我用mega16发送5个字节给mega128a1时,总是接收不到最后一个字节,两者的波特率都是9600。求指导。
mega16:
#ifndef F_CPU
#define F_CPU 16000000UL
#ifndef BAUD
#define BAUD 9600
#include "Anyway_uart.h"
void USART_Init(void)
DDRD&=0xfe;
PORTD=0xff;
/*设置波特率*/
//UBRRH = 0;
//UBRRL = 16;/*设置波特率,16M晶振,57600波特率,参考DataSheet*/
UBRRH = (((F_CPU/BAUD)/16)-1)/256;
UBRRL = (((F_CPU/BAUD)/16)-1)%256;
UCSRB |= (1<<RXEN)|(1<<TXEN)|(1<<RXCIE);
//使能发送,接收,接收中断
void Putc(uint8_t data)
/*等待发送缓冲器为空*/
while( !(UCSRA & (1<<UDRE)));
/*将数据放入缓冲区,发送数据*/
UDR = data;
while(!(UCSRA&(1<<TXC)));//等待发送完成
void putBuffer(uint8_t* data,uint8_t len)
int i;
for (i=0;i<len;i++)
loop_until_bit_is_set(UCSRA, UDRE);
UDR = data;
void Puts(char *str)
while(*str!='\0')
Putc(*str);
str++;
int uart_putchar(char c, FILE *stream)
if (c == '\n')
uart_putchar('\r', stream);
UDR = c;
return 0;
在main函数里循环发送:
_delay_ms(10000);
putBuffer(request,5);
mega128a1:
ISR(USARTF0_RXC_vect)
PORTE.OUTTGL = 0x80;
//清除中断标志位
//When interrupt-driven data reception is used, the receive complete interrupt routine must read
//the received data from DATA in order to clear the RXCIF
recv[recv_count] = USARTF0_DATA;
printf("IRQn recv[%d]=%x\r\n",recv_count,recv[recv_count]);
recv_count++;
if(recv_count == 5)
flag = 1;
recv_count = 0;
每次都只能接收到4个数据!
