我用中断写的接收端程序,但是只有第一次他irq脚由高电位跳到低电位,然后向status寄存器写相应的位
为1后,irq脚仍旧没有恢复为高电位。然后就无法响应后面的事情了- #include <reg52.h>
- #include <intrins.h>
- typedef unsigned char uint;//uint is a byte long
- sbit MISO =P1^5;
- sbit MOSI =P1^1;
- sbit SCK =P1^6;
- sbit CE =P1^7;
- sbit CSN =P1^2;
- sbit IRQ =P3^3;
- sbit LED=P3^7;
- #define ADR_WIDTH 5
- #define AW_ADR_WIDTH 0x03
- #define PLOAD_WIDTH 20
- uint const TX_ADDRESS[ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //address that the RF packets contain
- uint const RX_ADDRESS[ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //RF packets with *which address* that the pipes like to receive
- //THE COMMANDS
- #define READ_REG 0x00
- #define WRITE_REG 0x20
- #define RD_RX_PLOAD 0x61
- #define WR_TX_PLOAD 0xA0
- #define FLUSH_TX 0xE1
- #define FLUSH_RX 0xE2
- #define REUSE_TX_PL 0xE3
- #define NOP 0xFF
- //THE REGISTERS' ADDRESSES
- #define CONFIG 0x00
- #define EN_AA 0x01
- #define EN_RXADDR 0x02
- #define SETUP_AW 0x03
- #define SETUP_RETR 0x04
- #define RF_CH 0x05
- #define RF_SETUP 0x06
- #define STATUS 0x07
- #define OBSERVE_TX 0x08
- #define CD 0x09
- #define RX_ADDR_P0 0x0A
- #define RX_ADDR_P1 0x0B
- #define RX_ADDR_P2 0x0C
- #define RX_ADDR_P3 0x0D
- #define RX_ADDR_P4 0x0E
- #define RX_ADDR_P5 0x0F
- #define TX_ADDR 0x10
- #define RX_PW_P0 0x11
- #define RX_PW_P1 0x12
- #define RX_PW_P2 0x13
- #define RX_PW_P3 0x14
- #define RX_PW_P4 0x15
- #define RX_PW_P5 0x16
- #define FIFO_STATUS 0x17
- uint bdata sta;
- sbit RX_DR =sta^6;
- sbit TX_DS =sta^5;
- sbit MAX_RT =sta^4;
- //THE FUNCTIONS
- uint SPI_write_byte(uint the_byte){
- uint count;
- SCK=0;
- for (count=0;count<8;count++){
- MOSI=(the_byte&0x80);//get the left most bit of the byte,and put on MOSI
- the_byte=the_byte<<1;//left move one bit
- SCK=1; //the SCK upside occurs,nrf24 eats the bit on mosi,nrf24 generates the bit on miso
- the_byte = the_byte|MISO;//the right most bit of the byte become MISO
- SCK=0;
- return the_byte;
- uint SPI_WRITE_REG_DATA_OR_CMD(uint reg,uint data_cmd){
- uint status;
- CSN =0;
- status =SPI_write_byte(reg);
- SPI_write_byte(data_cmd);
- CSN=1;
- return status;
- uint SPI_WRITE_REG_ARRAY(uint reg,uint * array,uint length){
- uint status,count;
- CSN=0;
- for (count=0;count<length;count++){
- SPI_write_byte(array[count]);
- CSN=1;
- return status;
- void inerDelay_us(unsigned char n){
- for(;n>0;n--) _nop_();
- void init_NRF24L01(void){
- inerDelay_us(200);//100 us is okay,but 100 us as redundance
- CE=0; //let nrf24 stop Trans/Recev packets
- CSN=0; //let spi starts to work
- SCK=0; //ready for SCK upside
- //set the addresses width
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+SETUP_AW,AW_ADR_WIDTH);
- //write the addr width
- SPI_WRITE_REG_ARRAY(WRITE_REG+TX_ADDR,TX_ADDRESS,ADR_WIDTH);
- SPI_WRITE_REG_ARRAY(WRITE_REG+RX_ADDR_P0,RX_ADDRESS,ADR_WIDTH);
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+EN_RXADDR,0x01); //allow pipe0 to receive packets
- // SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+EN_AA,0x01); //allow pipe0 auto ACK,enter the SHOCKBURST MODE
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+EN_AA,0x00);
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+RF_CH,0); //let the channel become 2.4000 GHz
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+RX_PW_P0,PLOAD_WIDTH);//set the payload width of pipe0
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+RF_SETUP,0x07); //let the data rate 1 Mbps,the power amplifier 0 dBm
- CSN=1;
- void SET_RX_MODE(void){
- CE=0; //stop nrf24 Trans/Recv
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+CONFIG,0x0f);
- //1. allow all 3 interrupts,
- //2. allow 16 bits CRC code,
- //3. start PWR_UP,
- //4. PRIM_RX=1,let nrf24 become RX MODE
- CE=1; //start listining to receive packets
- inerDelay_us(200);//130 us is okay,but 70 us as redundance
- uint SPI_READ_REG(uint reg){
- uint status,val;
- CSN=0;
- status=SPI_write_byte(READ_REG+reg);//bcs READ_REG =0,so just a form for uinty
- val=SPI_write_byte(READ_REG+0);
- CSN=1;
- return val;
- uint SPI_READ_REG_ARRAY(uint reg, uint * array, uint length)
- CSN = 0;
- status = SPI_write_byte(reg);
- for(count=0;count<length;count++)
- array[count] = SPI_write_byte(0);
- SPI_write_byte(FLUSH_RX );
- CSN = 1;
- return(status);
- //THE NORMAL FUNCTION
- void longdelay(void){
- uint n=100,m=100,k=200;
- for (;k>0;k--) for (;m>0;m--) for (;n>0;n--) _nop_();
- uint payload[PLOAD_WIDTH]={0};
- void main(){
- init_NRF24L01();
- CE=0;
- SET_RX_MODE();
- CE=1;
- IT1=0;
- EX1=1;
- EA=1;
- PX1=0;
- LED=0;
- while (1){
- payload[2]=0;
- sta=SPI_READ_REG(STATUS);
- if (RX_DR) {
- SPI_READ_REG_ARRAY(RD_RX_PLOAD,payload,PLOAD_WIDTH);
- SPI_WRITE_REG_DATA_OR_CMD(WRITE_REG+STATUS,sta);//回写后irq没恢复。
- if (payload[2]) LED=~LED;
- void Renrf24() interrupt 2
- payload[2]=0;
- if (RX_DR) {
- if (payload[2]==1) {
- if (LED=0) LED=1;
- else LED=0;
复制代码 |
