发表于 2013-4-12 21:15:18
gnocy 发表于 2013-4-12 19:29
目前跑60M,还没有发现问题
跑60MHZ,我也是的,没什么问题!下面给下我的SDRAM(H57V256)的代码,各位可以简单测试下,能跑多少频率?
代码是参照其它程序的!
#define NSPERCLK ((1000 * 1000000) / SystemCoreClock)
#define EMC_NS2CLK(ns) ((ns + NSPERCLK - 1) / NSPERCLK)
* SDRAM settings
#define SDRAM_SIZE_MB 64
#define SDRAM_SIZE (SDRAM_SIZE_MB * 1024 * 1024)
#define SDRAM_BASE_ADDR 0xA0000000
* _DelayMs()
* Function description:
* Starts a timer and waits for the given delay in ms.
static void _DelayMs(uint32_t ms) {
LPC_TIM0->TCR = 0x02; // Reset timer
LPC_TIM0->PR = 0x00; // Set prescaler to zero
LPC_TIM0->MR0 = ms * (SystemCoreClock / (LPC_SC->PCLKSEL & 0x1F) / 1000 - 1);
LPC_TIM0->IR = 0xFF; // Reset all interrrupts
LPC_TIM0->MCR = 0x04; // Stop timer on match
LPC_TIM0->TCR = 0x01; // Start timer
// Wait until delay time has elapsed
while (LPC_TIM0->TCR & 1);
* _TestSDRAM()
* Simple SDRAM test for testing timing setup
* Return value:
* 1: Error
* 0: O.K.
static int _TestSDRAM(void) {
volatile uint32_t * pWriteLong;
volatile uint16_t * pWriteShort;
uint32_t Data;
uint32_t i;
uint32_t j;
pWriteLong = (uint32_t*)SDRAM_BASE_ADDR;
pWriteShort = (uint16_t*)SDRAM_BASE_ADDR;
// Fill 16 bit wise
for (i = 0; i < (SDRAM_SIZE / 0x40000); i++) {
for (j = 0; j < 0x100; j++) {
*pWriteShort++ = (i + j);
*pWriteShort++ = (i + j) + 1;
// Verifying
Data = *pWriteLong++;
if (Data != (((((i + j) + 1) & 0xFFFF) << 16) | ((i + j) & 0xFFFF))) {
return 1; // Error
return 0; // O.K.
* _FindDelay()
* Test for min./max. CMDDLY or FBCLKDLY values
* Parameter:
* DelayType: 0 = CMDDLY, 1 = FBCLKDLY
static void _FindDelay(int DelayType) {
uint32_t Delay;
uint32_t Min;
uint32_t Max;
uint32_t v;
// Init start values
Delay = 0x00;
Min = 0xFF;
Max = 0xFF;
// Test for DLY min./max. values
while (Delay < 32) {
// Setup new DLY value to test
if (DelayType == 0) {
v = LPC_SC->EMCDLYCTL & ~0x001Ful;
LPC_SC->EMCDLYCTL = v | Delay;
} else {
v = LPC_SC->EMCDLYCTL & ~0x1F00ul;
LPC_SC->EMCDLYCTL = v | (Delay << 8);
// Test configured DLY value and find out min./max. values that will work
if (_TestSDRAM() == 0) {
// Test passed, remember min. DLY value if not done yet
if (Min == 0xFF) {
Min = Delay;
} else {
// Test failed, if a min. value has been found before, remember the current value for max.
if (Min != 0xFF) {
Max = Delay;
Delay++;
// Calc DLY value
if (Max != 0xFF) { // If we found a min. and max. value we use the average of the min. and max. values to get an optimal DQSIN delay
Delay = (Min + Max) / 2;
} else if (Min != 0xFF) { // If we found only a min. value we use the average of the min. value and the longest DLY value to get an optimal DQSIN delay
Delay = (Min + 0x1F) / 2;
} else { // No working max. and/or min. values found
while (1); // Fatal error
// Setup DLY value to work with
} else {
* _CalibrateOsc()
* Calibrate ring oscillator.
* Return value:
* Current ring oscillator count
static uint32_t _CalibrateOsc(void) {
uint32_t Cnt;
uint32_t v;
uint32_t i;
Cnt = 0;
// Calibrate osc.
for (i = 0; i < 10; i++) {
LPC_SC->EMCCAL = (1 << 14); // Start calibration
v = LPC_SC->EMCCAL;
while ((v & (1 << 15)) == 0) { // Wait for calibration done
v = LPC_SC->EMCCAL;
Cnt += (v & 0xFF);
return (Cnt / 10);
* _AdjustEMCTiming()
* Adjust timings for EMC.
