SPI_InitTypeDef SPI_InitStructure;
uint16_t SPI1_Buffer_Tx[BufferSize] = {0x0102, 0x0304, 0x0506, 0x0708, 0x090A, 0x0B0C,
0x0D0E, 0x0F10, 0x1112, 0x1314, 0x1516, 0x1718,
0x191A, 0x1B1C, 0x1D1E, 0x1F20, 0x2122, 0x2324,
0x2526, 0x2728, 0x292A, 0x2B2C, 0x2D2E, 0x2F30,
0x3132, 0x3334, 0x3536, 0x3738, 0x393A, 0x3B3C,
0x3D3E, 0x3F40};
uint16_t SPI2_Buffer_Tx[BufferSize] = {0x5152, 0x5354, 0x5556, 0x5758, 0x595A, 0x5B5C,
0x5D5E, 0x5F60, 0x6162, 0x6364, 0x6566, 0x6768,
0x696A, 0x6B6C, 0x6D6E, 0x6F70, 0x7172, 0x7374,
0x7576, 0x7778, 0x797A, 0x7B7C, 0x7D7E, 0x7F80,
0x8182, 0x8384, 0x8586, 0x8788, 0x898A, 0x8B8C,
0x8D8E, 0x8F90};
uint16_t SPI1_Buffer_Rx[BufferSize], SPI2_Buffer_Rx[BufferSize];
uint32_t TxIdx = 0, RxIdx = 0;
__IO uint16_t CRC1Value = 0, CRC2Value = 0;
volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = FAILED;
/* Private functions ---------------------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
TestStatus Buffercmp(uint16_t* pBuffer1, uint16_t* pBuffer2, uint16_t BufferLength);
* @brief Main program
* @param None
* @retval None
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f10x_xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f10x.c file
/* System clocks configuration ---------------------------------------------*/
RCC_Configuration();
/* GPIO configuration ------------------------------------------------------*/
GPIO_Configuration();
/* SPI1 configuration ------------------------------------------------------*/
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
/* SPI2 configuration ------------------------------------------------------*/
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
SPI_Init(SPI2, &SPI_InitStructure);
/* Enable SPI1 CRC calculation */
SPI_CalculateCRC(SPI1, ENABLE);
/* Enable SPI2 CRC calculation */
SPI_CalculateCRC(SPI2, ENABLE);
/* Enable SPI1 */
SPI_Cmd(SPI1, ENABLE);
/* Enable SPI2 */
SPI_Cmd(SPI2, ENABLE);
/* Transfer procedure */
while (TxIdx < BufferSize - 1)
/* Wait for SPI1 Tx buffer empty */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
/* Send SPI2 data */
SPI_I2S_SendData(SPI2, SPI2_Buffer_Tx[TxIdx]);
/* Send SPI1 data */
SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx++]);
/* Wait for SPI2 data reception */
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
/* Read SPI2 received data */
SPI2_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPI2);
/* Wait for SPI1 data reception */
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
/* Read SPI1 received data */
SPI1_Buffer_Rx[RxIdx++] = SPI_I2S_ReceiveData(SPI1);
/* Wait for SPI2 Tx buffer empty */
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
/* Send last SPI2_Buffer_Tx data */
/* Enable SPI2 CRC transmission */
SPI_TransmitCRC(SPI2);
/* Send last SPI1_Buffer_Tx data */
SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx]);
/* Enable SPI1 CRC transmission */
SPI_TransmitCRC(SPI1);
/* Wait for SPI1 last data reception */
/* Read SPI1 last received data */
SPI1_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPI1);
/* Wait for SPI2 last data reception */
/* Read SPI2 last received data */
这一段我不怎么明白 它的CRC值怎么发过去的
/* Wait for SPI1 data reception: CRC transmitted by SPI2 */
/* Wait for SPI2 data reception: CRC transmitted by SPI1 */
/* Check the received data with the send ones */
TransferStatus1 = Buffercmp(SPI2_Buffer_Rx, SPI1_Buffer_Tx, BufferSize);
TransferStatus2 = Buffercmp(SPI1_Buffer_Rx, SPI2_Buffer_Tx, BufferSize);
/* TransferStatus1, TransferStatus2 = PASSED, if the data transmitted and received
are correct */
/* TransferStatus1, TransferStatus2 = FAILED, if the data transmitted and received
are different */
/* Test on the SPI1 CRC Error flag */
if ((SPI_I2S_GetFlagStatus(SPI1, SPI_FLAG_CRCERR)) == SET)
/* Test on the SPI2 CRC Error flag */
if ((SPI_I2S_GetFlagStatus(SPI2, SPI_FLAG_CRCERR)) == SET)
TransferStatus1 = FAILED;
/* Read SPI1 received CRC value */
CRC1Value = SPI_I2S_ReceiveData(SPI1);
/* Read SPI2 received CRC value */
CRC2Value = SPI_I2S_ReceiveData(SPI2);
大神们,帮我一下哈!不胜感激! |
