- LIBRARY IEEE;
- USE IEEE.std_logic_1164.ALL;
- ENTITY chucun IS
- PORT(s0,s1,s2:IN std_logic; b1,b2,b3,b4:IN std_logic;
- wr,rd:IN std_logic; f1,f2,f3,f4:OUT std_logic);
- END chucun;
- ARCHITECTURE F OF chucun IS
- SIGNAL e11,e12,e13,e14:std_logic;
- SIGNAL e21,e22,e23,e24:std_logic;
- SIGNAL e31,e32,e33,e34:std_logic;
- SIGNAL e41,e42,e43,e44:std_logic;
- SIGNAL e51,e52,e53,e54:std_logic;
- SIGNAL e61,e62,e63,e64:std_logic;
- SIGNAL e71,e72,e73,e74:std_logic;
- SIGNAL mid:std_logic_vector(2 DOWNTO 0);
- BEGIN
- mid<=s2&s1&s0;
- PROCESS(mid)
- BEGIN
- IF(wr='1')THEN --写信号有效,写入密码存储
- IF(mid="000")THEN
- e11<=b1;e12<=b2;e13<=b3;e14<=b4;
- f1<=e11;f2<=e12;f3<=e13;f4<=e14;
- IF(mid="001")THEN
- e21<=b1;e22<=b2;e23<=b3;e24<=b4;
- f1<=e21;f2<=e22;f3<=e23;f4<=e24;
- IF(mid="010")THEN
- e31<=b1;e32<=b2;e33<=b3;e34<=b4;
- f1<=e31;f2<=e32;f3<=e33;f4<=e34;
- IF(mid="011")THEN
- e41<=b1;e42<=b2;e43<=b3;e44<=b4;
- f1<=e41;f2<=e42;f3<=e33;f4<=e34;
- IF(mid="100")THEN
- e51<=b1;e52<=b2;e53<=b3;e54<=b4;
- f1<=e51;f2<=e52;f3<=e53;f4<=e54;
- IF(mid="101")THEN
- e61<=b1;e62<=b2;e63<=b3;e64<=b4;
- f1<=e61;f2<=e62;f3<=e63;f4<=e64;
- ELSE
- e71<=b1;e72<=b2;e73<=b3;e74<=b4;
- f1<=e71;f2<=e72;f3<=e73;f4<=e74;
- END IF;
- ELSIF(rd='1')THEN --读信号有效,读出密码比较
- IF(mid="000")THEN
- IF(mid="001")THEN
- IF(mid="010")THEN
- IF(mid="100")THEN
- f1<=e41;f2<=e42;f3<=e43;f4<=e44;
- IF(mid="101")THEN
- IF(mid="110")THEN
- ELSE
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END IF;
- END PROCESS;
- END F;
复制代码 此程序有什么问题,我在仿真的时候。当写信号高电平,有效输出。但是当读信号有效时,输出一直处于低电平。也就是等于最后一段的程序貌似没起到作用。
另,我把WR=1和RD=1的语句 掉下顺序后仿真。。貌似都没效了 这是为什么啊???
s0-s2 是计数器模块的,用于地址选择 |