static void _AdjustEMCTiming(uint32_t Delay) {
uint32_t v;
uint32_t CmdDly;
uint32_t FBDelay;
uint32_t FBClkDly;
FBDelay = _CalibrateOsc();
v = LPC_SC->EMCDLYCTL;
CmdDly = ((v & 0x001Ful) * Delay / FBDelay) & 0x1F;
FBClkDly = ((v & 0x1F00ul) * Delay / FBDelay) & 0x1F00;
LPC_SC->EMCDLYCTL = (v & ~0x1F1Ful) | FBClkDly | CmdDly;
* _EMC_Init()
* Purpose:
* Initializes external memory controller for SDRAM
void SDRAMInit(void) {
volatile uint32_t i;
volatile uint32_t Dummy;
volatile uint32_t CmdDly;
LPC_SC->PCONP |= (1 << 11); // Turn on EMC peripheral clock
LPC_SC->EMCDLYCTL = 0x00001010;
LPC_EMC->Control = 1; // EMC enable
LPC_EMC->Config = 0;
// Port init
LPC_IOCON->P3_0 = 1; // D0
LPC_IOCON->P3_1 = 1; // D1
LPC_IOCON->P3_2 = 1; // D2
LPC_IOCON->P3_3 = 1; // D3
LPC_IOCON->P3_4 = 1; // D4
LPC_IOCON->P3_5 = 1; // D5
LPC_IOCON->P3_6 = 1; // D6
LPC_IOCON->P3_7 = 1; // D7
LPC_IOCON->P3_8 = 1; // D8
LPC_IOCON->P3_9 = 1; // D9
LPC_IOCON->P3_10 = 1; // D10
LPC_IOCON->P3_11 = 1; // D11
LPC_IOCON->P3_12 = 1; // D12
LPC_IOCON->P3_13 = 1; // D13
LPC_IOCON->P3_14 = 1; // D14
LPC_IOCON->P3_15 = 1; // D15
LPC_IOCON->P3_16 = 1; // D16
LPC_IOCON->P3_17 = 1; // D17
LPC_IOCON->P3_18 = 1; // D18
LPC_IOCON->P3_19 = 1; // D19
LPC_IOCON->P3_20 = 1; // D20
LPC_IOCON->P3_21 = 1; // D21
LPC_IOCON->P3_22 = 1; // D22
LPC_IOCON->P3_23 = 1; // D23
LPC_IOCON->P3_24 = 1; // D24
LPC_IOCON->P3_25 = 1; // D25
LPC_IOCON->P3_26 = 1; // D26
LPC_IOCON->P3_27 = 1; // D27
LPC_IOCON->P3_28 = 1; // D28
LPC_IOCON->P3_29 = 1; // D29
LPC_IOCON->P3_30 = 1; // D30
LPC_IOCON->P3_31 = 1; // D31
LPC_IOCON->P4_0 = 1; // A0
LPC_IOCON->P4_1 = 1; // A1
LPC_IOCON->P4_2 = 1; // A2
LPC_IOCON->P4_3 = 1; // A3
LPC_IOCON->P4_4 = 1; // A4
LPC_IOCON->P4_5 = 1; // A5
LPC_IOCON->P4_6 = 1; // A6
LPC_IOCON->P4_7 = 1; // A7
LPC_IOCON->P4_8 = 1; // A8
LPC_IOCON->P4_9 = 1; // A9
LPC_IOCON->P4_10 = 1; // A10
LPC_IOCON->P4_11 = 1; // A11
LPC_IOCON->P4_12 = 1; // A12
LPC_IOCON->P4_13 = 1; // A13
LPC_IOCON->P4_14 = 1; // A14
LPC_IOCON->P4_15 = 1; // A15
LPC_IOCON->P4_16 = 1; // A16
LPC_IOCON->P4_17 = 1; // A17
LPC_IOCON->P4_18 = 1; // A18
LPC_IOCON->P4_19 = 1; // A19
LPC_IOCON->P4_20 = 1; // A20
LPC_IOCON->P4_21 = 1; // A21
LPC_IOCON->P4_22 = 1; // A22
LPC_IOCON->P4_23 = 1; // A23
LPC_IOCON->P4_24 = 1; // OE
LPC_IOCON->P4_25 = 1; // WE
//LPC_IOCON->P4_26 = 1; // BLS0
//LPC_IOCON->P4_27 = 1; // BLS1
//LPC_IOCON->P4_28 = 1; // BLS2
//LPC_IOCON->P4_29 = 1; // BLS3
//LPC_IOCON->P4_30 = 1; // CS0
//LPC_IOCON->P4_31 = 1; // CS1
//LPC_IOCON->P2_14 = 1; // CS2
//LPC_IOCON->P2_15 = 1; // CS3
LPC_IOCON->P2_16 = 1; // CAS
LPC_IOCON->P2_17 = 1; // RAS
LPC_IOCON->P2_18 = 1; // CLKOUT0
//LPC_IOCON->P2_19 = 1; // CLKOUT1
LPC_IOCON->P2_20 = 1; // DYCS0
//LPC_IOCON->P2_21 = 1; // DYCS1
//LPC_IOCON->P2_22 = 1; // DYCS2
//LPC_IOCON->P2_23 = 1; // DYCS3
LPC_IOCON->P2_24 = 1; // CKEOUT0
