发表于 2013-4-7 10:56:08
着脸张图已经说明问题了,但是还没找到原因
- ; * File : start_rvds.s
- ; * This file is part of RT-Thread RTOS
- ; * COPYRIGHT (C) 2009, RT-Thread Development Team
- ; * The license and distribution terms for this file may be
- ; * found in the file LICENSE in this distribution or at
- ; * http://www.rt-thread.org/license/LICENSE
- ; * Change Logs:
- ; * Date Author Notes
- ; * 2009-09-23 Bernard first implementation
- ;* <<< Use Configuration Wizard in Context Menu >>>
- ; Amount of memory (in bytes) allocated for Stack
- ; Tailor this value to your application needs
- ; <h> Stack Configuration
- ; <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
- ; </h>
- Stack_Size EQU 0x00000400
- AREA STACK, NOINIT, READWRITE, ALIGN=3
- Stack_Mem SPACE Stack_Size
- __initial_sp
- ; not use external SRAM as data memory
- ; <h> Heap Configuration
- ; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
- ; </h>
- Heap_Size EQU 0x00000000
- AREA HEAP, NOINIT, READWRITE, ALIGN=3
- __heap_base
- Heap_Mem SPACE Heap_Size
- __heap_limit
- PRESERVE8
- THUMB
- ; IMPORT rt_hw_hard_fault
- ; IMPORT rt_hw_pend_sv
- ; IMPORT rt_hw_timer_handler
- ; Vector Table Mapped to Address 0 at Reset
- AREA RESET, DATA, READONLY
- EXPORT __Vectors
- EXPORT __Vectors_End
- EXPORT __Vectors_Size
- __Vectors DCD __initial_sp ; Top of Stack
- DCD Reset_Handler ; Reset Handler
- DCD NMI_Handler ; NMI Handler
- ; DCD rt_hw_hard_fault ; Hard Fault Handler
- DCD MemManage_Handler ; MPU Fault Handler
- DCD BusFault_Handler ; Bus Fault Handler
- DCD UsageFault_Handler ; Usage Fault Handler
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD SVC_Handler ; SVCall Handler
- DCD DebugMon_Handler ; Debug Monitor Handler
- DCD 0 ; Reserved
- ; DCD rt_hw_pend_sv ; PendSV Handler in RT-Thread
- ; DCD rt_hw_timer_handler ; SysTick Handler in RT-Thread
- ; External Interrupts
- DCD WWDG_IRQHandler ; Window Watchdog
- DCD PVD_IRQHandler ; PVD through EXTI Line detect
- DCD TAMPER_IRQHandler ; Tamper
- DCD RTC_IRQHandler ; RTC
- DCD FLASH_IRQHandler ; Flash
- DCD RCC_IRQHandler ; RCC
- DCD EXTI0_IRQHandler ; EXTI Line 0
- DCD EXTI1_IRQHandler ; EXTI Line 1
- DCD EXTI2_IRQHandler ; EXTI Line 2
- DCD EXTI3_IRQHandler ; EXTI Line 3
- DCD EXTI4_IRQHandler ; EXTI Line 4
- DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1
- DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2
- DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3
- DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4
- DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5
- DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6
- DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7
- DCD ADC1_2_IRQHandler ; ADC1 and ADC2
- DCD USB_HP_CAN1_TX_IRQHandler ; USB High Priority or CAN1 TX
- DCD USB_LP_CAN1_RX0_IRQHandler ; USB Low Priority or CAN1 RX0
- DCD CAN1_RX1_IRQHandler ; CAN1 RX1
- DCD CAN1_SCE_IRQHandler ; CAN1 SCE
- DCD EXTI9_5_IRQHandler ; EXTI Line 9..5
- DCD TIM1_BRK_IRQHandler ; TIM1 Break
- DCD TIM1_UP_IRQHandler ; TIM1 Update
- DCD TIM1_TRG_COM_IRQHandler ; TIM1 Trigger and Commutation
- DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare
- DCD TIM2_IRQHandler ; TIM2
