原理图
代码:
/************************************mian.c********************************- /********************************************************************
- 文件名:万年历.c
- 晶振频率:12MHz
- 芯片:STC89C52
- #include "reg52.h"
- #include "intrins.h"
- #include "string.h"
- #include "LCD_12864.c"
- #define uchar unsigned char
- #define uint unsigned int
- /*extern void LCD_Initialize(void);
- extern void Display_A_Char_8X16(uchar P,uchar L,uchar *M);
- extern void Display_A_WORD(uchar P,uchar L,uchar *M);
- //在调整日期时间时,用该位决定是否反白显示
- extern bit Reverse_Display=0;
- sbit SDA=P1^0; //DS1302数据线
- sbit CLK=P1^1; //DS1302时钟线
- sbit RST=P1^2; //DS1302复位线
- sbit k1=P3^4; //选择
- sbit k2=P3^5; //加
- sbit k3=P3^6; //减
- sbit k4=P3^7; //确定
- uchar tCount=0;
- //一年中每个月的天数,2月的天数由年份决定
- uchar MonthsDays[]={0,31,0,31,30,31,30,31,31,30,31,30,31};
- //所读取的日期时间
- uchar DateTime[7];
- //当前调整的时间对象:秒,分,时,日,月,年(0,1,2,3,4,6)
- //5对应星期,星期调节由年月日调整自动完成
- char Adjust_Index=-1;
- //水平与垂直偏移
- uchar H_Offset=10,V_Page_Offset=0;
- //年月日,星期,时分秒汉字点阵(16*16)-------------------------------
- uchar code DATE_TIME_WORDS[]={
- /*-- 文字: 年 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
- 0x00,0x20,0x18,0xC7,0x44,0x44,0x44,0x44,0xFC,0x44,0x44,0x44,0x44,0x04,0x00,0x00,
- 0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
- /*-- 文字: 月 --*/
- 0x00,0x00,0x00,0xFE,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0xFE,0x00,0x00,0x00,
- 0x80,0x40,0x30,0x0F,0x02,0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x00,0x00,0x00,
- /*-- 文字: 日 --*/
- 0x00,0x00,0x00,0xFE,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0xFE,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x00,0x00,0x00,0x00,
- /*-- 文字: 星 --*/
- 0x00,0x00,0x00,0xBE,0x2A,0x2A,0x2A,0xEA,0x2A,0x2A,0x2A,0x3E,0x00,0x00,0x00,0x00,
- 0x00,0x44,0x42,0x49,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x41,0x40,0x00,0x00,
- /*-- 文字: 期 --*/
- 0x00,0x04,0xFF,0x24,0x24,0x24,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00,
- 0x88,0x48,0x2F,0x09,0x09,0x19,0xAF,0x48,0x30,0x0F,0x02,0x42,0x82,0x7F,0x00,0x00,
- /*-- 文字: 时 --*/
- 0x00,0xFC,0x84,0x84,0x84,0xFC,0x00,0x10,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x00,
- 0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00,0x01,0x06,0x40,0x80,0x7F,0x00,0x00,0x00,
- /*-- 文字: 分 --*/
- 0x80,0x40,0x20,0x90,0x88,0x86,0x80,0x80,0x80,0x83,0x8C,0x10,0x20,0x40,0x80,0x00,
- 0x00,0x80,0x40,0x20,0x18,0x07,0x00,0x40,0x80,0x40,0x3F,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: 秒 --*/
- 0x24,0x24,0xA4,0xFE,0x23,0x22,0x00,0xC0,0x38,0x00,0xFF,0x00,0x08,0x10,0x60,0x00,
- 0x08,0x06,0x01,0xFF,0x01,0x06,0x81,0x80,0x40,0x40,0x27,0x10,0x0C,0x03,0x00,0x00,
- //星期几的汉字点阵(16*16)----------------------------------
- uchar code WEEDDAY_WORDS[]={
- /*-- 文字: 日 --*/
- /*-- 文字: 一 --*/
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- /*-- 文字: 二 --*/
- 0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00,
