// IE 0xA8
SBIT (EA, SFR_IE, 7); // Global Interrupt Enable
SBIT (ESPI0, SFR_IE, 6); // SPI0 Interrupt Enable
SBIT (ET2, SFR_IE, 5); // Timer 2 Interrupt Enable
SBIT (ES0, SFR_IE, 4); // UART0 Interrupt Enable
SBIT (ET1, SFR_IE, 3); // Timer 1 Interrupt Enable
SBIT (EX1, SFR_IE, 2); // External Interrupt 1 Enable
SBIT (ET0, SFR_IE, 1); // Timer 0 Interrupt Enable
SBIT (EX0, SFR_IE, 0); // External Interrupt 0 Enable
// IP 0xB8
// Bit7 UNUSED
SBIT (PSPI0, SFR_IP, 6); // SPI0 Priority
SBIT (PT2, SFR_IP, 5); // Timer 2 Priority
SBIT (PS0, SFR_IP, 4); // UART0 Priority
SBIT (PT1, SFR_IP, 3); // Timer 1 Priority
SBIT (PX1, SFR_IP, 2); // External Interrupt 1 Priority
SBIT (PT0, SFR_IP, 1); // Timer 0 Priority
SBIT (PX0, SFR_IP, 0); // External Interrupt 0 Priority
// SMB0CN 0xC0
SBIT (MASTER, SFR_SMB0CN, 7); // SMBus0 Master/Slave
SBIT (TXMODE, SFR_SMB0CN, 6); // SMBus0 Transmit Mode
SBIT (STA, SFR_SMB0CN, 5); // SMBus0 Start Flag
SBIT (STO, SFR_SMB0CN, 4); // SMBus0 Stop Flag
SBIT (ACKRQ, SFR_SMB0CN, 3); // SMBus0 Acknowledge Request
SBIT (ARBLOST, SFR_SMB0CN, 2); // SMBus0 Arbitration Lost
SBIT (ACK, SFR_SMB0CN, 1); // SMBus0 Acknowledge Flag
SBIT (SI, SFR_SMB0CN, 0); // SMBus0 Interrupt Pending Flag
// SMB1CN 0xC0
SBIT (MASTER1, SFR_SMB1CN, 7); // SMBus1 Master/Slave
SBIT (TXMODE1, SFR_SMB1CN, 6); // SMBus1 Transmit Mode
SBIT (STA1, SFR_SMB1CN, 5); // SMBus1 Start Flag
SBIT (STO1, SFR_SMB1CN, 4); // SMBus1 Stop Flag
SBIT (ACKRQ1, SFR_SMB1CN, 3); // SMBus1 Acknowledge Request
SBIT (ARBLOST1, SFR_SMB1CN, 2); // SMBus1 Arbitration Lost
SBIT (ACK1, SFR_SMB1CN, 1); // SMBus1 Acknowledge Flag
SBIT (SI1, SFR_SMB1CN, 0); // SMBus1 Interrupt Pending Flag
// TMR2CN 0xC8
SBIT (TF2H, SFR_TMR2CN, 7); // Timer 2 High Byte Overflow Flag
SBIT (TF2L, SFR_TMR2CN, 6); // Timer 2 Low Byte Overflow Flag
SBIT (TF2LEN, SFR_TMR2CN, 5); // Timer 2 Low Byte Interrupt Enable
SBIT (TF2CEN, SFR_TMR2CN, 4); // Timer 2 Lfo Capture Enable
SBIT (T2SPLIT, SFR_TMR2CN, 3); // Timer 2 Split Mode Enable
SBIT (TR2, SFR_TMR2CN, 2); // Timer 2 On/Off Control
// Bit1 UNUSED
SBIT (T2XCLK, SFR_TMR2CN, 0); // Timer 2 External Clock Select
// TMR5CN 0xC8
SBIT (TF5H, SFR_TMR5CN, 7); // Timer 5 High Byte Overflow Flag
SBIT (TF5L, SFR_TMR5CN, 6); // Timer 5 Low Byte Overflow Flag
SBIT (TF5LEN, SFR_TMR5CN, 5); // Timer 5 Low Byte Interrupt Enable
// Bit4 UNUSED
SBIT (T5SPLIT, SFR_TMR5CN, 3); // Timer 5 Split Mode Enable
SBIT (TR5, SFR_TMR5CN, 2); // Timer 5 On/Off Control
// Bit1 UNUSED
SBIT (T5XCLK, SFR_TMR5CN, 0); // Timer 5 External Clock Select
// PSW 0xD0
SBIT (CY, SFR_PSW, 7); // Carry Flag
SBIT (AC, SFR_PSW, 6); // Auxiliary Carry Flag
SBIT (F0, SFR_PSW, 5); // User Flag 0
SBIT (RS1, SFR_PSW, 4); // Register Bank Select 1
SBIT (RS0, SFR_PSW, 3); // Register Bank Select 0
SBIT (OV, SFR_PSW, 2); // Overflow Flag
SBIT (F1, SFR_PSW, 1); // User Flag 1
SBIT (P, SFR_PSW, 0); // Accumulator Parity Flag
// PCA0CN 0xD8