//LPC_IOCON->P2_25 = 1; // CKEOUT1
//LPC_IOCON->P2_26 = 1; // CKEOUT2
//LPC_IOCON->P2_27 = 1; // CKEOUT3
LPC_IOCON->P2_28 = 1; // DQMOUT0
LPC_IOCON->P2_29 = 1; // DQMOUT1
LPC_IOCON->P2_30 = 1; // DQMOUT2
LPC_IOCON->P2_31 = 1; // DQMOUT3
// Setup EMC config for SDRAM, timings for 60MHz bus
LPC_EMC->DynamicConfig0 = 0x00004480; // 256MB, 8Mx32, 4 banks, 12 rows, 9 columns, buffers disabled
LPC_EMC->DynamicReadConfig = 0x00000001; // Command delayed strategy, using EMCCLKDELAY
#if 0
LPC_EMC->DynamicRasCas0 = 0x00000202; // 2 RAS, 2 CAS latency */
LPC_EMC->DynamicRP = 0x00000001; // n + 1 clock cycles
LPC_EMC->DynamicRAS = 0x00000003; // n + 1 clock cycles
LPC_EMC->DynamicSREX = 0x00000005; // n + 1 clock cycles
LPC_EMC->DynamicAPR = 0x00000002; // n + 1 clock cycles
LPC_EMC->DynamicDAL = 0x00000003; // n clock cycles
LPC_EMC->DynamicWR = 0x00000001; // n + 1 clock cycles
LPC_EMC->DynamicRC = 0x00000004; // n + 1 clock cycles
LPC_EMC->DynamicRFC = 0x00000004; // n + 1 clock cycles
LPC_EMC->DynamicXSR = 0x00000005; // n + 1 clock cycles
LPC_EMC->DynamicRRD = 0x00000001; // n + 1 clock cycles
LPC_EMC->DynamicMRD = 0x00000001; // n + 1 clock cycles
// RAS latency (active to read/write delay) (RAS): 3 CCLK cycles
// CAS latency (CAS) : 3 CCLK cycles
/* H57V2562GTR-75C: tCL=3CLK, tRCD=20ns(min), 3 CLK=24ns */
LPC_EMC->DynamicRasCas0 = 0x00000303;
LPC_EMC->DynamicRP = EMC_NS2CLK(20); /* 20ns, */
LPC_EMC->DynamicRAS = EMC_NS2CLK(50); /* 42ns to 100K ns, */
LPC_EMC->DynamicSREX = 1 - 1; /* tSRE, 1clk, */
LPC_EMC->DynamicAPR = 2 - 1; /* Not found!!! Estimated as 2clk, */
LPC_EMC->DynamicDAL = EMC_NS2CLK(20) + 2; /* tDAL = tRP + tDPL = 20ns + 2clk */
LPC_EMC->DynamicWR = 2 - 1; /* 2CLK, */
LPC_EMC->DynamicRC = EMC_NS2CLK(63); /* H57V2562GTR-75C tRC=63ns(min)*/
LPC_EMC->DynamicRFC = EMC_NS2CLK(63); /* H57V2562GTR-75C tRFC=tRC */
LPC_EMC->DynamicXSR = 0x0000000F; /* exit self-refresh to active, 不知道,设为最久 */
LPC_EMC->DynamicRRD = EMC_NS2CLK(63); /* 3clk, tRRD=15ns(min) */
LPC_EMC->DynamicMRD = 2 - 1; /* 2clk, tMRD=2clk(min) */
_DelayMs(100);
LPC_EMC->DynamicControl = 0x00000183; // Issue NOP command
_DelayMs(200);
LPC_EMC->DynamicControl = 0x00000103; // Issue PALL command
LPC_EMC->DynamicRefresh = 0x00000002; // n * 16 clock cycles
for (i = 0; i < 0x80; i++); // Wait 128 AHB clock cycles
LPC_EMC->DynamicRefresh = 0x0000003A; // n * 16 clock cycles
// Init SDRAM
LPC_EMC->DynamicControl = 0x00000083; // Issue MODE command
Dummy = *((volatile uint32_t*)(SDRAM_BASE_ADDR | (0x32 << (2+2+9)))); // 4 burst, 3 CAS latency
LPC_EMC->DynamicControl = 0x00000000; // Issue NORMAL command
LPC_EMC->DynamicConfig0 = 0x00084480; // 256MB, 8Mx32, 4 banks, 12 rows, 9 columns, buffers (re-)enabled
// Auto calibrate timings
CmdDly = _CalibrateOsc();
// Find best delay values
_FindDelay(0); // EMCDLY
_FindDelay(1); // FBCLKDLY
_AdjustEMCTiming(CmdDly);