- 0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,
- /*-- 文字: 三 --*/
- 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
- 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- /*-- 文字: 四 --*/
- 0x00,0xFC,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
- 0x00,0x7F,0x28,0x24,0x23,0x20,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x7F,0x00,0x00,
- /*-- 文字: 五 --*/
- 0x00,0x02,0x42,0x42,0x42,0xC2,0x7E,0x42,0x42,0x42,0x42,0xC2,0x02,0x02,0x00,0x00,
- 0x40,0x40,0x40,0x40,0x78,0x47,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x00,
- /*-- 文字: 六 --*/
- 0x20,0x20,0x20,0x20,0x20,0x20,0x21,0x22,0x2C,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- 0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x01,0x02,0x04,0x18,0x60,0x00,0x00,
- //半角数字点阵(8*16)----------------------------------------------------
- uchar code DIGITS[]={
- /*-- 文字: 0 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
- /*-- 文字: 1 --*/
- 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- /*-- 文字: 2 --*/
- 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
- /*-- 文字: 3 --*/
- 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 4 --*/
- 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,
- /*-- 文字: 5 --*/
- 0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 6 --*/
- 0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 7 --*/
- 0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
- /*-- 文字: 8 --*/
- 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
- /*-- 文字: 9 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,
- //向DS1302写入一字节
- void Write_A_Byte_TO_DS1302(uchar x)
- { uchar i;
- for(i=0;i<8;i++)
- { SDA=x&1; CLK=1; CLK=0; x>>=1;
- //从DS1302读取一字节
- uchar Get_A_Byte_FROM_DS1302(void)
- { uchar i,b,t;
- for(i=0;i<8;i++)
- { b>>=1; t=SDA; b|=t<<7; CLK=1; CLK=0;
- //BCD码转换
- return(b/16*10+b%16);
- //从DS1302指定位置读数据
- uchar Read_Data(uchar addr)
- { uchar dat;
- RST=0; CLK=0; RST=1;
- Write_A_Byte_TO_DS1302(addr);
- dat=Get_A_Byte_FROM_DS1302();
- CLK=1; RST=0;
- return(dat);
- //向DS1302某地址写入数据
- void Write_DS1302(uchar addr,uchar dat)
- { CLK=0; RST=1;
- Write_A_Byte_TO_DS1302(dat);
- CLK=0; RST=0;
- //设置时间
- void SET_DS1302(void)
- { uchar i;
- Write_DS1302(0x8e,0x00);
- //秒分时日月年依次写入
- for(i=0;i<7;i++)
- { //秒的起始地址1000 0000(0x80)
- //后续依次是分,时,月,周,年,写入地址每次递增2
- Write_DS1302(0x80+2*i,(DateTime[i]/10<<4)|(DateTime[i]%10));
- Write_DS1302(0x8e,0x80);
- //读取当前日期时间
- void GetTime(void)
- { uchar i;
- for(i=0;i<7;i++)
- { DateTime[i]=Read_Data(0x81+2*i);
- //半断是否为闰年
- uchar isLeapYear(uint y)
- { return((y%4==0&&y%100!=0)||(y%400==0));
- //求自2000.1.1开始的任何一天是星期几
- //函数没有通过,求出总天数后在求出星期几
- //因为求总天数可能会月出uint的范围
- void RefreshWeekDay(void)
- { uint i,d,w=5; //已知1999.12.31是周五
- for(i=2000;i<2000+DateTime[6];i++)
- { d=isLeapYear(i)?366:365;
- w=(w+d)%7;
- d=0;
- for(i=1;i<DateTime[4];i++)d+=MonthsDays[i];
- d+=DateTime[3];
- //保存星期,0~6表示星期日,星期一,二,、、、六,为了与DS1302的星期格式匹配,返回值需要加1
- DateTime[5]=(w+d)%7+1;