- DCD TIM3_IRQHandler ; TIM3
- DCD TIM4_IRQHandler ; TIM4
- DCD I2C1_EV_IRQHandler ; I2C1 Event
- DCD I2C1_ER_IRQHandler ; I2C1 Error
- DCD I2C2_EV_IRQHandler ; I2C2 Event
- DCD I2C2_ER_IRQHandler ; I2C2 Error
- DCD SPI1_IRQHandler ; SPI1
- DCD SPI2_IRQHandler ; SPI2
- DCD USART1_IRQHandler ; USART1
- DCD USART2_IRQHandler ; USART2
- DCD USART3_IRQHandler ; USART3
- DCD EXTI15_10_IRQHandler ; EXTI Line 15..10
- DCD RTCAlarm_IRQHandler ; RTC Alarm through EXTI Line
- DCD OTG_FS_WKUP_IRQHandler ; USB OTG FS Wakeup through EXTI line
- DCD TIM8_BRK_IRQHandler ; TIM8 Break
- DCD TIM8_UP_IRQHandler ; TIM8 Update
- DCD TIM8_TRG_COM_IRQHandler ; TIM8 Trigger and Commutation
- DCD TIM8_CC_IRQHandler ; TIM8 Capture Compare
- DCD ADC3_IRQHandler ; ADC3
- DCD FSMC_IRQHandler ; FSMC
- DCD SDIO_IRQHandler ; SDIO
- DCD TIM5_IRQHandler ; TIM5
- DCD SPI3_IRQHandler ; SPI3
- DCD UART4_IRQHandler ; UART4
- DCD UART5_IRQHandler ; UART5
- DCD TIM6_IRQHandler ; TIM6
- DCD TIM7_IRQHandler ; TIM7
- DCD DMA2_Channel1_IRQHandler ; DMA2 Channel1
- DCD DMA2_Channel2_IRQHandler ; DMA2 Channel2
- DCD DMA2_Channel3_IRQHandler ; DMA2 Channel3
- DCD DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 and Channel5
- ; for STM32F10x Connectivity line devices
- DCD DMA2_Channel5_IRQHandler ; DMA2 Channel5
- DCD ETH_IRQHandler ; Ethernet
- DCD ETH_WKUP_IRQHandler ; Ethernet Wakeup through EXTI line
- DCD CAN2_TX_IRQHandler ; CAN2 TX
- DCD CAN2_RX0_IRQHandler ; CAN2 RX0
- DCD CAN2_RX1_IRQHandler ; CAN2 RX1
- DCD CAN2_SCE_IRQHandler ; CAN2 SCE
- DCD OTG_FS_IRQHandler ; USB OTG FS
- __Vectors_End
- __Vectors_Size EQU __Vectors_End - __Vectors
- AREA |.text|, CODE, READONLY
- ; Reset handler routine
- Reset_Handler PROC
- EXPORT Reset_Handler [WEAK]
- IMPORT __main
- LDR R1, = __initial_sp ; restore original stack pointer
- MSR MSP, R1
- LDR R0, =__main
- BX R0
- ENDP
- ; Dummy Exception Handlers (infinite loops which can be modified)
- NMI_Handler PROC
- EXPORT NMI_Handler [WEAK]
- B .
- ENDP
- HardFault_Handler\
- PROC
- EXPORT HardFault_Handler [WEAK]
- B .
- ENDP
- MemManage_Handler\
- PROC
- EXPORT MemManage_Handler [WEAK]
- B .
- ENDP
- BusFault_Handler\
- PROC
- EXPORT BusFault_Handler [WEAK]
- B .
- ENDP
- UsageFault_Handler\
- PROC
- EXPORT UsageFault_Handler [WEAK]
- B .
- ENDP
- SVC_Handler PROC
- EXPORT SVC_Handler [WEAK]
- B .
- ENDP
- DebugMon_Handler\
- PROC
- EXPORT DebugMon_Handler [WEAK]
- B .
- ENDP
- Default_Handler PROC
- EXPORT WWDG_IRQHandler [WEAK]
- EXPORT PVD_IRQHandler [WEAK]
- EXPORT TAMPER_IRQHandler [WEAK]
- EXPORT RTC_IRQHandler [WEAK]
- EXPORT FLASH_IRQHandler [WEAK]
- EXPORT RCC_IRQHandler [WEAK]
- EXPORT EXTI0_IRQHandler [WEAK]
- EXPORT EXTI1_IRQHandler [WEAK]
- EXPORT EXTI2_IRQHandler [WEAK]
- EXPORT EXTI3_IRQHandler [WEAK]
- EXPORT EXTI4_IRQHandler [WEAK]
- EXPORT DMA1_Channel1_IRQHandler [WEAK]
- EXPORT DMA1_Channel2_IRQHandler [WEAK]
- EXPORT DMA1_Channel3_IRQHandler [WEAK]
- EXPORT DMA1_Channel4_IRQHandler [WEAK]
- EXPORT DMA1_Channel5_IRQHandler [WEAK]
- EXPORT DMA1_Channel6_IRQHandler [WEAK]
- EXPORT DMA1_Channel7_IRQHandler [WEAK]
- EXPORT ADC1_2_IRQHandler [WEAK]
- EXPORT USB_HP_CAN1_TX_IRQHandler [WEAK]
