发表于 2013-4-26 07:26:21
Override default program entry
By default, the program entry is the label __iar_program_start.
The linker makes sure that a module containing the program entry label is included,
and that the section containing that label is not discarded.
Override default program entry overrides the default entry label;
choose between:
Entry symbol Specify an entry symbol other than default.
Defined by application Uses an entry symbol defined in the linked object code.
The linker will, as always, include all program modules,
and enough library modules to satisfy all symbol references,
keeping all sections that are marked with the root attribute
or that are referenced, directly or indirectly, from such a section. |