- //年月日时分秒++/--
- void DateTime_Adjust(char x)
- { switch(Adjust_Index)
- { case 6: //年00-99
- if(x==1&&DateTime[6]<99)DateTime[6]++;
- if(x==-1&&DateTime[6]>0)DateTime[6]--;
- //获取2月天数
- MonthsDays[2]=isLeapYear(2000+DateTime[6])?29:28;
- //如果年份变化后当前月份的天数大于上限则设为上限
- if(DateTime[3]>MonthsDays[DateTime[4]])DateTime[3]=MonthsDays[DateTime[4]];
- RefreshWeekDay(); //刷新星期
- break;
- case 4: //月01-12
- if(x==1&&DateTime[4]<12)DateTime[4]++;
- if(x==-1&&DateTime[4]>1)DateTime[4]--;
- //获取2月份天数
- //如果月份变化后当前月份的天数大于上限则设为上限
- break;
- case 3: //日00-28/29/30/31;调节之前首先根据年份得出该年中2月的天数
- //根据当前月份决定调节日期的上限
- if(x==1&&DateTime[3]<MonthsDays[DateTime[4]])DateTime[3]++;
- if(x==-1&&DateTime[3]>1)DateTime[3]--;
- break;
- case 2: //时
- if(x==1&&DateTime[2]<23)DateTime[2]++;
- if(x==-1&&DateTime[3]>1)DateTime[2]--;
- break;
- case 1: //分
- if(x==1&&DateTime[1]<59)DateTime[1]++;
- if(x==-1&&DateTime[1]>1)DateTime[1]--;
- break;
- case 0: //秒
- if(x==1&&DateTime[0]<59)DateTime[0]++;
- if(x==-1&&DateTime[0]>1)DateTime[0]--;
- //定时器0每秒刷新LCD显示
- void T0_INT(void) interrupt 1
- { TH0=-50000/256;
- TL0=-50000%256;
- if(++tCount!=2)return;
- tCount=0;
- if(Adjust_Index==-1)GetTime(); //如果未执行调整操作则正常读取当前时间
- //年后两位
- Reverse_Display=Adjust_Index==6; /*等同于
- { if(Adjust_Index==6)Reverse_Display=1;
- else Reverse_Display=0; } */
- Display_A_Char_8X16(V_Page_Offset,16+H_Offset,DIGITS+DateTime[6]/10*16);
- Display_A_Char_8X16(V_Page_Offset,24+H_Offset,DIGITS+DateTime[6]%10*16);
- //月
- Reverse_Display=Adjust_Index==4;
- Display_A_Char_8X16(V_Page_Offset,48+H_Offset,DIGITS+DateTime[4]/10*16);
- Display_A_Char_8X16(V_Page_Offset,56+H_Offset,DIGITS+DateTime[4]%10*16);
- //日
- Reverse_Display=Adjust_Index==3;
- Display_A_Char_8X16(V_Page_Offset,80+H_Offset,DIGITS+DateTime[3]/10*16);
- Display_A_Char_8X16(V_Page_Offset,88+H_Offset,DIGITS+DateTime[3]%10*16);
- //星期
- Reverse_Display=Adjust_Index==5;
- Display_A_WORD(V_Page_Offset+2,96+H_Offset,WEEDDAY_WORDS+(DateTime[5]-1)*32);
- //时
- Reverse_Display=Adjust_Index==2;
- Display_A_Char_8X16(V_Page_Offset+5,16+H_Offset,DIGITS+DateTime[2]/10*16);
- Display_A_Char_8X16(V_Page_Offset+5,24+H_Offset,DIGITS+DateTime[2]%10*16);
- //分
- Reverse_Display=Adjust_Index==1;
- Display_A_Char_8X16(V_Page_Offset+5,48+H_Offset,DIGITS+DateTime[1]/10*16);
- Display_A_Char_8X16(V_Page_Offset+5,56+H_Offset,DIGITS+DateTime[1]%10*16);
- //秒
- Reverse_Display=Adjust_Index==0;
- Display_A_Char_8X16(V_Page_Offset+5,80+H_Offset,DIGITS+DateTime[0]/10*16);
- Display_A_Char_8X16(V_Page_Offset+5,88+H_Offset,DIGITS+DateTime[0]%10*16);
- //键盘中断(INT0)
- void EX_INT0(void) interrupt 0
- { if(k1==0) //选择调整对象
- { if(Adjust_Index==-1||Adjust_Index==0)Adjust_Index=7;
- Adjust_Index--;
- if(Adjust_Index==5)Adjust_Index=4; //跳过对星期的调整
- else if(k2==0)DateTime_Adjust(1); //加
- else if(k3==0)DateTime_Adjust(-1); //减
- else if(k4==0) //确定
- { SET_DS1302(); //将调整后的时间写入DS1302
- Adjust_Index=-1; //操作索引重设为-1,时间继续正常显示
