自己现在需要FPGA与ARM进行通讯,用的是omap3530上的GPMC总线来实现的。
如图所示如GPMC的总线电路图,与FPGA进行连接,连接上电之后,没有加载驱动,
发现ARM端报错:
UBI error: ubi_io_write: error -5 while writing 2048 bytes to PEB 1195:22528, written 0 bytes
UBI warning: ubi_eba_write_leb: failed to write data to PEB 1195
UBI: recover PEB 1195, move data to PEB 1707
uncorrectable error :
UBI error: ubi_io_read: error -74 while reading 512 bytes from PEB 1195:512, read 512 bytes
UBI warning: ubi_io_read_vid_hdr: bad magic number at PEB 1195: e4c0e400 instead of 55424921
UBI: run torture test for PEB 1707
UBI warning: ubi_ro_mode: switch to read-only mode
UBI error: do_sync_erase: cannot erase PEB 1707, error -5
UBI error: erase_worker: failed to erase PEB 1707, error -5
UBIFS error (pid 546): ubifs_wbuf_sync_nolock: cannot write 2048 bytes to LEB 692:20480
UBI: mark PEB 1707 as bad
UBI error: ubi_io_mark_bad: read-only mode
UBIFS error (pid 546): ubifs_bg_wbufs_sync: cannot sync write-buffer, error -5
UBI error: do_work: work failed with error code -30
UBI error: ubi_thread: ubi_bgt0d: work failed with error code -30
UBIFS warning (pid 546): ubifs_ro_mode: switched to read-only mode, error -5
似乎是文件系统被破坏了?
而且有时候在ARM下输入命令ls的时候会自动重启.
Nand Flash、SRAM、还有现在要用的FPGA是共用的GPMC总线,是不是因为连接了FPGA,设置的地方不对,影响了NAND中的文件系统呢?
请教各位前辈,谢谢! |
