看了它的datasheet,功耗真是相当低,都可以拼单片机的功耗了,不过主频只能跑到48MHz。从它官网上拷了段介绍。
The Atmel® SAM4L microcontrollers (MCUs) redefine the power benchmark for Cortex™-M4 processor-based devices, delivering the lowest power in active mode (down to 90µA/MHz) as well as sleep mode with full RAM retention (1.5µA) with the shortest wake-up time (down to 1.5µs). Embedding Atmel picoPower® technology, the SAM4L family provides highly efficient signal processing, ease of use and high-speed communication peripherals—ideal for power-sensitive designs in the industrial, healthcare and consumer application areas.
Key Features
Atmel picoPower Technology — Ensures that devices are developed from the ground up for the lowest power consumption possible, enabling long battery life
Atmel QTouch Capacitive Touch Support — Includes hardware integrated capacitive touch module based on QTouch® technology for fast development of touch and proximity functionality with ultra low power consumption
Highly Efficient Signal Processing — Thanks to the Cortex-M4 architecture, the SAM4L microcontrollers feature extended single-cycle multiply-accumulate instructions, optimized SIMD arithmetic and saturating arithmetic instructions for highly efficient signal processing
Ease of Use — Its ecosystem of software tools and support for Atmel Studio 6 integrated development environment enables an efficient design process and reduces time to market
LC Series
Benefits
Description
Cortex-M4 microcontroller at 48MHz
Lowest power consumption in active and sleep modes
128KB to 256KB embedded Flash
Hardware capacitive touch module supported by Atmel QTouch technology
Up to 4x40-segment LCD controller
The SAM4LC Cortex-M4 processor-based Flash microcontrollers offer the industry’s lowest power consumption and fastest wake-up. The devices feature an LCD controller with up to 4x40 segments, an embedded capacitive touch module supported by Atmel QTouch technology, USB host, and multiple serial communication interfaces. They are ideal for a wide range of industrial, healthcare and consumer applications.
Details
View Parameters
Device
Description
ATSAM4LC4A
Cortex-M4 microcontroller with 256KB Flash, picoPower technology, LCD, hardware cryptography, USB host and device, QTouch technology, 48 pins
ATSAM4LC4B
Cortex-M4 microcontroller with 256KB Flash, picoPower technology, LCD, hardware cryptography, USB host and device, QTouch technology, 64 pins
ATSAM4LC4C
Cortex-M4 microcontroller with 256KB Flash, picoPower technology, LCD, hardware cryptography, USB host and device, QTouch technology, 100 pins
ATSAM4LC2A
Cortex-M4 microcontroller with 128KB Flash, picoPower technology, LCD, hardware cryptography, USB host and device, QTouch technology, 48 pins
ATSAM4LC2B
Cortex-M4 microcontroller with 128KB Flash, picoPower technology, LCD, hardware cryptography, USB host and device, QTouch technology, 64 pins
ATSAM4LC2C
Cortex-M4 microcontroller with 128KB Flash, picoPower technology, LCD, hardware cryptography, USB host and device, QTouch technology, 100 pins
LS Series
Benefits
Description
The SAM4LS Cortex-M4 processor-based Flash microcontrollers offer the industry’s lowest power consumption and fastest wake-up. The devices feature an embedded capacitive touch module supported by Atmel QTouch technology, USB device, and multiple serial communication interfaces. They are ideal for a wide range of industrial, healthcare and consumer applications.
Details
View Parameters
Device
Description
ATSAM4LS4A
Cortex-M4 microcontroller with 256KB Flash, picoPower technology, USB device, QTouch technology, 48 pins
ATSAM4LS4B
Cortex-M4 microcontroller with 256KB Flash, picoPower technology, USB device, QTouch technology, 64 pins
ATSAM4LS4C
Cortex-M4 microcontroller with 256KB Flash, picoPower technology, USB device, QTouch technology, 100 pins
ATSAM4LS2A
Cortex-M4 microcontroller with 128KB Flash, picoPower technology, USB device, QTouch technology, 48 pins
ATSAM4LS2B
Cortex-M4 microcontroller with 128KB Flash, picoPower technology, USB device, QTouch technology, 64 pins
ATSAM4LS2C
Cortex-M4 microcontroller with 128KB Flash, picoPower technology, USB device, QTouch technology, 100 pins |
