发表于 2014-10-9 17:41:00
//功 能:通过RC522和ISO14443卡通讯
//参数说明:Command[IN]:RC522命令字
// pInData[IN]:通过RC522发送到卡片的数据
// InLenByte[IN]:发送数据的字节长度
// pOutData[OUT]:接收到的卡片返回数据
// *pOutLenBit[OUT]:返回数据的位长度
char PcdComMF522(unsigned char Command,
unsigned char *pInData,
unsigned char InLenByte,
unsigned char *pOutData,
unsigned int *pOutLenBit)
char status = MI_ERR;
unsigned char irqEn = 0x00;
unsigned char waitFor = 0x00;
unsigned char lastBits;
unsigned char n;
unsigned int i;
switch (Command)
case PCD_AUTHENT:
irqEn = 0x12;
waitFor = 0x10;
case PCD_TRANSCEIVE:
irqEn = 0x77;
waitFor = 0x30;
default:
WriteRawRC(ComIEnReg,irqEn|0x80);
ClearBitMask(ComIrqReg,0x80);
WriteRawRC(CommandReg,PCD_IDLE);
SetBitMask(FIFOLevelReg,0x80);
for (i=0; i<InLenByte; i++)
{ WriteRawRC(FIFODataReg, pInData); }
WriteRawRC(CommandReg, Command);
if (Command == PCD_TRANSCEIVE)
{ SetBitMask(BitFramingReg,0x80); }
i = 600;//根据时钟频率调整,操作M1卡最大等待时间25ms
do
n = ReadRawRC(ComIrqReg);
i--;
while ((i!=0) && !(n&0x01) && !(n&waitFor));
ClearBitMask(BitFramingReg,0x80);
if (i!=0)
if(!(ReadRawRC(ErrorReg)&0x1B))
status = MI_OK;
if (n & irqEn & 0x01)
{ status = MI_NOTAGERR; }
n = ReadRawRC(FIFOLevelReg);
lastBits = ReadRawRC(ControlReg) & 0x07;
if (lastBits)
{ *pOutLenBit = (n-1)*8 + lastBits; }
{ *pOutLenBit = n*8; }
if (n == 0)
{ n = 1; }
if (n > MAXRLEN)
{ n = MAXRLEN; }
for (i=0; i<n; i++)
{ pOutData = ReadRawRC(FIFODataReg);
_nop_();_nop_();_nop_();_nop_();_nop_();
{ status = MI_ERR; }
SetBitMask(ControlReg,0x80); // stop timer now
return status;
具体需要怎样修改呢?麻烦请再指教下!
现在遇到FIFO溢出的情况,想采用中断的方式试一下。 |