- EXPORT USB_LP_CAN1_RX0_IRQHandler [WEAK]
- EXPORT CAN1_RX1_IRQHandler [WEAK]
- EXPORT CAN1_SCE_IRQHandler [WEAK]
- EXPORT EXTI9_5_IRQHandler [WEAK]
- EXPORT TIM1_BRK_IRQHandler [WEAK]
- EXPORT TIM1_UP_IRQHandler [WEAK]
- EXPORT TIM1_TRG_COM_IRQHandler [WEAK]
- EXPORT TIM1_CC_IRQHandler [WEAK]
- EXPORT TIM2_IRQHandler [WEAK]
- EXPORT TIM3_IRQHandler [WEAK]
- EXPORT TIM4_IRQHandler [WEAK]
- EXPORT I2C1_EV_IRQHandler [WEAK]
- EXPORT I2C1_ER_IRQHandler [WEAK]
- EXPORT I2C2_EV_IRQHandler [WEAK]
- EXPORT I2C2_ER_IRQHandler [WEAK]
- EXPORT SPI1_IRQHandler [WEAK]
- EXPORT SPI2_IRQHandler [WEAK]
- EXPORT USART1_IRQHandler [WEAK]
- EXPORT USART2_IRQHandler [WEAK]
- EXPORT USART3_IRQHandler [WEAK]
- EXPORT EXTI15_10_IRQHandler [WEAK]
- EXPORT RTCAlarm_IRQHandler [WEAK]
- EXPORT OTG_FS_WKUP_IRQHandler [WEAK]
- EXPORT TIM8_BRK_IRQHandler [WEAK]
- EXPORT TIM8_UP_IRQHandler [WEAK]
- EXPORT TIM8_TRG_COM_IRQHandler [WEAK]
- EXPORT TIM8_CC_IRQHandler [WEAK]
- EXPORT ADC3_IRQHandler [WEAK]
- EXPORT FSMC_IRQHandler [WEAK]
- EXPORT SDIO_IRQHandler [WEAK]
- EXPORT TIM5_IRQHandler [WEAK]
- EXPORT SPI3_IRQHandler [WEAK]
- EXPORT UART4_IRQHandler [WEAK]
- EXPORT UART5_IRQHandler [WEAK]
- EXPORT TIM6_IRQHandler [WEAK]
- EXPORT TIM7_IRQHandler [WEAK]
- EXPORT DMA2_Channel1_IRQHandler [WEAK]
- EXPORT DMA2_Channel2_IRQHandler [WEAK]
- EXPORT DMA2_Channel3_IRQHandler [WEAK]
- EXPORT DMA2_Channel4_5_IRQHandler [WEAK]
- EXPORT DMA2_Channel5_IRQHandler [WEAK]
- EXPORT ETH_IRQHandler [WEAK]
- EXPORT ETH_WKUP_IRQHandler [WEAK]
- EXPORT CAN2_TX_IRQHandler [WEAK]
- EXPORT CAN2_RX0_IRQHandler [WEAK]
- EXPORT CAN2_RX1_IRQHandler [WEAK]
- EXPORT CAN2_SCE_IRQHandler [WEAK]
- EXPORT OTG_FS_IRQHandler [WEAK]
- WWDG_IRQHandler
- PVD_IRQHandler
- TAMPER_IRQHandler
- RTC_IRQHandler
- FLASH_IRQHandler
- RCC_IRQHandler
- EXTI0_IRQHandler
- EXTI1_IRQHandler
- EXTI2_IRQHandler
- EXTI3_IRQHandler
- EXTI4_IRQHandler
- DMA1_Channel1_IRQHandler
- DMA1_Channel2_IRQHandler
- DMA1_Channel3_IRQHandler
- DMA1_Channel4_IRQHandler
- DMA1_Channel5_IRQHandler
- DMA1_Channel6_IRQHandler
- DMA1_Channel7_IRQHandler
- ADC1_2_IRQHandler
- USB_HP_CAN1_TX_IRQHandler
- USB_LP_CAN1_RX0_IRQHandler
- CAN1_RX1_IRQHandler
- CAN1_SCE_IRQHandler
- EXTI9_5_IRQHandler
- TIM1_BRK_IRQHandler
- TIM1_UP_IRQHandler
- TIM1_TRG_COM_IRQHandler
- TIM1_CC_IRQHandler
- TIM2_IRQHandler
- TIM3_IRQHandler
- TIM4_IRQHandler
- I2C1_EV_IRQHandler
- I2C1_ER_IRQHandler
- I2C2_EV_IRQHandler
- I2C2_ER_IRQHandler
- SPI1_IRQHandler
- SPI2_IRQHandler
- USART1_IRQHandler
- USART2_IRQHandler
- USART3_IRQHandler
- EXTI15_10_IRQHandler
- RTCAlarm_IRQHandler
- OTG_FS_WKUP_IRQHandler
- TIM8_BRK_IRQHandler
- TIM8_UP_IRQHandler
- TIM8_TRG_COM_IRQHandler
- TIM8_CC_IRQHandler
- ADC3_IRQHandler
- FSMC_IRQHandler
- SDIO_IRQHandler
- TIM5_IRQHandler
- SPI3_IRQHandler
- UART4_IRQHandler
- UART5_IRQHandler
- TIM6_IRQHandler
- TIM7_IRQHandler
- DMA2_Channel1_IRQHandler
- DMA2_Channel2_IRQHandler
- DMA2_Channel3_IRQHandler
- DMA2_Channel4_5_IRQHandler
- DMA2_Channel5_IRQHandler
- ETH_IRQHandler
- ETH_WKUP_IRQHandler
- CAN2_TX_IRQHandler
- CAN2_RX0_IRQHandler
- CAN2_RX1_IRQHandler
- CAN2_SCE_IRQHandler
- OTG_FS_IRQHandler
- B .
