发表于 2013-4-2 11:33:51
用超级终端连接WR340G+,设置为9600,8,n,1,无,得到以下结果
+Unknown PHY: 0141:0C87
Ethernet eth0: MAC address 00:15:6d:aa:ba:60
IP: 0.0.0.0/255.255.255.0, Gateway: 0.0.0.0
Default server: 0.0.0.0
RedBoot(tm) bootstrap and debug environment [ROMRAM]
Ubiquiti Networks certified release, version 0.9.00483.1103151313 - built 13:14:
44, Mar 15 2011
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Board: Ubiquiti Ubiquiti AR2315/6/7/8 based board (Ubiquiti NanoStation2 detecte
d)
Arch: ar2316
RAM: 0x80000000-0x82000000, [0x80040b80-0x80fe1000] available
Flash: 0xbfc00000-0xbfff0000, in 64 blocks of 0x00010000 bytes each
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> cache off
RedBoot> fis load -d -e kernel
Trying LZMA decompression...
Image loaded from 0x80041000-0x801df25c
Entry point: 0x80196040, address range: 0x80042000-0x801bf000
RedBoot> go
[ 0.000000] CPU revision is: 00019064
[ 0.000000] Primary instruction cache 16kB, physically tagged, 4-way, linesiz
e 16 bytes.
[ 0.000000] Primary data cache 16kB 4-way, linesize 16 bytes.
[ 0.000000] Linux version 2.4.27-ubnt0 (buildd@builder) (gcc version 3.3.3) #
2 Mon Dec 19 21:23:00 EET 2011
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 02000000 @ 00000000 (usable)
[ 0.000000] On node 0 totalpages: 8192
[ 0.000000] zone(0): 8192 pages.
[ 0.000000] zone(1): 0 pages.
[ 0.000000] zone(2): 0 pages.
[ 0.000000] Kernel command line: console=ttyS0,9600 console=ttyS0,9600 root=/
dev/mtdblock2 rootfstype=squashfs init=/linuxrc ro
[ 0.000000] Using 92.000 MHz high precision timer.
[ 0.010000] Calibrating delay loop... 181.45 BogoMIPS
[ 0.300000] Memory: 30436k/32768k available (1351k kernel code, 2332k reserve
d, 88k data, 68k init, 0k highmem)
[ 0.420000] Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.500000] Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.580000] Mount cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.660000] Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.740000] Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.820000] Checking for 'wait' instruction... unavailable.
[ 0.890000] POSIX conformance testing by UNIFIX
[ 0.940000] Linux NET4.0 for Linux 2.4
[ 0.990000] Based upon Swansea University Computer Society NET3.039
[ 1.060000] Initializing RT netlink socket
[ 1.110000] Starting kswapd
[ 1.150000] Squashfs 2.2-r2 (released 2005/09/08) (C) 2002-2005 Phillip Lough
er
[ 1.240000] pty: 256 Unix98 ptys configured
[ 1.290000] Serial driver version 5.05c (2001-07-08) with no serial options e
nabled
[ 1.380000] ttyS00 at 0xb1100003 (irq = 37) is a 16550A
[ 1.440000] PPP generic driver version 2.4.2
[ 1.490000] PPP Deflate Compression module registered
[ 1.550000] MPPE/MPPC encryption/compression module registered
[ 1.620000] spiflash: JEDEC compatible device detected (Manufacturer: 0xC2; d
evice: 0x2016)
[ 1.730000] mtd: adjusted dev mtd2 size from 61440 to 65536 bytes
[ 1.800000] Creating 8 MTD partitions on "spiflash":
[ 1.860000] 0x00000000-0x00030000 : "RedBoot"
[ 1.910000] 0x00030000-0x00100000 : "kernel"
[ 1.960000] 0x00100000-0x003c0000 : "cramfs"
[ 2.010000] 0x003c0000-0x003e0000 : "cfg"
[ 2.060000] 0x003e0000-0x003f0000 : "FIS directory"
[ 2.120000] 0x003ef000-0x003f0000 : "RedBoot config"
[ 2.180000] mtd: partition "RedBoot config" doesn't start on an erase block b
oundary -- force read-only
[ 2.290000] 0x003f0000-0x00400000 : "EEPROM"
[ 2.340000] 0x00030000-0x003e0000 : "Working flash"
[ 2.400000] Initializing Cryptographic API
[ 2.450000] NET4: Linux TCP/IP 1.0 for NET4.0
[ 2.500000] IP: routing cache hash table of 512 buckets, 4Kbytes
[ 2.580000] TCP: Hash tables configured (established 2048 bind 4096)
[ 2.650000] IPv4 over IPv4 tunneling driver
[ 2.700000] GRE over IPv4 tunneling driver
[ 2.750000] Linux IP multicast router 0.06 plus PIM-SM
[ 2.820000] NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
[ 2.890000] Ebtables v2.0 registered
[ 2.930000] NET4: Ethernet Bridge 008 for NET4.0
[ 2.980000] Bridge firewalling registered
[ 3.030000] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[ 3.110000] All bugs added by David S. Miller <davem@redhat.com>
[ 3.190000] VFS: Mounted root (squashfs filesystem) readonly.
[ 3.260000] Freeing unused kernel memory: 68k freed
[ 3.330000] Warning: unable to open an initial console.
[ 3.810000] Algorithmics/MIPS FPU Emulator v1.5 |
