接收数据超时后关闭连接的相关代码:
bytes_received = recv(sock, buf_data, 4 , 0);
if (bytes_received < 0)
lwip_close(sock);
dtu_execute = E_CONNECT ;
rt_kprintf("接收数据失败,重新连接\n");
rt_thread_delay(100);
break ;
重新连接的相关代码:
if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1)
rt_kprintf("Socket error\n");
rt_thread_delay(500);
break ;
if (connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1)
rt_kprintf("Connect fail!\n");
lwip_close(sock);
break ; //如果没连接成功就一直重连上面的截图就是在这个状态.
nNetTimeout = 60000 ;
setsockopt(sock,SOL_SOCKET,SO_SNDTIMEO,(char *)&nNetTimeout,sizeof(int));
setsockopt(sock,SOL_SOCKET,SO_RCVTIMEO,(char *)&nNetTimeout,sizeof(int));
nNetTimeout = 1 ;
setsockopt(sock,SOL_SOCKET,SO_DONTLINGER,(char *)&nNetTimeout,sizeof(int));
板子重新复位后可以连上服务器.
