// MSP430F552x Demo - USCI_A0, SPI 3-Wire Slave Data Echo
// Description: SPI slave talks to SPI master using 3-wire mode. Data received
// from master is echoed back. USCI RX ISR is used to handle communication,
// CPU normally in LPM4. Prior to initial data exchange, master pulses
// slaves RST for complete reset.
// ACLK = ~32.768kHz, MCLK = SMCLK = DCO ~ 1048kHz
// Use with SPI Master Incremented Data code example. If the slave is in
// debug mode, the reset signal from the master will conflict with slave's
// JTAG; to work around, use IAR's "Release JTAG on Go" on slave device. If
// breakpoints are set in slave RX ISR, master must stopped also to avoid
// overrunning slave RXBUF.
// MSP430F552x
// Master---+->|RST |
// | P3.3|-> Data Out (UCA0SIMO)
// | P3.4|<- Data In (UCA0SOMI)
// | P2.7|-> Serial Clock IN (UCA0CLK)
// Bhargavi Nisarga
// Texas Instruments Inc.
// April 2009
// Built with CCSv4 and IAR Embedded Workbench Version: 4.21
#include <msp430f5529.h>
WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer
while(!(P2IN&0x80)); // If clock sig from mstr stays low,
// it is not yet in SPI mode
P3SEL |= BIT3+BIT4; // P3.3,4 option select
P2SEL |= BIT7; // P2.7 option select
UCA0CTL1 |= UCSWRST; // **Put state machine in reset**
UCA0CTL0 |= UCSYNC+UCCKPL+UCMSB; // 3-pin, 8-bit SPI slave,
// Clock polarity high, MSB
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
UCA0IE |= UCRXIE; // Enable USCI_A0 RX interrupt
__bis_SR_register(LPM4_bits + GIE); // Enter LPM4, enable interrupts
// Echo character
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
switch(__even_in_range(UCA0IV,4))
case 0:break; // Vector 0 - no interrupt
case 2: // Vector 2 - RXIFG
while (!(UCA0IFG&UCTXIFG)); // USCI_A0 TX buffer ready?
UCA0TXBUF = UCA0RXBUF;
case 4:break; // Vector 4 - TXIFG
default: break;
这一句
while(!(P2IN&0x80)); // If clock sig from mstr stays low, it is not yet in SPI mode
为什么 If clock sig from mstr stays low, it is not yet in SPI mode