- ENDP
- ALIGN
- ; User Stack and Heap initialization
- IF :DEF:__MICROLIB
- EXPORT __initial_sp
- EXPORT __heap_base
- EXPORT __heap_limit
- ELSE
- IMPORT __use_two_region_memory
- EXPORT __user_initial_stackheap
- __user_initial_stackheap
- LDR R0, = Heap_Mem
- LDR R1, =(Stack_Mem + Stack_Size)
- LDR R2, = (Heap_Mem + Heap_Size)
- LDR R3, = Stack_Mem
- BX LR
- ALIGN
- ENDIF
- END
- ;******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE*****
- [code];******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
- ;* File Name : startup_stm32f10x_hd.s
- ;* Author : MCD Application Team
- ;* Version : V3.5.0
- ;* Date : 11-March-2011
- ;* Description : STM32F10x High Density Devices vector table for MDK-ARM
- ;* toolchain.
- ;* This module performs:
- ;* - Set the initial SP
- ;* - Set the initial PC == Reset_Handler
- ;* - Set the vector table entries with the exceptions ISR address
- ;* - Configure the clock system and also configure the external
- ;* SRAM mounted on STM3210E-EVAL board to be used as data
- ;* memory (optional, to be enabled by user)
- ;* - Branches to __main in the C library (which eventually
- ;* calls main()).
- ;* After Reset the CortexM3 processor is in Thread mode,
- ;* priority is Privileged, and the Stack is set to Main.
- ; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- ; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
- ; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
- ; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
- ; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
- ; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- ; </h>
- __initial_sp
- ; </h>
- Heap_Size EQU 0x00000200
- __heap_base
- __heap_limit
- PRESERVE8
- THUMB
- EXPORT __Vectors
- DCD HardFault_Handler ; Hard Fault Handler
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD PendSV_Handler ; PendSV Handler
- DCD SysTick_Handler ; SysTick Handler
- DCD ADC1_2_IRQHandler ; ADC1 & ADC2
- DCD USBWakeUp_IRQHandler ; USB Wakeup from suspend
- DCD DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5
- __Vectors_End
- ; Reset handler
- IMPORT __main
- IMPORT SystemInit
- LDR R0, =SystemInit
- BLX R0
- LDR R0, =__main
- BX R0
- ENDP
- NMI_Handler PROC
- B .
- ENDP
- PROC
- B .
- ENDP
- PROC
- B .
- ENDP
- BusFault_Handler\
- PROC
- B .
- ENDP
- PROC
- B .
- ENDP
- SVC_Handler PROC
- B .
- ENDP
- DebugMon_Handler\
- PROC
- B .
- ENDP
- PendSV_Handler PROC
- EXPORT PendSV_Handler [WEAK]
- B .
- ENDP
- SysTick_Handler PROC
- EXPORT SysTick_Handler [WEAK]
- B .
- ENDP
- EXPORT USBWakeUp_IRQHandler [WEAK]
- WWDG_IRQHandler
- PVD_IRQHandler
- TAMPER_IRQHandler
- RTC_IRQHandler
- FLASH_IRQHandler
- RCC_IRQHandler
- EXTI0_IRQHandler
- EXTI1_IRQHandler
- EXTI2_IRQHandler
- EXTI3_IRQHandler
- EXTI4_IRQHandler
- ADC1_2_IRQHandler
- TIM2_IRQHandler
- TIM3_IRQHandler
- TIM4_IRQHandler
- SPI1_IRQHandler
- SPI2_IRQHandler
- USART1_IRQHandler
- USART2_IRQHandler
- USART3_IRQHandler
- USBWakeUp_IRQHandler
- ADC3_IRQHandler
- FSMC_IRQHandler
- SDIO_IRQHandler
- TIM5_IRQHandler
- SPI3_IRQHandler
- UART4_IRQHandler
- UART5_IRQHandler
- TIM6_IRQHandler
- TIM7_IRQHandler
- B .
- ENDP
- ALIGN
- ELSE
- BX LR
- ALIGN
- ENDIF
- END
- ;******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE*****
复制代码 [/code] |
