发表于 2013-3-24 23:32:35
主函数也来了- int main(void)
- signed char brightness=8;
- long int num = 0;
- int i=-20;
- char temp=0;
- TM1638_init();
- TM1638_set_brightness(4);
- uart_init(9600);
- timer_init();
- ADS1232_init(CHANNEL2, GAIN_128, SPEED_10, TEMP_OFF);
- EA = 1;
- while(1)
- communicate_with_HMI();
- TM1638_display_num(i++);
- timer0_main_loop();
- key_main_loop();
- if(key1_on)
- LED1 = ~LED1;
- temp = ADS1232_read_value(&num);
- if(temp==ADS1232_READ_FINISH)
- printf("%8ld\r\n", num);
- if(f_1s)
- LED2 = ~LED2;
复制代码 |