SBIT (CF, SFR_PCA0CN, 7); // PCA0 Counter Overflow Flag
SBIT (CR, SFR_PCA0CN, 6); // PCA0 Counter Run Control Bit
// Bit5 UNUSED
// Bit4 UNUSED
// Bit3 UNUSED
SBIT (CCF2, SFR_PCA0CN, 2); // PCA0 Module 2 Interrupt Flag
SBIT (CCF1, SFR_PCA0CN, 1); // PCA0 Module 1 Interrupt Flag
SBIT (CCF0, SFR_PCA0CN, 0); // PCA0 Module 0 Interrupt Flag
// ADC0CN 0xE8
SBIT (AD0EN, SFR_ADC0CN, 7); // ADC0 Enable
SBIT (AD0TM, SFR_ADC0CN, 6); // ADC0 Track Mode
SBIT (AD0INT, SFR_ADC0CN, 5); // ADC0 EOC Interrupt Flag
SBIT (AD0BUSY, SFR_ADC0CN, 4); // ADC0 Busy Flag
SBIT (AD0WINT, SFR_ADC0CN, 3); // ADC0 Window Interrupt Flag
SBIT (AD0CM2, SFR_ADC0CN, 2); // ADC0 Convert Start Mode Bit 2
SBIT (AD0CM1, SFR_ADC0CN, 1); // ADC0 Convert Start Mode Bit 1
SBIT (AD0CM0, SFR_ADC0CN, 0); // ADC0 Convert Start Mode Bit 0
// SPI0CN 0xF8
SBIT (SPIF, SFR_SPI0CN, 7); // SPI0 Interrupt Flag
SBIT (WCOL, SFR_SPI0CN, 6); // SPI0 Write Collision Flag
SBIT (MODF, SFR_SPI0CN, 5); // SPI0 Mode Fault Flag
SBIT (RXOVRN, SFR_SPI0CN, 4); // SPI0 RX Overrun Flag
SBIT (NSSMD1, SFR_SPI0CN, 3); // SPI0 Slave Select Mode 1
SBIT (NSSMD0, SFR_SPI0CN, 2); // SPI0 Slave Select Mode 0
SBIT (TXBMT, SFR_SPI0CN, 1); // SPI0 TX Buffer Empty Flag
SBIT (SPIEN, SFR_SPI0CN, 0); // SPI0 SPI0 Enable
// Interrupt Priorities
#define INTERRUPT_INT0 0 //External Interrupt 0
#define INTERRUPT_TIMER0 1 //Timer0 Overflow
#define INTERRUPT_INT1 2 //External Interrupt 1
#define INTERRUPT_TIMER1 3 //Timer1 Overflow
#define INTERRUPT_UART0 4 //UART 0
#define INTERRUPT_TIMER2 5 //Timer2 Overflow
#define INTERRUPT_SPI0 6 //Serial Peripheral Interface 0
#define INTERRUPT_SMBUS0 7 //SMBus0 Interface
#define INTERRUPT_PORT_MATCH 8 //Port Match
#define INTERRUPT_ADC0_WINDOW 9 //ADC0 Window Comparison
#define INTERRUPT_ADC0_EOC 10 //ADC0 End Of Conversion
#define INTERRUPT_PCA0 11 //PCA0 Peripheral
#define INTERRUPT_COMPARATOR0 12 //Comparator0
#define INTERRUPT_TIMER3 14 //Timer3 Overflow
#define INTERRUPT_SMBUS1 15 //SMBus1 Interface
#define INTERRUPT_TIMER4 16 //Timer4 Overflow
#define INTERRUPT_TIMER5 17 //Timer5 Overflow
#define INTERRUPT_TEMPSENSE 18 //Temperature Sensor
// SFR Page Definitions
#define LEGACY_PAGE 0x00 // LEGACY SFR PAGE
#define SMBUS0_PAGE 0x00 // SMBus0 SFR PAGE
#define SMBUS1_PAGE 0x0F // SMBus1 SFR PAGE
#define IDAC0_PAGE 0x00 // IDAC0 SFR PAGE
#define IDAC1_PAGE 0x0F // IDAC1 SFR PAGE
#define TIMER2_PAGE 0x00 // Timer2 SFR PAGE
#define TIMER3_PAGE 0x00 // Timer3 SFR PAGE
#define TIMER4_PAGE 0x0F // Timer4 SFR PAGE
#define TIMER5_PAGE 0x0F // Timer5 SFR PAGE
#define TS0CN_PAGE 0x0F // Tempsense control SFR PAGE
#define TS0DAT_PAGE 0x00 // Tempsense data SFR PAGE
#define SERIALNUM_PAGE 0x0F // Serial Number DFR PAGE
// SDCC PDATA External Memory Paging Support
#if defined SDCC
SFR(_XPAGE, 0xAA); // Point to the EMI0CN register
// Header File PreProcessor Directive
#endif // #define C8051F390_DEFS_H
// End Of File