- //主程序
- void main()
- { //液晶初始化
- LCD_Initialize();
- //显示年的固定前两位
- Display_A_Char_8X16(V_Page_Offset,0+H_Offset,DIGITS+2*16);
- Display_A_Char_8X16(V_Page_Offset,8+H_Offset,DIGITS);
- //显示固定汉字:年月日,星期,时分秒
- Display_A_WORD(V_Page_Offset,32+H_Offset,DATE_TIME_WORDS+0*32);
- Display_A_WORD(V_Page_Offset,64+H_Offset,DATE_TIME_WORDS+1*32);
- Display_A_WORD(V_Page_Offset,96+H_Offset,DATE_TIME_WORDS+2*32);
- Display_A_WORD(V_Page_Offset+2,64+H_Offset,DATE_TIME_WORDS+3*32);
- Display_A_WORD(V_Page_Offset+2,80+H_Offset,DATE_TIME_WORDS+4*32);
- Display_A_WORD(V_Page_Offset+5,32+H_Offset,DATE_TIME_WORDS+5*32);
- Display_A_WORD(V_Page_Offset+5,64+H_Offset,DATE_TIME_WORDS+6*32);
- Display_A_WORD(V_Page_Offset+5,96+H_Offset,DATE_TIME_WORDS+7*32);
- //允许INT0,T0中断
- IE=0x83;
- IP=0x01;
- IT0=0x01;
- TH0=-50000/256;
- TL0=-50000%256;
- TR0=1;
- while(1);
复制代码 /******************************LCD12864.c*******************************************/- #include "reg52.h"
- #define LCD_DB_PORT P0 //液晶DB0~DB7
- #define LCD_START_ROW 0xc0 //起始行
- #define LCD_PAGE 0xb8 //页指令
- #define LCD_COL 0x40 //列指令
- //液晶引脚定义
- sbit LCD_DI=P2^0;
- sbit LCD_RW=P2^1;
- sbit LCD_E=P2^2;
- sbit LCD_CS1=P2^3;
- sbit LCD_CS2=P2^4;
- sbit LCD_RST=P2^5;
- bit Reverse_Display=0;
- //检查LCD是否忙
- bit LCD_Check_Busy(void)
- { LCD_DB_PORT=0xff;
- LCD_RW=1; _nop_(); LCD_DI=0;
- LCD_E=1; _nop_(); LCD_E=0;
- return(bit)(P0&0x80);
- //向LCD发送命令
- void LCD_Write_Command(uchar c)
- { while(LCD_Check_Busy());
- LCD_DB_PORT=0xff; LCD_RW=0; _nop_(); LCD_DI=0;
- LCD_DB_PORT=c; LCD_E=1; _nop_(); LCD_E=0;
- //向LCD发送数据
- void LCD_Write_Data(uchar d)
- LCD_DB_PORT=0xff;
- LCD_RW=0;_nop_();LCD_DI=1;
- //根据Reverse_Display决定是否反相显示
- if(!Reverse_Display)LCD_DB_PORT=d;else LCD_DB_PORT=~d;
- LCD_E=1;_nop_();LCD_E=0;
- //初始化LCD
- void LCD_Initialize(void)
- { LCD_CS1=1;LCD_CS2=1;
- LCD_Write_Command(0x38);
- LCD_Write_Command(0x0f);
- LCD_Write_Command(0x01);
- LCD_Write_Command(0x06);
- LCD_Write_Command(LCD_START_ROW);
- //通用显示函数
- //从第P页第L列开始显示W个字节数据,数据在r所指向的缓冲
- //每字节8位是垂直显示的,高位在下,低位在上
- //每个8*128的矩形区域为一页
- //整个LCD右由64*64的左半屏和64*64的右半屏构成
- void Common_Show(uchar P,uchar L,uchar W,uchar *r)
- { uchar i;
- if(L<64) //显示在左半屏或左右半屏
- { LCD_CS1=1;LCD_CS2=0;
- LCD_Write_Command(LCD_PAGE+P);
- LCD_Write_Command(LCD_COL+L);
- if(L+W<64) //全部显示在左右半屏
- { for(i=0;i<W;i++)LCD_Write_Data(r[i]);
- else //如果越界则跨左右半屏显示
- { for(i=0;i<64-L;i++)LCD_Write_Data(r[i]); //左半屏显示
- LCD_CS1=0;LCD_CS2=1; //右半屏显示
- LCD_Write_Command(LCD_COL);
- for(i=64;i<W;i++)LCD_Write_Data(r[i]);
- else //全部显示在右半屏
- { LCD_CS1=0;LCD_CS2=1;
- LCD_Write_Command(LCD_COL+L-61);
- for(i=0;i<W;i++)LCD_Write_Data(r[i]);
- //显示8*16点阵字符
- void Display_A_Char_8X16(uchar P,uchar L,uchar *M)
- { Common_Show(P,L,8,M);
- Common_Show(P+1,L,8,M+8);
- //显示一个16*16点阵汉字
- void Display_A_WORD(uchar P,uchar L,uchar *M)
- { Common_Show(P,L,16,M); //显示汉字上半部分
- Common_Show(P+1,L,16,M+16);
复制代码 编译无法通过,error and warning
附件
